Max height on 2019 after fox coil overs and 285s
Discussion in '5th Gen 4Runners (2010-2024)' started by Narbeh, Dec 14, 2018.
  1. Dec 14, 2018 at 1:06 PM
    Narbeh
    Narbeh [OP] New Member
    Narbeh
    La Canada Flintridge
    2019 4Runner TRD Off Road Premium
    Hey guys. Does anyone here have a 5th gen lifted with 285s and the stock roof rack. Can you measure the max height of your truck? I want to know if the truck is less than 6ft5inches. My office building has a low clearance and want to be sure I won’t run into issues. I’m doing a fox 2.0 coil over camburg UCA and rear OME spring with fox shocks on Wednesday. Running 285 bfg on the oem trd wheels.
    Thanks so much.
  2. Dec 14, 2018 at 2:05 PM
    76 1/2 "
  3. Dec 14, 2018 at 2:20 PM
    Narbeh
    Narbeh
    What is your setup?
  4. Dec 14, 2018 at 6:17 PM
    About 2 1/2" in the front with 2" longer springs in the rear, 285/70/17
  5. Dec 15, 2018 at 9:24 AM
    With 285's, you will add roughly 1" to your stock height. With Fox coilovers in the front, you can adjust those to provide you with little to no lift if you want. We need more info on the rear springs. Are they adding any lift to the rear? How much lift do you want to add to the front?
  6. Dec 15, 2018 at 9:34 AM
    Narbeh
    Narbeh
    OME rear springs with fox shocks. I think overall gain in height will be 3” so I should be ok.
