Loss of power after changing water pump
Discussion in '2nd Gen 4Runners (1990-1995)' started by jenegirl4ever, Mar 28, 2021.
  1. Mar 28, 2021 at 10:26 PM
    jenegirl4ever
    jenegirl4ever [OP] New Member
    jennifer
    90 yota
    so had to change water pump in my yota. now it has a major loss of power.....help.
    it idles beautifully sooooo... also starts to ping and sometimes gets hot..
  2. Mar 28, 2021 at 10:45 PM
    Mtbpsych
    Mtbpsych New Member
    More info would be helpful. Under what conditions is there a loss? When does it get hot? Every time you’re driving or only under certain conditions? 4 cylinder, v6? I think on the v6 the timing belt comes off. I would suspect maybe you didn’t have the engine set to TDC before taking off the belt and that’s what’s causing your loss of power. As far as the over heating issue, did you replace your thermostat? It could be stuck and not opening.
  3. Mar 28, 2021 at 11:14 PM
    jenegirl4ever
    jennifer
    90 yota
    6 cyl. and only once in a while does it get hot.
  4. Mar 28, 2021 at 11:17 PM
    jenegirl4ever
    jennifer
    90 yota
    loss of power everytime i drive her. pinging.
    i can barely make it out my driveway
  5. Mar 29, 2021 at 4:45 AM
    Mtbpsych
    Mtbpsych New Member
    Check your timing.
  6. Mar 29, 2021 at 7:10 PM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    Definitely check your timing. Pinging could be a sign that the timing is too advanced. You should always check ignition timing after doing anything related to the timing belt. If timing is ok I would see if you have a plugged exhaust. A plugged exhaust will cause your truck to run lean which will make it ping, over heat, and have no power. One way to check for a plugged exhaust is to pull the upstream oxygen sensor (sensor before the catalytic converter) out, drive it, and see if it has power.
  7. Mar 30, 2021 at 9:27 AM
    jenegirl4ever
    jennifer
    90 yota
    so if i was say sgupid when it comes to timing how would you explsin to a dummy how to time her rig
  8. Mar 30, 2021 at 11:46 AM
    Dezman92
    Dezman92 New Member
    Doug
    Norcal
    1994 Green 4runner
    Jump the diagnostic connector, terminals te1 and e1 with a paper clip, start the truck, make sure engine light is flashing, connect the timing light to the battery and the pickup to the wire for the number 1 cylinder. Spec is 10 degrees BTDC. There should be mark on the pulley and timing cover. Loosen distributor bolts and turn distributor until the mark on the pulley lines up with the 10 mark on the cover. If you can’t get the marks to line up pull off the timing cover and see if the cams will line up with the marks
  9. Mar 30, 2021 at 4:03 PM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    First don’t drink and work on your truck, LOL. Then try Google and YouTube. Tons of info on the subject & videos too .
  10. Apr 2, 2021 at 5:46 PM
    blueosprey90
    blueosprey90 New Member
    I'm new to having a 4runner - just a few weeks.
    But didn't you need to remove the timing belt to change the water pump? If so, your cam timing may be off. I think that could explain loss of power and quite possibly the pinging - especially if you didn't touch ignition timing to replace the pump.
    Running hot might also be explained with bad cam timing in that the exhaust valves are not opening at the proper time.
    Take my advice with two grains of salt, but that's my guess.
    mjamgb and captsolo like this.
  11. Apr 3, 2021 at 10:58 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    I'm on the OEM water pump that came with my 2005 4runner. I have new spares for various parts because the car is in the Bahamas and there is only one parts place and dealer for parts here and the prices can be astronomical, or not in stock.
    OEM alternator, exhaust, radiator. Amazing Toyota cars and trucks they build.
    Last week I had a new evaporator core put in, and a few years ago the AC compressor was replaced. Freezing cold right now - as we head into the hot, hot Bahamian summer sun.
    Amazon.com: Denso 476-0040 A/C Evaporator Core: Automotive
    This is the second evaporator core that has been replaced. The original that came with my new 4runner failed in 4 years.
    Part was $90 at Amazon.
