meats magnetic rig
Discussion in '5th Gen Builds (2010-2024)' started by meats, Aug 29, 2024.
  1. Aug 29, 2024 at 6:44 PM
    meats
    meats [OP] New Member
    Broken Arrow, OK
    2018 Magnetic Gray TRD OR
    2/1 Cornfed Leveling kit Sway Bar Delete 285/70/17 - Arroyo Tamarock M/T
    New to the forum--
    Big fan of the 4runner my whole life. The 3rd gen is my fav Gen but I found a solid deal on this 5th Gen TRD Off-Road. It was meticulously serviced at the dealer. It's in great shape. 1 owner. I ordered a 2/1 cornfed leveling kit. Eventually will add tires and a few things. It's just so capable as is.
    Pulled the dealer badge off the rear already too.
    Enjoy the build. Thanks for having me.:hattip:
  2. Aug 30, 2024 at 7:02 AM
    meats
    Broken Arrow, OK
    Paid 32k cash. Not bad for 93k miles. The used car market sucks right now!
    In the mail:
    1. Blackout badge kit
    2. Steering wheel blacked out emblem
    3. Mud flap delete rears
    4. Trunk rear seat protection
    Coming soon:
    • 285-70-17 Mud terrain tires. (Open to suggestion. Don’t want the most expensive nor the cheapest)
    • Simple black rims. 17s
    • 3” lift - Mid travel suspension (Open to suggestion)
    • Nguyen Fab high clearance rear bumper
    • Front hi clearance steel bumper (Open to suggestions)
    • Cali-raised kick-out sliders with top plate powder coated.
    • MAYBE -
    dgtulsaguy and HuskyMike like this.
  3. Aug 30, 2024 at 7:32 AM
    Noice
    welcome to the group
    icebear and meats[OP] like this.
  4. Sep 4, 2024 at 12:48 PM
    meats
    Broken Arrow, OK
    First suspension mods:
    • sway bar delete— I’ve done this on every Toyota and Offroad rig I’ve owned.
    • 2” front leveling kit from Cornfed suspension. After doing the front I decided not to do the rear.
    Took me a couple hours. Some oil under the skid but no leaks. Just lazy technicians doing oil changes.
    Also added some Molle seat backs to keep the kids feed off the seats and add storage.
    In the mail:
    Coming soon:
    Thacrow likes this.
  5. Sep 4, 2024 at 2:57 PM
    ThomasL
    ThomasL New Member
    Florida
    24 TRD Off Road Prem
    Looks great!
    If you’re going to go with bigger heavier tires may be try to get “lighter” wheels from Method or Nomad, they are some out there that weigh about 22 pounds. Helps offset the bigger heavier tires.
    Thacrow likes this.
  6. Sep 4, 2024 at 3:23 PM
    meats
    Broken Arrow, OK
    Great advice. I'll post a couple options and see what people think
  7. Sep 4, 2024 at 4:53 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Grats on the sweet ride and glad you're on the forums. For suggestions, in short, map out your long term plans. Sleep on it a while and audit those plans. throw them on here for critique.
    For tires - are you going to upgrade the spare? and do you want the spare to fit under the car? Make sure the tires you're getting fit if you need them to fit under the same.
    Do you want skids? Winch? anything else? - Add of the additional weight of your bumpers and everything else and make sure you buy springs that will support that weight in the future. Don't want to have a sweet ride height now get all droopy in the front or rear or both. This is very important.
    Wheels - how do you want your stance to look? wheels / tires sticking out. Do you like the look of the tires sticking out a little? get read to cut more so they don't rub. Anyone here who says they but on 285's and had zero rubbing is insane. Do not listen to that. Maybe they only drive in straight lines. I don't know. If you're going to go off road you need no rubbing on full articulation at full wheel turn so you'll need to do some trimming. More negative offset = more trimming.
    You'll be noticeably slower with those tires and worse MPG. Consider an ECU flash to help with both points.
    3 inch lift you'll probably need to upgrade the needle bearing and with the millage on the vehicle probably just do it preventatively.
    meats[QUOTED][OP] likes this.
