Locked Up's 4Runner
Discussion in '4th Gen Builds (2003-2009)' started by lockedup, May 23, 2024.
  1. May 23, 2024 at 12:06 PM
    lockedup
    lockedup [OP] Old member
    2003 V8 4WD Limited with 2.5" Lift and 31s
    Build highlights as of 3/31/2025
    2003
    Part Time 4WD (Manual T-case swap)
    V8
    Limited
    LB42 Leather
    216,000 miles
    Dobinsons 1-3.5" IMS Coilovers (+100lbs/black)
    Dobinsons C59-325 coils (black)
    Dobinsons IMS59-50701 Shocks
    1/2" Body Lift
    Extended brake lines
    265/70 R16 Cooper Discover S/T
    XD Hoss 16" Wheels
    Current pic:
    I picked this up back in December '23 and have already put a chunk into it ....
    Motor has plenty of power and it drives nice and straight.
    Dealer said "The PO said they did timing belt and water pump" ... but no sticker so I had it redone.
    Known issues are the 4wd actuator, passenger side air mix servo and rear main seal.
    Plans:
    Fix EVERYTHING noted above.
    The front seems a little stiff so may investigate swapping something else in.
    There are dents and dings that I am going to try to correct or at least minimize.
    Might repaint/recolor it as well.... the black is sexy and all but it's hawt here in TX.
    If I don't do a color change I might just do a white roof to reflect that sun!
    If I keep the black I may look for some of the newer Limited wheels.
    I generally like black wheels on white/silver vehicles and shiny metal on black/dark blue.
    I will need to refurbish headlights so I may crack them open and convert to something brighter.
    Grill needs some love. Emblems were plasti-dipped. Not sure if I like it.
    On the inside I also want to replace the dash so will probably do a coverlay unless I find a nice one at the 'yard.
    I am also going to look at replacement carpet, refurbishing the leather and some new floor mats.
    Audio is the JBL system but I want something more modern.
    I will investigate swapping that out for something touch screen assuming I can keep the steering wheel controls.
    May remove the running boards and relocate the lights in them to under the body. We will see if they are necessary for the wife. lol
    All information here is cross posted over here: Just in case ;)
    Photon_Chaser, BassAckwards and Bob like this.
  2. May 23, 2024 at 12:07 PM
    lockedup
    Going to use this post as my maintenance log.
    1/8/24
    215,473 Miles
    OEM AC Condenser - 1/13/24
    215,473
    OEM B2 S1 O2 Sensor - (8946560150) Tom Wood Toyota
    OEM Coil Pack - (90919-02230) Tom Wood Toyota
    1/30/24
    215,473
    Detroit Pass front Wheel Bearing - Amazon
    Denso Coil Packs - (6731303) Rock Auto x7
    2/7/24
    215,495
    OEM Radiator Shroud - OEM Fan Clutch - (1621050090) Tom Wood Toyota
    OEM Fuel Tube Clamp - OEM Fuel Tube Clamp - 2/12/24
    215,501
    New Spare tire changing tools
    Amazon
    3/2/24
    215,511
    Cleaned Sun Roof Drains
    OEM Relay Block Cover - (82663-35090) Toyota Parts Deal
    OEM B1 S1 O2 Sensor - (8946560150) Tom Wood Toyota
    OEM PCV Valve - (12204-50030) Toyota Parts Deal
    OEM Gas Cap - (77300-47010) Toyota Parts Deal
    OEM PCV Hose - (12261-50060) Toyota Parts Deal
    OEM PCV Hose - (12261-50050) Toyota Parts Deal
    3/11/24
    215,520
    OEM Fuel Resistor - (23080-50130) Toyota Parts Deal
    OEM MAF Sensor - (22204-75020) Toyota Parts Deal
    OEM Vapor Hose - (23829-50070) Toyota Parts Deal
    OEM Vapor Hose - (23820-50140) Toyota Parts Deal
    OEM Thermistor - (88790-22131) Toyota Parts Deal
    Battery Duralast Gold 27F-DLG - AutoZone
    3/21/24
    215,532
    Bearden Automotive. They use OE parts and for this they used the ASIN kit.
