Max weight on top of the 5th gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Nov 15, 2023.
  1. Nov 15, 2023 at 9:22 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    What is it? I hope I am not over it. 60 lb KO2, maybe 40 lb wheel, and 60 lb rack, and soon 60 lbs of fuel.
    JuliaGotta4x4 likes this.
  2. Nov 16, 2023 at 3:59 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I think the after market racks and how they mount to distribute weight change this but there is from manual
    Owners manual 2021 4Runner - Page 190 - "Do not exceed 120 lb. (54 kg) cargo weight on the roof luggage carrier."
    Yotaholic[OP] likes this.
  3. Nov 16, 2023 at 12:09 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    The product should have documented static/dynamic weight limits.
    Check with your manufacturer for specific weights.
    SuedePflow and Yotaholic[OP] like this.
  4. Nov 16, 2023 at 12:41 PM
    AKA: No fat chicks can ride on the roof. Or your drunk ass friend named Darryl.
  5. Nov 16, 2023 at 12:48 PM
    Yotaholic
    Olympia, WA
    Zero clue what to do with them. They are heavy with no gas in them. And my roof frack is cheap and crappy :p
  6. Nov 16, 2023 at 1:09 PM
    TRDSD
    2019 TRD Off Road Premium
    The lack of crossbar support vs. weight is your biggest concern. Essentially, that's a wire rack that's only supported in 2 places with the cross bars you have.
  7. Nov 16, 2023 at 1:33 PM
    Sounds like an excuse to buy a better roof rack.
    Or, reinforce the one you have.
    My basket is attached to the side rails with angle channel. 3/8" carriage bolts slide right into the side rails, If you remove the end caps. I bolted those through the angle channel and used rubber washers to isolate the channel from the side rail so they wouldn't scratch each other up. Then, I used small u-bolts to attach the basket to the angle channel. Not that it necessarily adds any capacity, but the basket sits tighter to the side rails, and it feels much more solid this way.
    Yotaholic[QUOTED][OP] likes this.
  8. Nov 16, 2023 at 1:38 PM
    2021venture
    Todd
    2021 Venture
  9. Nov 16, 2023 at 1:45 PM
    nova
    nova New Member
    mike
    Hate to say it but your storage rack doesn’t appear to be engineered for this application.
    If it is junk, sell it and get something more purposeful. I like Sherpa Crestone and you might see a Black Friday sale if you look. Front-runner, Prinsu, et. al. Their’s a lot of good options. You can expect capacities of 300 / 700 (static/dynamic) with a good rack.
    You’ll probably need to revisit your gas can solution as well.
  10. Nov 16, 2023 at 1:48 PM
    Yotaholic
    Olympia, WA
    I think reinforcing it is a better idea for now.
  11. Nov 16, 2023 at 1:56 PM
    What is the emblem on the left front fender. I cannot make out what it says.
  12. Nov 16, 2023 at 2:01 PM
    Yotaholic
    Olympia, WA
  13. Nov 16, 2023 at 2:55 PM
    Yotaholic
    Olympia, WA
    Strapped the life out of them for now. We will see when we will fill em up!
  14. Nov 16, 2023 at 3:09 PM
    Yotaholic
    Olympia, WA
  15. Nov 16, 2023 at 3:13 PM
    For serious overlanding I can see the benefits of an equipment rack on top. My main concern would be being too top heavy resulting in increased roll over risks.
  16. Nov 16, 2023 at 10:37 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    I would put that spare tire back under the vehicle and call it good.
    Rocko9999 and Yotaholic[OP] like this.
  17. Nov 16, 2023 at 10:59 PM
    Yotaholic
    Olympia, WA
    It is 34 inches, won't fit.
  18. Nov 16, 2023 at 11:10 PM
    Do 34’s fit underneath in the spare tire area? I think we all know where this is going, lets not beat around the bush. Our friend Mr. @Yotaholic has painted himself into the rear bumper corner lol.
    Just kidding ;) There’s always creative solutions….
    (Usually temporary ones….until you can no longer resist and just say screw it and get a bumper with double swingouts. Then that will be followed by re-doing your rear suspension to match the weight, then doing it again when you overshoot and it sits too high…. Buuuut maybe a Gobi rack would have enough weight to settle the suspension down a bit instead….Then that’s when you realize what is meant by “4runner lifestyle” and then you go all in and get tattoos and shit)
    :anonymous:
  19. Nov 16, 2023 at 11:12 PM
    Yotaholic
    Olympia, WA
    C4 Fabrication will bankcrupt me lol, 5 grand minimum.
    Justkelvin likes this.
  20. Nov 16, 2023 at 11:34 PM
    Yotaholic
    Olympia, WA
    My Inspiration
  21. Nov 17, 2023 at 8:07 AM
    nova
    nova New Member
    mike
    Hmmm - C4
  22. Nov 17, 2023 at 8:28 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Tell that to people who spend $5K on roof top tents.
  23. Nov 17, 2023 at 8:30 AM
    2021venture
    Todd
    2021 Venture
    Hope this is not controversial but personally I don't trust the roof for climbing on top of roof. My rack is overbuilt and I trust it. Weakest link is the roof supporting the weight of rack or tent.
  24. Nov 17, 2023 at 8:52 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Do the bfg ko2 285 75 17 actually measure 34"? I thought ko2s ran small.
    Do you have an on board air system?
  25. Nov 17, 2023 at 9:00 AM
    surfingbuddhist
    surfingbuddhist New Member
    Glen
    2020 4Runner
    THIS ^. SUV's are already notoriously prone to roll overs because of their higher center of gravity. With more weight added to the highest point, it wouldn't take much for an inexperienced driver to tip it over.
  26. Nov 17, 2023 at 10:16 AM
    Henry J
    Sacramento Ca
    Get a rear tire swing and attach the gas tanks to that.
  27. Nov 17, 2023 at 1:40 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    That rack and yours is alot different. So id rethink putting all that weight in a basket that's mounted to the lightweight factory rack.
  28. Nov 17, 2023 at 2:53 PM
    Here's an alternative location for an oversized spare. Obviously it eats up some cargo room. But, I still manage to fit everything I need in there with it. By placing it directly behind me, I hardly notice it in the rear view mirror.
  29. Nov 17, 2023 at 3:03 PM
    This is definitely worth considering. I've heard of 4Runners tipping at Black Bear pass, and generally being considered tippy. Some of the overland crowd seem to really load stuff up on the roof rack, and I wonder how much of a factor it has been in these incidents.
    I think the best use of a roof rack is to store bulkier items that aren't too heavy. I try to keep the heaviest things as low and centered in the vehicle as possible.
  30. Nov 17, 2023 at 3:23 PM
    Yotaholic
    Olympia, WA
    It is doing fine, this is kind of wheeling I will do, nothing crazy. I should be safe with that weight on top
    djwantke likes this.
