Low Profile Drawer Build
Discussion in '5th Gen 4Runners (2010-2024)' started by PCRIDE4RUNNER, Oct 2, 2025.
  1. Oct 2, 2025 at 8:34 AM
    PCRIDE4RUNNER
    PCRIDE4RUNNER [OP] New Member
    SUPER DUPER
    Any thoughts on this build for a low profile drawer box? I’ve been fabricating this box system which will be covered in 1/4” ABS, riveted to the steel frame. Two full extension wood drawers (Baltic wood) with dividers and compartments. The drawer system is designed for a drop in and turn buckle mounting system, and modular boxes can be clipped in to make different combinations. I’ve only seen one brand that has such a modular system. the system also is unique by leveraging side supports that create a storage area over the wheel wells and prevent gear from falling /rolling into the cargo area.
    Additional modular accessories can be used like a bolt on security box/cage on top of the base drawers , this can allow storage of gear in a lock cage essentially.
    gear tie downs, extension bars, platforms etc can all be modular.
    ChessGuy likes this.
  2. Oct 13, 2025 at 11:57 AM
    PCRIDE4RUNNER
    SUPER DUPER
    Here’s an update with the ABS cut to fit and a dry fit on everything.
    ChessGuy and RumHamRunner73 like this.
  3. Oct 14, 2025 at 8:37 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Installed both drawers.
    Welded the drawer guides in. Seemed to work perfect.
  4. Oct 15, 2025 at 6:13 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks good, i built a low profile box as well. I love it. Probably one of the best mods.
  5. Oct 15, 2025 at 6:40 AM
    PCRIDE4RUNNER
    SUPER DUPER
    That looks great. I like how you did the drawer fronts with the latch cut outs. I’ll probably borrow this method!
  6. Oct 15, 2025 at 8:33 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    If i changed anything it would to put only one latch on each drawer.
  7. Oct 15, 2025 at 8:35 AM
    PCRIDE4RUNNER
    SUPER DUPER
    I thought of that as well, but after it was all installed as takes away from having a handle on the front, and forcing the user to grab the sides which is difficult. The drawer rails came as a set, each having a latch. I suppose there are various drawer guides with one, two latch.
  8. Oct 18, 2025 at 6:56 PM
    PCRIDE4RUNNER
    SUPER DUPER
    95% complete.
    Just need drawer front cover, 1/8” sheeting on the sides (didn’t account for the ABS thickness on the width.
    used 5/8 sq tube steel and 1/4” ABS with 5/8” x 3/16” rivets and glued with silicon.
    I added structure plates on the corners to mount tie downs (bolt through)
    the next piece will be a larger box that snaps in on one side. I could make an extension platform for a sleeper.
    Working with that ABS is nice! Cuts like wood, sands smooth. Heat formable too with thinner sheets. I’ll probably carpet the inside drawers.
    Full cost material
    $115 ABS sheet 4x8
    5/8” steel sq tube $40
    $160 for drawer guides $80 x2
    $180 Baltic birtch plywood
    $20 rivets
    $12 turn buckles
    not bad for DIY pricing.
    Ricphoto likes this.
  9. Oct 19, 2025 at 10:02 AM
    Geojanitor
    Geojanitor New Member
    Dave
    Eastern WA
    2019 Red SR5 Premier
    Gobi Stealth Rack, Finn Fab Molle Panels, Greenlane sliders
    PCPRIDE4RUNNER, Could you post the drawer dimensions and the overall weight? Thanks
  10. Oct 19, 2025 at 11:49 AM
    PCRIDE4RUNNER
    SUPER DUPER
    here are the details.
    4runner low profile Drawer box
    Frame outer dimensions (assumes the frame thickness is 5/8 x 5/8” steel sq tube)
    41” width
    33” 7/8 depth
    7” height
    Drawer cavity width 19” 5/8” (5/8” divider)
    Drawer dimensions - used 5/8 and 3/8 Baltic birch plywood)
    Dado the bottom of the drawer (3/8”)
    Lap joint , glue and nail sides
    Dado side cutouts for dividers if you plan that
    32” 3/4” x 17 7/8 x 5” 3/8”
    Drawer boxes assume 7/8” on each side to allow for drawer guides. Drawer guides will have different thicknesses so double check if you aren’t using the exact drawer guides here 32”
    https://a.co/d/2W7Z52J
    Rivets for ABS paneling https://www.amazon.com/dp/B0C4TQ1X1B
    Optional- The side top extensions for cargo is a 60 degree slope on the back to allow for the rear seats to recline fully w/out hitting the boxes. The height is 8”. The side extensions allow storage items above and around the wheel well without it falling/occupying the cargo area
    If you plan to use these dimensions, and the ABS paneling, buy two sheets 1/4” and 1/8” . The 1/8” is used for the sides. Because this design doesn’t allow an extra 1/4” allowance for the ABS to fit between the plastic in the 4 runner. See picture. Otherwise reduce the overall frame dimensions by 3/8” to allow 1/4” ABS sheeting on each side.
    Note: this exact design using metal sq tube and requires the top to be capped with alum channel if you want a finished look. (Still working on a solution. You could cap it off with the ABS and it wouldn’t look too bad after Sanding)
    and welding keeps the weight down compared to larger plywood. Using the Baltic birch plywood dimensions stated above is on purpose as you don’t need a full 3/4” plywood. Estimated overall weight is 50-60lbs
    Detail showing the tolerance if using 1/4” ABS sheets on each side.
    Guppy1301 and Geojanitor[QUOTED] like this.
  11. Oct 19, 2025 at 11:57 AM
    2020 Venture / 2017 Tacoma
    Well done :hattip:.
  12. Oct 20, 2025 at 1:48 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Nicely done and clean! Drawer slides jack the price up! I'm about the same cost as you and did mine out of all birch 2 years ago.
    PCRIDE4RUNNER[OP] likes this.
  13. Nov 1, 2025 at 6:21 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Adding mod box plus. Provides extra storage when traveling, while keeping gear organized and accessible. Bonus wheel steering wheel turny thing. You never knew you needed it until now.
    Guppy1301 likes this.
  14. Nov 2, 2025 at 5:22 PM
    PCRIDE4RUNNER
    SUPER DUPER
    Got it all done. Just need to cap the edge with alum angle.
    Total cost at about $700 and about 5 days labor.
    the larger box bolts down, you can see the access panel on the back (didn’t weld the plates in the right spot so I have this extension). Looks fine tho.
    Welded the gear basket, then bolted to the box.
    learned other ways it could be built, but that’s how the first one goes. I think it makes use of the space and all things in the cargo space fit neatly on the outside , like bags etc.
    I might add a stop bar that goes across the front edge so stuff doesn’t slide out. Ideally an adjustable sliding/lock like a truck bed set up.
    Fits the smaller Packout boxes perfectly.