    B2 S1 O2 Sensor Ground fix
    Timing Belt Idler
    Cam Seal x2
    Crank Seal
    Timing belt
    Water Pump
    Idler lower Timing
    Coolant
    FIPG Sealer
    Thermostat Gasket
    O-Ring Bypass
    Inlet O-ring
    Thermostat
    Tension Adjuster Timing
    P/S Hose 3/8
    P/S Feed Hose
    Power Steering Fluid
    Oil Pickup Gasket
    Oil Pumo/RM Housing O-Ring
    Oil Pump
    Tensioner Accessory Belt
    Harmonic balancer
    Alternator
    Cooling Bracket Assembly
    3/27/24
    215,600
    Passed Inspection
    4/8/24
    215,674
    Lubed front & rear driveshafts (slips & u-joints)
    5/13/24
    215,690
    Krawltex Motorsports
    Installed SafeTcap Frame Repairs 200,201 & 202 on both sides
    5/22/24
    215706
    Bearden Automotive.
    New Radiator & Cap
    7/27/24
    216,116
    OEM Fuel Cap - Toyota Parts Deal
    8/8/24
    216,253
    OEM Purge Valve - Amayama
    8/9/2024
    216,253
    Powerstop Front Pads & Rotors - Amazon
    Powerstop Rear Pads & Rotors - Amazon
    VastAuto Hub Grease Caps - Amazon
    Detroit Driver Front Wheel Bearing - Amazon
    Geometry Correction UCAs - SuperPro
    LCA Kit - SuperPro
    Sway bar Drop - Amazon
    Dobinsons 1-3.5" IMS Coilovers (+100lbs/black) - Exit Offroad
    Dobinsons C59-675V Variable Long travel coils (black) - Exit Offroad
    Dobinsons IMS59-50701 Shocks - Exit Offroad
    Extended Stainless Kevlar Teflon (maybe some Unobtanium too) Brake lines Front & Rear (smoked black) - YotaMafia
    OEM 5th Gen CV Axles (43430-60082) - OEM Differential Mounts lower x2 - Partsourq
    OEM Differential Mounts upper x2 - Partsourq
    OEM Support assy front diff (5238060012) - Partsourq
    OEM Support assy front diff (5238060021) - Partsourq
    Alignment and install of above parts - Krawltex Motorsports
    12/05/24
    216,565
    Dobinsons C59-325 Rear Coils - Exit Offroad
    Install rear coils & front coil over adjustment - Round2 Offroad
    Alignment - Precision Tune Auto Care
    2/28/25
    216,695
    Fixed rear sunroof drain
    Manual T-case swapped
    Rear main seal
    OEM Oil Seal (9031138083) - Amayama
    OEM Transmission Mount (1237150150) - Amayama
    Tom Woods Drive Shaft - Tom Woods
    --Front 31 7/8" Flange to Flange
    --Rear 47 1/4" Flange to Flange
    1/2" Body Lift - Etsy
    OEM Body mount bushings & hardware:
    Bolt Body Mounting (5221735180) - Amayama
    Bolt body Mounting (5221735191) - Amayama
    Bush(9044018011) - Amayama
    Holder Cab Mount Cushion No 1(9044031002) - Amayama
    CUSHION SUB-ASSY, CAB MOUNTING, NO.1 LOWER (5220235090) - Amayama
    CUSHION SUB-ASSY, CAB MOUNTING, NO.2 LOWER (5220435120) - Amayama
    CUSHION SUB-ASSY, CAB MOUNTING, NO.3 LOWER (5220635040) - Amayama
    CUSHION SUB-ASSY, CAB MOUNTING, NO.4 LOWER (5220835050) - Amayama
    STOPPER, CAB MOUNTING CUSHION (9020112078) - Amayama
    NUT(FOR REAR SPRING U BOLT) (9418801201) - Amayama
    CUSHIION SUB-ASSY, CAB MOUNTING, NO.1 UPPER (5220135100) - Partsourq
    CUSHION SUB-ASSY, CAB MOUNTING, NO.2 (5220335210) - Partsourq
    CUSHIION SUB-ASSY, CAB MOUNTING, NO.3 UPPER (5220535160) - Partsourq
    CUSHION SUB-ASSY, CAB MOUNTING, NO.4 UPPER (5220735050) - Partsourq
    Install of above parts by - Krawltex Motorsports
    3/18/25
    Passed Annual Inspection
    3/19/25
    OEM Radiator Cover (53292-35010) - Ebay
    Wheel Well engine bay Covers - Ebay
    3/21/25
    Seat Skins - Amazon
    Coverlay Dash Cover - Coverlay
    Cleanup on aisle 3
    3/22/25
    USB Port - Amazon
    3/23/25
    Subwoofer replacement - Amazon
    More cleaning
    3/24/25
    216,730
    Shift boot - Amazon
    Black Center caps - Amazon
    3/29/25
    Removed Rear Shelf
  3. May 23, 2024 at 12:27 PM
    lockedup
    I am working a little backwards on this thread because I had started my log elsewhere. So some of these pictures will predate this thread but here goes....
