Low beam headlights
Discussion in '5th Gen 4Runners (2010-2024)' started by Reptilicus777, Aug 1, 2022.
  1. Aug 1, 2022 at 12:29 PM
    Reptilicus777
    Reptilicus777 [OP] New Member
    Folks
    I just joined this and read a few of the comparisons on LED/HID/Halogen and I have tried LED and they just don’t project but are bright for the first ~20’ but suck otherwise. These are Seallight ones that I bought on Amazon.
    I am looking for some insight on what the best route to go is given the issue with the LED’s and the stock deflection housing that is designed for halogen lights. What is the brightest and most like an LED output (so I can leave the high beam and fog light LED since they’re fine)? Thoughts? I just want a really bright nighttime light for the low beam that doesn’t make the LED fog lights look odd with them.
    Thanks
  2. Aug 1, 2022 at 12:34 PM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    search "headlights" or "LED headlights" in this forum. TONS of info, links, good and bad buys, etc.
  3. Aug 1, 2022 at 2:39 PM
    2000Sport
    2000Sport New Member
    HUDSON VALLEY NY
    OG Gen 5 2013 Trail ~Classic Silver ~ KDSS
    I replaced the halogens low beams in my 2013 TE with DDM Tuning Saber 55W ProX Accu V2 and I can attest that these lights have WAY out performed the OEM halogens in terms of brightness, and they are well focused, with a clean top cutoff. These aim well up the road , and I recommend them highly.
  4. Aug 1, 2022 at 2:44 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Don’t waste your time experimenting with drop-in LED bulbs in your halogen housings.
    Try the H9 bulb conversion first. It’s easy, inexpensive, and reliable. If that isn’t enough light for you the best bet is to get all new Toyota LED headlights.
    H9:
    https://www.4runners.com/threads/h9-in-h11-headlight-sockets.8593/page-4#post-177309
    Toyota LED Headlights:
    (there are other threads also):
    https://www.4runners.com/threads/oe...on-adapters-for-14-20-halogen-4runners.25899/
  5. Aug 1, 2022 at 2:56 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Xenon depot kit for the win
    DIRTRCR13 likes this.
  6. Aug 1, 2022 at 3:29 PM
    This^
    suaveflooder likes this.
  7. Aug 1, 2022 at 3:31 PM
    Oh, and welcome to the forum! :wave:
  8. Aug 1, 2022 at 5:53 PM
    Henry J
    Sacramento Ca
    No joke, I did this and holy crap! I have zero interest in swapping out or dropping $1k+ for new headlight assembly
  9. Aug 1, 2022 at 5:56 PM
    Yes!
    I had the brightest H11's I could find, and the cheapo H9's I picked up have better output. I will recommend it to anyone who asks.
    jmkulbeth and ElectroBoy like this.
  10. Aug 1, 2022 at 6:30 PM
    lunar_t4r
    lunar_t4r New Member
    2022 Lunar Rock ORP
    H9 bulb is the best bang for buck upgrade you can do. Hid/led in halogen housing merely give you an illusion as it dumps most of the light in the foreground. Too much foreground lighting also makes it harder for you to see down the road. Win win with h9.
    Too Stroked and Thatbassguy like this.
  11. Aug 1, 2022 at 6:41 PM
    Which is the brightest h11 you had? (Serious question, not sarcastic question)
    I had xtreme vision halogen h11s but LEDs like GTR Ultra2 and nilight were very bright and they taking less current never look back on halogens.
  12. Aug 1, 2022 at 7:05 PM
    I was gonna suggest trying the Sylvania higher output H11’s but sounds like that’s already been tried. We use them in the Sequoia and they work well. But brighter bulbs usually have a shorter life.
  13. Aug 1, 2022 at 8:07 PM
    Actually, I misspoke.
    I bought the brightest high beams, the Osram Nightbreaker unlimited. The headlights are the Nightbreaker Lasers, so they're not quite as bright.
    But even if the unlimited were brighter than the H9, an upgraded H9 would be brighter still.
    I have used Sylvania bulbs in the past with good results. I can't recall how I found out about the Osrams.
    kmeeg[QUOTED] likes this.
  14. Aug 2, 2022 at 1:05 AM
    Mirroring the previous comments, don't waste your time with LEDs in the stock housings. The links they already provided have the best/worst comparison. These sideways projector housings suck. And plenty of YouTube vids on it too.
    After researching, i just upgraded the whole headlight assembly.
