Lower Control Arms
Discussion in '4th Gen 4Runners (2003-2009)' started by grumpy 02, Apr 9, 2024.
  1. Apr 9, 2024 at 9:21 AM
    grumpy 02
    grumpy 02 [OP] New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    Just had the 4Runner aligned. The Tech (owner) of the shop said he was able to get a good alignment, but 3 of the 4 cam bolts are seized. He said it would cost more to cut out/replace than installing new OEM LCAs. He also said that none of the aftermarket LCAs he has ever used were worth installing because of fitment/alignment issues. That being said, has anyone replaced their LCAs with aftermarket & been happy? If so what brand? Thanks
  2. Apr 9, 2024 at 12:59 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Well, lets see here.
    Mechanic say cutting out the cam bolts will cost more than just installing new LCAs. Which makes no sense to me since he would have to cut out the cam bolts to replace the LCAs either way.
    I am running SuperPro LCAs and have had zero issues with them. Been on for a couple years now too. As long as anti-seize is used generously on the cam bolts when they are installed, which is also specified by SuperPro in their instructions, that should reduce the chances of seized cam bolts in the future.
  3. Apr 9, 2024 at 1:35 PM
    The statement from the tech is not accurate in my opinion. Sounds as if the shop did not want to correct your issues.
  4. Apr 9, 2024 at 2:02 PM
    grumpy 02
    Stan
    None Yet
    Kinda had the same thought. You ever cut those out? Hard to do? Just a Sawzall & good blades, right?
  5. Apr 9, 2024 at 2:51 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    Any reason you want to go aftermarket? Just curious. Lifted? Etc?
    I went with OEM replacements not that long ago but mine is also a family hauler/highway princess so wasn’t in need of anything extravagant.
  6. Apr 9, 2024 at 3:30 PM
    grumpy 02
    Stan
    None Yet
    Cost mainly. Almost $900 for LCAs seems pretty steep.
  7. Apr 9, 2024 at 3:52 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have a southern Arizona truck, so no, I didn't need to cut mine out fortunately. But yes, sawzall and good blades should do it. I would order new bushings as well, since those can get messed up cutting the bolts. Still cheaper than replacing the whole LCA.
  8. Apr 10, 2024 at 6:22 AM
    racinjason
    racinjason New Member
    xtremewlr likes this.
  9. Apr 10, 2024 at 12:37 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    +1 for 1AAuto. Installed their LCAs in January 2023 and have ~30K miles on them including some rough trails and bump/scrape/bang rock crawling at Windrock Park, no issues. With that said, time will tell as far as long-term reliability.
  10. Apr 11, 2024 at 5:47 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    DirtKing LCAs chiming in. Love em and no issues so far :cheers:
  11. Apr 11, 2024 at 6:04 AM
    grumpy 02
    Stan
    None Yet
    Thanks guys. I will save all the info for when I have to do this. Since the alignment is good, I will kick this down the road for awhile.
  12. Apr 14, 2024 at 7:58 PM
    GreatWhitePig
    GreatWhitePig New Member
