Looking at 99 4runner. pretty clean , dealer wants $9995.
Discussion in '3rd Gen 4Runners (1996-2002)' started by kurtzoellner, Mar 1, 2023.
  1. Mar 1, 2023 at 6:54 AM
    kurtzoellner
    kurtzoellner [OP] New Member
    Kurt
    Snowflake AZ
    99 Rav- 99 4runner
    Pretty stinky now after alot of dead animals.
    I've been looking a few years for a clean 98-99-2000 4 runner SR5. Im picky. found a 99 w 250K miles, manual. Pretty clean, straight, 1 owner from Az , drives great, sounds great. Car fax only shows service records up to 137K . Im concerned about timing belt ? Meaning no records , no info besides regular service at dealer. Any clues on how to tell if replaced? Engine has been detailed. I mean super clean , inside and out.
  2. Mar 1, 2023 at 10:36 AM
    roboturner
    roboturner Dead Eyed
    ‘98 NW 3.4L 5MT SR5 | '18 6MT DCSB Tacoma
    If it's been changed recently, you should be able to find a sticker with date and mileage, usually on the airbox or close to it. If it hasn't it's not a particularly hard DIY job. I'd definitely climb under the truck and tap around with a hammer on the frame though. That's the secret killer on these things, look for crusty bits, also check each of the weep holes, they tend to rot from inside out, and will begin what looks like delamination around those holes if there's an issue brewing.
    Malinois38 likes this.
  3. Mar 2, 2023 at 4:20 PM
    Ahdofu
    Ahdofu New Member
    Matt
    10K sounds like a fair price for a 99 and even if it is a dealer that is selling it, there must still be some wiggle room there. With an AZ car I don't expect to see any rust underneath but there should be corrosion spots on the exhaust system. Hopefully everything is still intact and no holes. If maintenance after 137K is unknown, you'll have to assume that timing belt and water pump will need to be replaced. It is a non-interference engine so that aspect gives you some time to do the repairs. Before you purchase the car though, I suggest that you have someone check the condition of the plugs (telltale sign of oil burning) and also perform a compression test on all the cylinders.
  4. Mar 2, 2023 at 4:31 PM
    Superdave1.0
    Superdave1.0 New Member
    LX470
    If 2wd that's way overpriced. 4x4 it's still on the upper end.
    250k miles be prepared to spend money on mechanical items. It may look clean, but I guarantee you it will need something.
    Timing belt is one of those things that if you don't know when it was last done, you better just get it done.
  5. Mar 6, 2023 at 7:47 AM
    kurtzoellner
    Kurt
    Snowflake AZ
    99 Rav- 99 4runner
    New owner of 99 SR5. Great condition. Found timing belt RR sticker . Thanks for advise on where to look. Replaced 249K. Good news. No rust. Damn clean. Took it and twisted it, up-down, reverse , 4 H -4 L all tight. Salesman was cool . I told him to hold on,60mph on wash board. It is tight , no noise , no vibrations , shifts(manuel) great. I'm impressed. Quietest 4x4 I've owned. $7200.00. Thanks for comment's. 1 owner , looks like back was never used not even back seat, crazy Weather guard customs , even full size in cargo space. Wish me luck.
  6. Mar 6, 2023 at 1:36 PM
    1st things to check closely are the lower ball joints.
  7. Mar 6, 2023 at 1:57 PM
    Ironguy New Member
    Welcome from BZB!
  8. Mar 6, 2023 at 5:59 PM
    Malinois38
    Malinois38 New Member
    Pa
    2002 SR5
    Pics or it didn’t happen…
    roboturner likes this.
  9. Mar 9, 2023 at 6:07 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    good luck with the purchase..if so, welcome..
  10. Mar 23, 2023 at 12:07 PM
    4RSCOUT
    4RSCOUT New Member
    JS
    WA
    3rd Gen 4Runner
    In-progress!
    mine has 260K. Recently replaced oil cooler seal, main seals, some interior bulbs, and had the AC serviced. Steering is a bit sloppy, alignment is good though. Runs great but just affirm the above, you will have TLC issues.
  11. Mar 29, 2023 at 9:13 AM
    SnowBunny56
    SnowBunny56 New Member
    North Texas
    1999 3rd Gen
    Toyo tires with Fuel wheels, Carhart seat covers, getting started with some suspension mods
    250k and no record of the ball joints being replaced? no question, replace them with oem joints, I've seen a couple of pics of what happens when one of them separates, it's ugly, welcome to the forums!
