Loud vibration in the rear end when going over 50 mph
Discussion in '3rd Gen 4Runners (1996-2002)' started by Durelly69, Sep 9, 2021.
  1. Sep 9, 2021 at 10:18 PM
    Durelly69
    Durelly69 [OP] New Member
    Russell
    3rd gen 96 4runner 2WD
    Flowmaster,Bilstien front shocks
    3rd gen 96 4runner, I'm getting a loud vibration past 50 in the rear end and it's riding rough also when going from park to drive i get a clunking
  2. Sep 9, 2021 at 11:45 PM
    dricko
    dricko New Member
    Derick W.
    About the vibration, try to rotate the tires first.
    canadian.bacon likes this.
  3. Sep 10, 2021 at 1:14 AM
    Durelly69
    Russell
    I'll start with that first and go from there ill post update
  4. Sep 10, 2021 at 5:40 AM
    Welcome!
  5. Sep 10, 2021 at 6:02 AM
    A clunk sounds like a bad U-Joint which would potentially also be the source of the vibration.
  6. Sep 10, 2021 at 6:23 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    +1
  7. Sep 10, 2021 at 12:02 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    +2
    Pat☺
  8. Sep 15, 2021 at 11:56 AM
    Durelly69
    Russell
    Rotated tires and now I'm getting a lot of vibration when I let off the gas above 40 50
  9. Sep 15, 2021 at 11:57 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    That's classic wheel balance. You could have thrown weights, but the steady banging is odd.
  10. Sep 15, 2021 at 1:09 PM
    Probably 2 issues. Get the tires/wheels balanced first. Take it to a good tire shop and they should be able to locate the clunk for you too.
  11. Sep 16, 2021 at 2:43 AM
    +3
  12. Sep 17, 2021 at 10:44 PM
    Durelly69
    Russell
    Got tires rotated and balanced, it fixed the vibration going past 50 but now it does it really bad when I let off the gas
  13. Sep 18, 2021 at 2:02 PM
    When you let off the gas, the drive train is no longer tensioned and it vibrates because somewhere something is loose. Most commonly it is a u-joint. Especially if you have a clunk when shifting into drive or from drive to reverse.
    PhantomTweak and jmkulbeth like this.
  14. Sep 22, 2021 at 11:40 AM
    Durelly69
    Russell
    Would a bad u-joint cause it to vibrate really bad when letting off the gas but stops when I get back on gas?
  15. Sep 22, 2021 at 11:43 AM
    Of course. You are applying tension to all parts of the drive train now and things aren't loose.
  16. Sep 22, 2021 at 11:45 AM
    Durelly69
    Russell
    Also is it bad to drive with a bad ujoint
  17. Sep 22, 2021 at 11:50 AM
    Durelly69
    Russell
    When changing the u joint is there anything else that I should change out? This is my first rwd vehicle so I'm kinda new to all this
  18. Sep 22, 2021 at 11:50 AM
    If the rear ujoint lets go, and the rear of the driveshaft drops...there should be no real damage as you will be dragging the end of the driveshaft on the pavement.
    If the front of the driveshaft drops down, it drops to the road and acts as a pole vault. Not sure if it will flip a 4Runner, but I've heard of stories of catastrophe in other cars.
    You need the drive line inspected if you don't know what you are looking for. Get an estimate and just do the repair yourself if you think you can do it (it's usually not too hard).
  19. Sep 22, 2021 at 1:18 PM
    Durelly69
    Russell
    I appreciate it,thank you this forum has been so helpful. Is there a write up on how to change out the u joint, I've never done one before
  20. Sep 23, 2021 at 6:25 AM
    Youtube has lots of 3rd gen videos from Timmy the Toolman. Check there, I am sure he shows how to do it.
    It sounds like it is a ujoint but may not be it. Diagnose it if you can or have a shop do it.
