Low brake pedal
Discussion in '5th Gen 4Runners (2010-2024)' started by Oldtimerbrem, Sep 3, 2018.
  1. Sep 3, 2018 at 5:20 PM
    Oldtimerbrem
    Oldtimerbrem [OP] New Member
    George
    2015 4Runner, limited
    my gen5 has a low brake pedal, sometimes pedal will continue down while at a stop. Read many threads and cannot see similar problem. Anyone see this problem?
  2. Sep 4, 2018 at 9:05 AM
    fsroader
    fsroader New Member
    james
    E.TN.
    sounds like your master cylinder is dying.
  3. Sep 4, 2018 at 10:00 AM
    jester243
    Dan
    Spokane, WA
    is the brake light on the dash lighting up, have you checked the fluid level
  4. Sep 4, 2018 at 10:15 AM
    4X4Runner
    The left coast
    What’s been done to the 4Runner? Any recent brake work? Or, have the brakes been serviced yet? How many miles?
    I’d start small and check the fluid and bleed the brakes to see if there is air in the system. If that checks out and you’re still having the problem I’d check the pads. From there I’d take it to the dealer’s service department or to your trusted mechanic to diagnose the problem.
  5. Sep 5, 2018 at 4:57 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    it's all gas for me. :mudding: who needs brakes?
  6. Sep 6, 2018 at 7:20 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    not a problem on these 5th gen 4runners.. pedal drop is usually a leak.. also since it is 5th gen I doubt the master is bad. since your pedal does drop lower than normal you did check that the brake fluid, it is at the full mark ..
    if it is low after you last checked the fluid , then a leak.. if the fluid is normal level correct and no fluid added that could be the master .. new vehicles can have these problems if you have your vehicle serviced , as the brake fluid does get contaminated if they add the damaged fluid .. contaminated fluid does occur and the lube jocky floor sweeper can kill it..
