Metal oil filter housing
Discussion in '5th Gen 4Runners (2010-2024)' started by banjos-n-beer, Mar 31, 2022.
  1. Mar 31, 2022 at 6:21 PM
    banjos-n-beer
    banjos-n-beer [OP] New Member
    Steve
    Maine
    2018 Pro
    Toy4X4, Spare Parts and Thatbassguy like this.
  2. Mar 31, 2022 at 6:28 PM
    redfield, Spare Parts, Toy4X4 and 2 others like this.
  3. Mar 31, 2022 at 6:40 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Yup get the fumoto valve.
  4. Apr 1, 2022 at 3:36 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
  5. Apr 1, 2022 at 4:21 AM
  6. Apr 1, 2022 at 7:02 AM
    Toy4X4 and Thatbassguy[QUOTED] like this.
  7. Apr 1, 2022 at 7:29 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    you can but I haven’t found a reason to.
  8. Apr 1, 2022 at 8:02 AM
    No. I believe some versions have a nipple so you can attach a tube. This one just drains straight down.
    Toy4X4 and glwood54[QUOTED] like this.
  9. Apr 1, 2022 at 8:08 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    ordered all 3 pieces a few hours ago. i forgot to ask, but sure i'll be okay, but i imagine the fumoto valve will be fine fitment-wise with my TRD skidplate?
  10. Apr 1, 2022 at 8:11 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Yes. The skid doesn’t cover the drain plug
  11. Apr 1, 2022 at 9:50 AM
    GtownRunner
    GtownRunner New Member
    2022 Black TRD Pro
    None Yet
    Question as I would like to add the drain as well. If my truck goes into Toyota for the odd oil change any hassle from them or potential warranty issues if something happened? They are reliable etc ?
    Toy4X4 likes this.
  12. Apr 1, 2022 at 9:58 AM
    Marchy
    Marchy New Member
    Sean
    Seattle
    2021 4 Runner Venture
    I would only worry about a young dumb tech taking the fumoto off vs just using the valve. and then you'd have to get a new washer for the fumoto and never go to the dealer again.
    BionicRandy, GoSlow, A&P and 3 others like this.
  13. Apr 1, 2022 at 10:38 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    on the limited we had prior, I added both the metal housing and valve, well worth it and I plan to do it to the new runner first oil change.
  14. Apr 1, 2022 at 10:59 AM
    slixx1320
    slixx1320 New Member
    If you have steel skids, it can be a PITA to remove them plus having the nipple version will help with oil not splattering all over the place when you use a hose.
    This ^^^.... thats why I won't take mine to Toyota. Yes, I get 2 free oil change but it's not worth the headache.
  15. Apr 1, 2022 at 12:59 PM
    2019 TRDP w/Kangs brah!
    I had Fumoto before without issues but I went with Stahlbus this time on both cars.
  16. Apr 1, 2022 at 4:23 PM
    Does one drain faster than the other?
  17. Apr 1, 2022 at 4:28 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Does the washer on the Fumoto ever need to be replaced?
  18. Apr 1, 2022 at 4:57 PM
    I'm going to say it's about the same as the Fumoto. This is when the time when I do other stuff like greasing the zerks.
    Not unless it starts leaking on you.
  19. Apr 1, 2022 at 6:02 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Was there a reason you chose Stahlbus?
    glwood54 likes this.
  20. Apr 1, 2022 at 6:09 PM
    I really just wanted to try something different. There's no valve handle to hit and you have a cap as a safety.
    Spare Parts[QUOTED] likes this.
  21. Apr 1, 2022 at 8:58 PM
    7harper7
    7harper7 New Member
    2022 AG TRD ORP
    Fumoto valve yes ,but what does the metal oil filter housing do that the composite one doesn't or didn't do? Did it break?
  22. Apr 2, 2022 at 12:15 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    The metal is stronger, less likely to break. Peace of mind.
    BGH2023, banjos-n-beer[OP] and Toy4X4 like this.
  23. Apr 2, 2022 at 3:14 AM
    Don't do that... One or the other, preferably the washer that Fumoto sent you. While I'm not sure of the engineering aspect of 2 washers, but it doesn't seem right. You're gonna like the Fumoto valve.
    Spare Parts likes this.
  24. Apr 2, 2022 at 6:37 AM
    On my recent oil change, the shop I use did it for the first time with the RCI skid. They left a bit a mess with oil on top of the skid. I took off the skid later and cleaned it up.
    Next oil change I plan to take off the skid, change the oil myself, and put on a Fumoto or Stahl valve and swap out the composite housing for metal. Then decide whether to reinstall the RCI skid or the oem ones.
    Isn't there a gadget for draining the filter housing prior to removing it?
    I want to do it at least once myself, just to know what all is involved.
  25. Apr 2, 2022 at 6:40 AM
    I'd remove the skid and work on the valve, then reinstall.
  26. Apr 2, 2022 at 10:51 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    This guys video shows some sort of nipple/valve to drain the filter.
  27. Apr 2, 2022 at 12:47 PM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    The OEM filters include the rubber o-rings and a plastic nipple for draining the oil from the filter housing. You just shove it in and wait about 5 minutes for the oil to drain out.
  28. Apr 2, 2022 at 2:13 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    The drain valve is much cleaner to drain the filter.
  29. Apr 2, 2022 at 2:15 PM
    2020 4Runner
    Fl
    Yes there is. It's a kit called MotivX. It comes with a screw-in funnel, filter wrench, and oil drain valve with tube. I have on for my Tundra.
  30. Apr 3, 2022 at 8:25 AM
    It's a feel good mod.
    trktwo, ecoterragaia and Spare Parts like this.
