Loud Beeping
Discussion in '5th Gen 4Runners (2010-2024)' started by Blaze1969, Aug 1, 2024.
  1. Aug 1, 2024 at 1:47 PM
    Blaze1969
    Blaze1969 [OP] New Member
    Vince
    2024 4Runner Limited
    None
    Hello,
    I recently purchased a 2024 4Runner Limited, and I LOVE IT! I don't understand why I waited years to get one...
    The main issue I am having, honestly I have no idea why it does this, but when I am driving at freeway speed for at least 20-30 minutes, there is a loud beeping noise from the dash. It beeps 5 times, pauses, then 5 more beeps and then stops. Nothing lights up on the dash, no warning lights or anything letting me know why. It's so random, it happened 4 times so far. I've owned this new since April 2024. Any ideas or suggestions would be appreciate. It is the weirdest thing I've run into.
  2. Aug 1, 2024 at 2:09 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Think back. Did it maybe happen when you had something in the passenger seat that wasn't quite as heavy as a human, but maybe 20-25lbs or so? Groceries, maybe a case or two of sodas? If that is the case, what you're probably hearing is a seat belt warning. When you hit a slight bump in the road, it created just enough force for that 20lb sack of groceries to become 40lbs of down force momentarily. The warning sounded, the pressure was released and no further warning happened. Fast forward 2 weeks until the same convergence of events occurred and there's your warning again.
    We had this exact situation on our 22 Limited (our 21 Venture didn't do it).
    Workaround: And.... I'm not suggesting that you do this (totally up to you), but FYI - the audio portion of the seatbelt warning can be disabled with an OBD2 manager like Carista. Again, I am not suggesting that you disable a seat belt warning (that's up to you), but when this happens audio will not be triggered. The red seatbelt visual warning light on the panel cannot be bypassed with an OBD2 manager and will still trigger.
    Good luck.
    steelevo likes this.
  3. Aug 1, 2024 at 2:18 PM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Yep - what @Texoma-Brad suggested has also happened to me because my laptop bag is heavy as hell.
    TimG
  4. Aug 1, 2024 at 2:23 PM
    Blaze1969
    Vince
    None
    Hey Brad...
    I had a full grown adult sitting in the passenger side seat during each time it happened. It's definitely not a seatbelt waring light or malfunction. It's just some random, weird noise. I wish I could do a video, but it happens when you don't expect it. As mentioned, this only happens after I've been on the road for at least 20-30 minutes. I've checked everything, except the Sway Warning which doesn't seem to do much anyway.
  5. Aug 1, 2024 at 2:32 PM
    Is it the Awake Warning?
  6. Aug 1, 2024 at 2:34 PM
    Blaze1969
    Vince
    None
    Not sure... I'm always awake with both hands on the wheel.
    4scooter19 likes this.
  7. Aug 1, 2024 at 2:39 PM
    TPMS reaction time is 20 minutes if a sensor is going bad, but as far as I know you just get the amber tire pressure light and no beeping.
    Dash cam?
    Dealer installed tracker? Is the OBD2 plug in its OEM bracket? Follow the wires up with a mirror and flashlight, do you see a breakout cable?
  8. Aug 1, 2024 at 2:43 PM
    I think there is rest reminder you can adjust in the gauge cluster screen. However, you should see a coffee cup symbol when the alert happens.
    Whammo and Saker like this.
  9. Aug 1, 2024 at 2:44 PM
    Blaze1969
    Vince
    None
    I hope I don't have a dealer installed tracker! I paid cash for this, so it better not have a tracker! Yikes. The only thing I plugged into the OBD2 port is the Banks Pedal Monster. This noise was happening before I added it. FYI, get one if you don't have one! What a huge difference it makes with holding shift points better. Worth it!!!
    Sorry for getting off track, but I will do some digging this weekend and look for anything out of the ordinary.
  10. Aug 1, 2024 at 2:44 PM
    Blaze1969
    Vince
    None
    The coffe cup thing never pops up.
    Saker likes this.
  11. Aug 1, 2024 at 2:45 PM
    Blaze1969
    Vince
    None
    Even though I love this vehicle, I think it must have been made on a Friday at 4:56pm! Lol
  12. Aug 1, 2024 at 2:52 PM
    Some dealers install a tracker before any customer ever sees the vehicle, regardless of financing situation. Since it isn't a Toyota accessory, the work is usually farmed out to a cut-rate stereo shop. The dealer typically doesn't pay a tech to remove it if you pay cash.
  13. Aug 1, 2024 at 3:05 PM
    Blaze1969
    Vince
    None
    I will see then... I actually have an appointment to drop it off for my 1st oil change, I'll ask them while I am there. Thanks for the suggestions.
