Massive leak on driver side floor
Discussion in '5th Gen 4Runners (2010-2024)' started by Kennyp, Oct 20, 2018.
  1. Oct 20, 2018 at 3:33 PM
    Kennyp
    Kennyp [OP] New Member
    2011 Magnetic Grey 4Runner Limited
    Iv had pool of water on my floorboard almost every time it rained and could not figure where it was coming from. I checked the AC drain hose and even modified the hose to extend directly away from the body...still no results. Found out after taking to Toyota that the pwr roof drains were clogged. Took about 20 minutes and Ive never had the problem again. Paid $189 for diagnostic. Starting to learn some of the quirks Im going to endure with this truck.
  2. Oct 21, 2018 at 9:36 AM
    4runningMan
    4runningMan New Member
    New Mexico
    I didn't know the moon roof had drains?! So water gets in the seals?
  3. Oct 22, 2018 at 7:02 AM
    poncho65
    poncho65 New Member
    New England
    It's a common issue on the 4th and 5th gens. Once a year I check the drains, lube the tracks and clean the sunroof area when it's open. I'm not a huge sunroof fan, I'd rather the extra headroom.
    LandCruiser and 4runningMan like this.
  4. Oct 22, 2018 at 8:05 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    How do you check the drains do you just simply open the sunroof and can you see them when open?
    thirdyota and cjrunner like this.
  5. Oct 22, 2018 at 11:43 AM
    Kennyp
    They are either side of the sunroof..open the roof and you will see them facing the front left and right in the water well area
  6. Oct 22, 2018 at 11:45 AM
    Kennyp
    Might want to use some sort of thin wire or maybe some weed wacker line to run it through....thats probably what I will do with mine the next time
  7. Oct 22, 2018 at 5:31 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I do not keep that roof window open when parked under trees .. that is how they get plugged up.
    could use air pressure , put a air regulator on the output, use low pressure to blow out the lines.
  8. Oct 23, 2018 at 4:02 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    So I'm assuming this happens when left open and their allowed to block up. Please tell me the sun roof doesn't leak or allow water into that "well" area when closed.
    4runningMan likes this.
  9. Oct 23, 2018 at 6:35 AM
    j cat
    j cat New Member
    massachusetts
    water enters that well area not a perfect seal which is why these roofs on all vehicles have drain holes..
    after the spring pollen falls I open the roof glass and clean it up with a sponge.. then I spray silicone on a soft cloth and wipe down the rubber seals so that the rubber stays soft and repels the debris from getting into that well area ..
    common if its not cleaned and its open a lot ..
  10. Oct 23, 2018 at 6:38 PM
    2018 4Runner Premium Blue
    2018 4Runner Premium Blue New Member
    AL
    2018 Blue 4 Runner Premium
    That stinks that this has happened to you but thanks for sharing, my first vehicle with a moon roof so have been wondering if people have issues with them.
  11. Oct 24, 2018 at 4:08 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    What exactly do you use to moisturize the seals I'd like to get some. I know Honda sells a grease they recommend for door hinges and also "moisturizing" seals and gaskets I suppose I could just get a little tube of that. No real rush immediately as it's a 2018.
  12. Oct 24, 2018 at 8:38 AM
    DEDON
    DEDON New Member
    Don
    '06 SR5 Stock
    The other guys are correct and it probably IS just that the holes are plugged with debris. It's an easy fix. There are holes in both left and right front corners. They also exist in the rear corners and they are a little more difficult to get to.
    With the driver's door and sunroof open, climb up so that you are standing up through the open sunroof. As suggested, run some weed wacker line ( you'll only need 4 feet) down through the holes. You'll feel when you pass through the blockage, most of the time. Then, pour some warm water through the holes...4-6 oz is plenty. Voile! You may want to clean the rest of the ledges as best you can so that it stays clear for a while. I had this issue 6-8 months ago. It's a easy fix. Best of luck.
  13. Oct 25, 2018 at 12:11 PM
    fsroader
    fsroader New Member
    james
    E.TN.
    I have never seen the need or advantage of a hole in my roof. Add the inevitable screw-ups that will occur over time and this is why I have purposely never had one. Unfortunately I do now. Not happy but the TRD Ps all had them. Did I mention they serve no purpose and are totally useless?