  8. Sep 4, 2024 at 7:12 PM
    ThomasL
    ThomasL New Member
    Florida
    cool! I also want to blackout the car, sadly I can’t find any aftermarket wheels that I like. I actually really like the look of the OR wheels, just wish they were black matte black.
  9. Sep 6, 2024 at 8:23 AM
    meats
    Broken Arrow, OK
    Tires in the mail - Arroyo Tamarock M/T - 285/70/17. Got the protection package and 5 tires. Stock rims for now. I'll get better rims when I slap on a solid midtravel kit.
  10. Sep 6, 2024 at 6:57 PM
    meats
    Broken Arrow, OK
    You could powder coat them
  11. Sep 6, 2024 at 7:48 PM
    I paid right at $200 a wheel to have mine powdercoated.
    I took all 5 up there so even the spare matched, powder coat shop about an hour away from me. They sand blast them, bake them, powder them, bake them and then they are done.
    If you like that wheel and want it black, all you gotta do is have them powdercoated.
    meats[OP] likes this.
  12. Sep 6, 2024 at 8:00 PM
    meats
    Broken Arrow, OK
    Looks slick. I am looking at some methods. Something extra light.
  13. Sep 7, 2024 at 10:03 PM
    ThomasL
    ThomasL New Member
    Florida
    Thanks for the pointers guys!
  14. Sep 9, 2024 at 5:10 PM
    meats
    Broken Arrow, OK
    Atturo - Trail Blade X/T - 295/70/r17 - In the mail now. 5 tires coming. Wish me luck fitting them. I have plates for BMC -- I've done a DRT BMR on a 2020 Tacoma previously so that shouldn't be a big deal. Also will need some sort of viper cut. Anyone have suggestions on fitting the 295s? Right now just have a 2" front spacer lift. I don't want to the upgraded suspension yet.
    captrussia253 likes this.
  15. Sep 9, 2024 at 5:45 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    You don't need a suspension lift to fit tires per se. When your suspension articulates it pushes the tires up. The lift just gives ground clearance. Not tire clearance. I would go to Perry Parts and order bump stops. Front is going to need taller bump stops so these tires don't crash into your fender liners when they articulate.
    What offset are your wheels?
    Do you want a viper cut? Those are 33.3's. You could remove the mud flaps, do a BMC, cut a little bit of bumper and melt and push / relocate part of the fender and it should clear.
    295's are wider than most go so you'll need more negative offset to clear your frame and UCA meaning you'll need to cut more bumper.
    If you want to do a viper cut though, then start there. Push the tires all the way forward after the viper cut and see if you don't need to remove the mub flaps or do a BMC.
    You will be noticeably more sluggish and get much worse MPG's but it won't be as bad as your dash says because your speedo thinks you're going slower than you are. You're right on the fence for a regear.
  16. Sep 9, 2024 at 6:16 PM
    meats
    Broken Arrow, OK
    Using stock rims for now. I'l be doing some methods. 0mm offset or - whatever I need
  17. Sep 15, 2024 at 5:57 PM
    meats
    Broken Arrow, OK
    Great kit. Super easy to do. Looks slick. More room and clearance for sure.
    Thacrow likes this.
  18. Sep 15, 2024 at 6:55 PM
    More room, nice.
  19. Sep 15, 2024 at 7:09 PM
    meats
    Broken Arrow, OK
    100%
  20. Sep 15, 2024 at 7:31 PM
    Bend_4R
    Bend_4R New Member
    I installed RoxBloxz mudflaps that take up the same amount of room as the mud flap delete kit if you want to use mud flaps.
  21. Sep 15, 2024 at 7:34 PM
    meats
    Broken Arrow, OK
    I opted for none. I'm probably going to put on some taller pizza cutters so I figured less would make it look taller. 255/80/r17s
    ThomasL likes this.
  22. Sep 16, 2024 at 5:32 AM
    ThomasL
    ThomasL New Member
    Florida
    Sick! is it just me or people are moving from the wide rims and tires with the tires stretched out with a wide stand to more in the fenders skinnies with a taller tires to raise the ground clearance.
