Lucas upper cylinder oil
Discussion in '5th Gen 4Runners (2010-2024)' started by nagano21, Oct 20, 2024.
  1. Oct 20, 2024 at 9:16 AM
    nagano21
    nagano21 [OP] New Member
    AC
    2013 SR5
    Exhaust, tires
  2. Oct 20, 2024 at 9:18 AM
    No need for additives. I just change my oil regularly.
    Daddykool, Sin4R and catbrown357 like this.
  3. Oct 20, 2024 at 9:20 AM
    nagano21
    AC
    2013 SR5
    Exhaust, tires
    Same, this goes into the fuel tank, so advertised to do more than just lubricate like motor oil does.
  4. Oct 20, 2024 at 9:22 AM
    2016Pro
    Waste of money, every 10k oci with whatever brand of synthetic on sale and your motor will go 500k miles easy
  5. Oct 20, 2024 at 9:54 AM
    nagano21
    AC
    2013 SR5
    Exhaust, tires
    True… wish the body would last that long. Sad how badly they rust. I’ve been using fluid film but the damage is done.
    2016Pro[QUOTED] likes this.
  6. Oct 20, 2024 at 9:57 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Exactly. An ounce of prevention... Change your oil early if you are concerned.
    Now, I personally do use various additives, but this is in a classic cars that are 40+ years and are not built for modern oil formulations or track cars that spend a lot of time at the redline, or DI-only cars with known carbon buildup issues, etc.
    Absolutely no reason for oil or fuel additives in a daily driver 4Runner that gets top tier fuel and regular oil changes.
  7. Oct 20, 2024 at 10:16 AM
    Lost Woods
    Lost Woods New Member
    Sooo you're adding a lubricant into a giant tank of solvent and that doesn't sound off to you?
    It's snake oil like 90% of what Lucas sells and the other 10% is a band aid for broken shit. Just use good gas and change your oil properly.
    jasonmcelroy and 2016Pro like this.
  8. Oct 20, 2024 at 11:03 AM
    nagano21
    AC
    2013 SR5
    Exhaust, tires
    I guess you’ve never heard of a two-stroke…
    BillyE and 08TXRunner like this.
  9. Oct 20, 2024 at 11:47 AM
    Lost Woods
    Is your 4Runner a two stroke?
    RumHamRunner73 likes this.
  10. Oct 20, 2024 at 11:49 AM
    nagano21
    AC
    2013 SR5
    Exhaust, tires
    Haha. No but a two-stroke runs off of a mix of gas and oil.
  11. Oct 20, 2024 at 12:16 PM
    Lost Woods
    Right but we're not talking about two stroke oil which is for an engine designed to be lubricated by this mixture. My comment was because there is nothing in a 4 stroke engine that will take advantage of this. A 4-stroke isn't designed to take advantage of lubricant in the fuel because the fuel never enters the crankcase when things aren't broken. Gas will prevent most lubricants from adhering to surfaces so you're not adding lubricant anywhere that it is needed, you're adding a lubricant to a system that has no parts that need lubrication and will just inject that mixture into a cylinder where it is immediately burned.
    2016Pro likes this.
  12. Oct 20, 2024 at 1:19 PM
    Sin4R
    Mall crawling kit.
    This is incorrect for any engine, but more so for forced induction.
    Watch this for good explanation: https://www.youtube.com/watch?v=DAmEGI7xvBw
    nimby, Rocko9999 and 2Toys like this.
  13. Oct 20, 2024 at 10:09 PM
    Lost Woods
    This is why it's stupid to try to be helpful on the internet because someone will always hyperfocus on a general statement and post some video like it's universal gospel. Your oil choice and routine and driving habits will have an exponentially greater impact on the longevity of your engine than anything you run through fuel. If you are to the point that the additives in the fuel are impacting your wear outside an academic setting then I congratulate you on your discipline.
    Noodles likes this.
  14. Oct 21, 2024 at 5:37 AM
    2016Pro
    Oil brand choice doesn't matter
  15. Oct 21, 2024 at 6:07 AM
    CHS4runner
    CHS4runner New Member
    DW
    2024 Black ORP
    Don’t run that stuff through your injectors and fuel system. Especially the 4Runners since it recirculates it.
  16. Oct 21, 2024 at 10:01 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    This is a great video. There is a measurable benefit to fuel that contains anti-wear/friction modifier additives. 15:05 is the main part talking about this.
  17. Oct 21, 2024 at 10:46 AM
  18. Oct 28, 2024 at 2:45 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Are you putting vehicle into storage for many months of nonuse? Then maybe a good idea.
  19. Oct 28, 2024 at 12:21 PM
    java
    java fauxrunner
    2023 ORP ice cap