  14. Oct 25, 2018 at 12:16 PM
    4runningMan
    New Mexico
    Hahaha yeah I ended up with one too. And feel the same as you do about them. Oh well. It's a great truck.
    fsroader[QUOTED] likes this.
  15. Oct 25, 2018 at 3:42 PM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    I don't use mine very often maybe open it 5 times all summer but I look at them like A/C even if you want/need it a handful of times a year WHEN you want it they totally seem like their worth whatever you paid for it. Good resale point of interest too.
    toy33 likes this.
  16. Oct 25, 2018 at 4:53 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    We used to use a piece of weed eater cord to clear the holes. I buy mine by the roll so was was nothing to spool off 10 feet for the job
    jester243 and fsroader like this.
  17. May 30, 2019 at 9:07 AM
    toy33
    toy33 New Member
    T. Batey
    CA: OC LA SD BB
    2024 TRD Pro Tundra - Terra
    PPF Front end hood, grill and headlights
    No purpose ? I use mine in combo with the back glass down a few inches and get a nice wind chill without the noise that the side windows would cause at highway speeds. Also enjoy the light in certain situations and seeing nighttime sky in the middle of nowhere.
    Singleminded and Big_jarv like this.
  18. May 30, 2019 at 6:22 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Me too...I love mine and do the same thing. It was actually the deciding factor between the two premiums they had in stock. I use it all the time.
    toy33[QUOTED] likes this.
  19. Jun 27, 2021 at 4:39 AM
    Ohya
    Ohya New Member
    2013 4Runner
    My 2013 trail edition driver side is totally wet today too after heavy rain for 1hour...
    The top of A-pillar was starting wet first, then the down side control panel just like water fall after...
    A bunch of water drain from left side control panel upon my foot when i was going to drive back home...
    Later on when on the way back home, the multi-terrain system seems activate unintentionally and randomly (i was in 2WD mode) so center display show "multi-terrain system cannot be selected..." several times...
    The center side is dry (supposed to be), i didn't see any leakage, the leakage are all at driver side.
    May i know is this same symptom as sunroof drain clogged?
    Hopefully it's simple mechanical/physical fix, nothing matter to electrical or deep tear down repair required... :(
    Can anyone help to comment? appreciate for the help~
  20. Jun 27, 2021 at 5:38 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Fried had this issue years ago in his Lincoln suv. The sun roof drains would clog and creat the same problems. On his truck the drain tubes for the sun roof tracked through the A-pillar down to the drivers and passengers door and dumped out at the bottom corner or each door opposite of the door hinge side. We found that weed eater cord was perfect for clearing the clogs. Started from the top and push out the crud. I’d likely follow up with a diluted bleach mix and then flush with clean water
  21. Jun 27, 2021 at 8:08 AM
    Coupe
    Coupe New Member
    Houston, Texas
    2008 Toyota X-Runner
    I was once parked on a steep incline, during a heavy rain. This caused one drain line to take all of the rain. When the drain could not handle to incoming load, it leaked into the cabin. There was nothing wrong with the drain, it was the steep incline I was parked on.
  22. Jun 27, 2021 at 5:02 PM
    Another reason I dislike moonroofs.
    IceYeti likes this.
  23. Jun 27, 2021 at 11:59 PM
    Ohya
    Ohya New Member
    2013 4Runner
    I parked at incline heading downward too and have a tarp connected to the tail gate. All the rain on the tarp was flew on the roof. If this is a rational suspicion, perhaps it makes front side drain out of the design expectation... :confused::confused::confused:
  24. Jul 1, 2021 at 4:07 AM
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    I had a Mazda that had mold growing in the sun roof drain tubes, which were clogging up. Parking under trees will do strange stuff to a car.
    Pouring some 50:50 bleach/water down it cleared the clog.
    LandCruiser and toy33 like this.
  25. Jul 9, 2021 at 6:57 PM
    Ohya
    Ohya New Member
    2013 4Runner
    Finally, it was a drain tube loosen and that spent me around $500 to fix it and clean the carpet and check all the wiring make sure those are no damaged. Hope that won’t happen again…
  26. Jul 10, 2021 at 7:12 AM
    j cat
    j cat New Member
    massachusetts
    did the repair tech give details on how the drain tube fell off or did the drain tube break off and cracked ?
    many Toyota and other manufacturers use plastic parts that breakdown.