    1/13/24
    Today's plans were a new coil pack, new fan clutch, new wheel bearing and new 02 sensor...
    I started with the 02 sensor and with the right tool, that was pretty easy.
    Access was easy for me since it's lifted and there isn't wheel well liner there.
    I highly recommend this tool if you are doing an O2 sensor:
    O2 Sensor Socket on Amazon
    Then I started with the coil pack and since I was in there, I checked them all.
    Access is very easy on the driver side:
    Passenger side requires removal of the air filter housing:
    I knew one was cracked but didn't know ALL of them were cracked.
    Ugh.
    I had help when it was time for the fan clutch and we were able to get it apart and out by pulling the fan shroud at the same time.
    Didn't have to take any hoses off!
    Unfortunately, it looks like the PO cross threaded one of the studs so it had to come out:
    New one on order.
    Ugh!
    Thankfully since it was out and getting late-ish, we decided to not do the bearing today. That led us to discover some questionable wire routing, which we temp solved with bright ass zip ties. Bright so that I will notice them and they will irritate me so I will order the proper clips! lol
    I also noticed a few missing nuts & bolts.
    Hoping to get to the parts yard soon to find a few of these:
    Also, while sitting under the frame checking things out ... I noticed there is something missing.
    What is supposed to go in these clips (driverside):
  4. May 23, 2024 at 12:28 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Keep the pics coming, we love pics!
    Keep up the good work…
    lockedup[OP] likes this.
  5. May 23, 2024 at 12:33 PM
    lockedup
    Thanks.
    I will have to find a way to resize those pics. I thought I hit "thumbnail" but they seem to be pretty big.
  6. May 23, 2024 at 12:34 PM
    lockedup
    1-21-24
    Scored a few smaller items at the 'yard because the two 4Runners there were picked pretty clean!
    Found hood release & cover, lumbar assembly, 1 fuel/evap clip, fan clutch stud and a bunch of misc clamps nuts & bolts. The hardware is to replace a few things I have but that aren't in great shape.
    Couldn't find the radiator cover, radiator shroud nuts & bolts, spare tire tools and one fuel/evap clip. Hope I can find those elsewhere.
  7. May 23, 2024 at 12:36 PM
    lockedup
    1/30/24
    Well the hood latch assembly has some sort of sensor built into it. Must be a limited thing. No way to remove the sensor from mine and add it to the new one without breaking them apart. I was only swapping it out to clean things up a little, so I ended up wire wheeling it and hitting it with some paint.
    The larger project I got done was the wheel bearing which went really smoothly. I did see that the PO had replaced this before because they poked a hole in the disc shaped cover trying to get it off. So I massaged it back to close the hole as much as I could and slopped some RTV on the hole. Meh.
    We also swapped in all new coil packs to match the one I had done a few weeks ago. So it should purr like a kitten now.
    I also removed the plastidip from the V8 Emblem.
    I'm not a chrome fan but the total black murdered out look isn't me either.
    Waiting on some replacement hardware to put the new radiator shroud, new belt and new fan clutch in.
  8. May 23, 2024 at 12:38 PM
    lockedup
    2/7/24
    Got a new engine cover in place.
    I know it does nothing but I like the look!
    Also replaced a few small brackets that hold evap lines on the driver side.
    Got a few more to find part numbers on and swap out.
