Low beam Headlight and Tail light not working.
Discussion in '5th Gen 4Runners (2010-2024)' started by akki445, May 3, 2025 at 8:26 PM.
  1. May 3, 2025 at 8:26 PM
    akki445
    akki445 [OP] New Member
    Akhil
    2020 Trd off road
    Hi Folks,
    Noticed that my low beam headlight and tail light both are not working. I already checked the fuses and all the fuse looks good. I haven't checked the relay yet just as I am not sure which one to pop off. But anybody recently had this issue ? Any help is appreciated
  2. May 3, 2025 at 9:07 PM
    Was there any previous maintenance or modifications?
  3. May 4, 2025 at 3:58 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Have you checked the bulbs?
  4. May 4, 2025 at 4:00 AM
    akki445
    Akhil
    2020 Trd off road
    There was no modification done on headlights
    I have raptor lights hooked on to my high beam and it works fine. The bulb doesn't looked cooked
  5. May 4, 2025 at 5:08 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Just because a bulb "looks good" doesn't mean it isn't bad. A continuity test or swapping in a new bulb will tell for sure. Always go for the simplest fix first.
  6. May 4, 2025 at 5:24 AM
    How soon after you hooked up the raptor lights did you start having issues?
    I agree with @Too Stroked stick with the easiest answers first. Re-check the bulb(s) and all fuses. Look closely at the fuses to see if one is blown. Maybe remove/unplug the raptor lights and see if that fixes it. Raptor lights have been known to cause a lot of issues if they are hooked up improperly or if they short out.
  7. May 4, 2025 at 7:11 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    You're having lighting problems. This is the kind of information you need to lead with. :facepalm: Disconnect them and see if it fixes the problem.