  14. Aug 1, 2024 at 3:25 PM
    Trundle
    Trundle Lapsed Lurker
    2023 TRD ORP Barcelona Red
    My first guess was the lane departure warning, but I'm pretty sure that gives a visual indication too.
  15. Aug 1, 2024 at 3:32 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    The visual is only in the outside mirror though. The warning beep can be set to silent.
  16. Aug 1, 2024 at 3:39 PM
    Yes and the driver can turn off LDA. In my Tacoma I turn it off in day to day driving, only enabling it in long drives where I might doze.
    You're thinking blind spot monitoring?
  17. Aug 1, 2024 at 3:56 PM
    We can all guess at what the noise is, but without a video that's all we can offer....random ass guesses. Take a video please and post it in this thread.
    Saker and Rocko9999 like this.
  18. Aug 1, 2024 at 4:03 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    What Borracho said. But, if you can get us a video, it’d be a lot easier. Take it by the dealership have them put an OBD2 reader on it and see if it threw a code when it happened. Probably didn’t, but worth a try and they won’t charge since it’s under warranty.
  19. Aug 1, 2024 at 4:18 PM
    steelevo
    Utah
    I second this. Try turning off the lane departure and see if it's still giving you the beep. If the sensitivity is set too high, it will give false alerts.
  20. Aug 2, 2024 at 7:55 AM
    Adventure51
    Adventure51 New Member
    2022 TRD Pro
    Prinsu Roof Rack, 2” lift, mudflap delete
    My new to me 2022 TRD Pro does the same random beeping pattern as yours but only just after startup. Transmission still in park. It doesn’t do it very often. Only happened a few times so far. The only thing I can think is it’s the dash cam. And it’s not a factory sounding beep. I’m pretty sure it’s the dash cam but I don’t know why yet.
  21. Aug 2, 2024 at 8:24 AM
    TimGinCentralNJ
    Tim
    This actually was happening to me while I was trying to take delivery of my new '24 Limited. Turned out of he nonstop beeping was because the memory card had not been installed in the camera; once installed, it stopped. Now it will been when you do thinks like slam your door too hard or bump the camera itself. Bottom line, check out the owners manual for the camera...theres a lot of helpful info in there about why the damn thing beeps so much.
    Tim G
    3JOH22A and Adventure51[QUOTED] like this.
  22. May 13, 2025 at 5:58 PM
    Blaze1969
    Vince
    None
    Circling back on this one... My 4Runner still does this random, out of nowhere beeping while driving. I can't be the only one on the planet who has experience this, am I?
    I've owned this 5th gen since new, about 1 year now. Only have 11,600 miles on it. Randomly its still gives me the 5 beeps, pause, then 5 more beeps. Comes from the dash. No lights on the dash either. To preface, it's been doing this since day 1. I looked at everything, took it to the dealership and they were able to duplicate it. They have no idea what it is... So I have this unresolvable issue and my stereo's bluetooth also cuts in and out (another post). One thing I noticed is that the "Red Brake Light" lights up on the dash sometimes while driving. No, I do not tailgate... Lol
    I feel like this was definitely a Friday made unit. If anyone has any ideas on what's happening to this 4Runner, please let me know. I'm about to call a lemon law attorney and get something else.
  23. May 13, 2025 at 6:18 PM
    West Coast, Sierra Mountains
    This one observation points towards a TSS malfunction, perhaps a recalibration will help.
    Blaze1969[QUOTED][OP] likes this.
  24. May 13, 2025 at 6:23 PM
    Well that’s good
  25. May 14, 2025 at 12:34 AM
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    BFG KO2, stock size RCI 20 degree sliders RCI engine/trans skids
    Mine does that when I forget to release the parking brake. Maybe a bad PB sensor?
  26. May 14, 2025 at 3:11 AM
    TimGinCentralNJ
    Tim
    Could it possibly be your dealer installed dash cam doing the beeping? I've only had this happen when I first start the truck...never while driving...but it's fairly loud and there are no warning lights or other indicators when it happens.
    I haven't had any luck getting the damn thing to connect to it's app on my phone anyway, so it's utterly useless anyway.
    TimG
    '24 Limited
    Blaze1969[OP] likes this.
  27. May 14, 2025 at 10:00 AM
    Blaze1969
    Vince
    None
    I will mention the TSS malfunction to them. Maybe that will guide them (Toyota) to look at it a little more indepth. Thanks for the feedback.
  28. May 14, 2025 at 11:32 AM
    Lol Friday made. What do you think this is, 1965? The plant runs three shifts 7 days a week. (As I understand they are over capacity and had to contract a portion of Land Cruiser assembly to a Hino plant.) Yours is probably made on graveyard shift on a Saturday :p