    Including replacing those bright yellow zip ties with the proper clips!
    Also got the new fan clutch & shroud in.
    PO had said it ran a little hot on long trips. I have not experienced that but also it's winter and I have not driven far.
    I'm wondering if it has/had to do with the aftermarket radiator or cap? Maybe it had to do with the AC Condensor leaking (as in maybe it was running constantly?). That was changed out so I guess time will tell. Considering going back to OEM for the Radiator & cap and doing the thermostat with it. Just to be sure.
    Currently looking for a mild water leak. It had rained a TON here and I suspect it was a sunroof drain. Should get that sorted out in the next week.
    Also doing a power steering flush and checking the hoses out.
    Then it's on to taking care of the 2 spots of bad frame on the passenger side and sorting out the leaky actuator.
    After that I will do timing belt, water pump and thermostat. Need to do something with the dash, the CV boots and I want some aftermarket UCAs. Thinking I like the look of the Dirt King with the Ball Joints. Also need to scope out a rear Track bar bracket.
    It's coming together!
  9. May 23, 2024 at 12:47 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    Glad to see you getting her back in shape. She looks good. Memorial Day may be a good time to look at suspension options since you mentioned it.
    I have a 2004 v8 Limited 4x4 with 248k and have sort of gone through a lot of what you have, replacing bits here and there getting mine back to tip top shape. I've spent more than what I paid for it so far - so there's that, lol.
  10. May 23, 2024 at 12:53 PM
    lockedup
    3/2/24
    I got both front sunroof drains cleared.
    It has rained since then and I didn't find any wet spots so I think I'm good there.
    Somehow the PO had cracked the fuse box cover/base.
    So that got replaced as well.
    I'm now trying to track down a Bank 2 Lean condition (P0174).
    I also replaced the driver side O2 sensor ... so both fronts are new.
    (Side note, thread chaser is < thread tap. Just FYI)
    I have the rear sensors too but have not put them in.
    Cleaned the MAF.
    Also replaced the PCV valve, PCV hoses and a few misc bits of hardware and clips.
    I'm thinking it might be a vac leak since I did replace a few brackets under the hood.
    Maybe I popped off a hose or bumped a brittle one?
    That or a fuel injector.
    Ugh.
    Time to bust out the smoke tester I guess.
  11. May 23, 2024 at 12:54 PM
    lockedup
    3/3/24
    Did a smoke test today and couldn't find any major leaks.... but I did find a few Evap hoses that need some love, so those are getting replaced.
    During the smoke test I did see the slightest amount , and I mean super slight, coming out from near the TB/Intake connection. I tightened that up and noticed the intake housing is looking a little ragged. Might order a new one to be safe.
    I also noticed that the fuel line to the passenger side must have had a leak at some point and the PO patched it.
    You can see it in the back of this pic (please ignore the missing evap lines). That would technically be going to "Bank 2" so I might replace it when I do the injectors if I can figure out the part
  12. May 23, 2024 at 12:55 PM
    lockedup
    3/21/24
    Had to go out of town and I need an inspection before the end of the month. So I had to drop it off at a shop.
    Of course the battery was dead so dropped in a new 27F-DLG because it has more CCA.
    Anyway, glad I brought it to the shop because I was about to try to change the injectors to solve my P0174.
    Turns out it was a broken ground wire to the O2 sensor. They repaired the break and no CEL now.
    While it was there I had them do a bunch of stuff so that I can get some miles on it before inspection.
    Needed a Timing belt service so I told them to change out pretty much everything "while they were in there"...
    Belts, Cam & Crank Seals, Idler, Adjusters, tensioners, Thermostat, water & oil pumps, Harmonic balancer, Alternator
    & Cooling Assembly Bracket.
    Also needed 2 power steering hoses.
    Don't ask how much it all was.... but it runs like a champ now.
    After it passes inspection.... next up will be to address the spots in the frame which I am planning on going overkill with, as in SafeTCaps.
    Then I need to do something about the actuator leak. Thinking about an FJ case.... is that crazy?
    After that I am thinking about leveling it out. I don't like the rake but not sure it's wise to go up on the Bilsteins in the front for added lift. So either I need to go big money up front or lower the rear an inch... which I don't really want to do. Hmmmmm.
  13. May 23, 2024 at 12:56 PM
    lockedup
    4/2/24
    I got all the SafeTCap parts ordered.
    Went with 200, 201 & 202 on both sides as well as some fish plates and gussets.
    I don't think it will need them all, but the shop I am using is far away and I didn't want to have to make a second trip/order.
    Some before shots:
    This is everything I can find (and I am looking hard) on the driver side.
    3rd picture is down the gas tank side and it looks clean.
    The outside (outboard side) looks immaculate everywhere. It's just the inner (inboard) side.
  14. May 23, 2024 at 12:58 PM
    lockedup
    Pass side is worse and the photos make it look horrible...but still not like the catastrophic stuff I see on the web... and again the outside (outboard side) looks immaculate. very strange.
    I think even on this side the 202 parts are overkill but that is my goal.
    I never want to do this again (and if I have to I will re-frame it).
  15. May 23, 2024 at 12:59 PM
    lockedup
    4/8/24
    Got the front & rear driveshafts lubed up today @ 215,674
    (Had the typical clunking)
    Opted for Valvoline with Moly for u-joints and Mobil 1 synthetic for the slips.
    Seems to have solved it.
    Dropping off tomorrow at my local 4x4 shop for the Saftcap install.
    I'll share pics when I get them!
  16. May 23, 2024 at 1:01 PM
    lockedup
    5/3/24
    The shop was backed up but getting to me now.
    Driver side was very clean inside except for the very bottom.
    Passenger side will look worse inside but hopefully not too far up.
    I guess as thick as these caps are it doesn't matter.... not gonna go anywhere now!
    Will share pics from pass side when I get them.
    BassAckwards likes this.
  17. May 23, 2024 at 1:13 PM
    Muggsy71
    Muggsy71 New Member
    Tom
    2003 4runner
    I will be following this thread. I just bought an identical 03 except no sunroof.
  18. May 23, 2024 at 1:16 PM
    lockedup
    5/13/24
    Got her back from Krawltex and the frame is STOUT.
    Unfortunately, on the way to Krawltex I noticed that it was running hot.
    I was running a Bluetooth code scanner with live data.
    So I brought it from one shop to another... back to Bearden Automotive.
    Since they just did a bunch of engine work I just want to make sure it's not something they did.
  19. May 23, 2024 at 1:22 PM
    lockedup
    Bearden traced it to the Radiator.
    Said it looked like the PO had used some stop leak and it probably clogged it up. This explains the overheating that PO mentioned.
    It had hot & cold spots so that got replaced along with the cap. Pretty happy to have this sorted out.
    While it was there I asked them about the no heat on the Passenger side that I had noticed last winter and forgot about.
    They poked around and said the Air Mix servo isn't working so I will order one of those after I verify. Hopefully that is it and nothing to do with a clogged heater core from the dang stop leak used by PO.
    Additional shot of Engine bay because I forgot to post after I added the new intake assembly and new MAF so here they are...
    And the passenger front turn signal went out and was causing the fast blink.
    So swapped this out too.
  20. May 23, 2024 at 1:25 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I believe those clips were used for a removed XREAS system that's on all Limiteds.
    lockedup[QUOTED][OP] likes this.
  21. May 23, 2024 at 2:45 PM
    gkomo
    gkomo New Member
    San Diego, CA
    Damn you're going balls deep in this, i like it!
  22. May 23, 2024 at 3:19 PM
    lockedup
    Thanks.
    I didn't intend on having to go this far with it as far as the frame goes, but I don't like to do things half ass. Probably could have had a few spots plated here and there and redone it every few years but I just wanted to do it all at once, while I have a second vehicle I can use. Eventually this will be my DD/Work truck so I want it to be as dependable as I can get it, even if it is a little beat up on the outside.
    gkomo[QUOTED] likes this.
  23. May 23, 2024 at 7:20 PM
    Xreas, the 2003+ Limited and Urban Runner came with Xreas suspension which had a series of metal lines connected to an expansion chamber. This connected the shocks in a big X and acted as a huge crossover and remote reservoir. Whoever did the lift took the Xreas shocks and lines and all out.
  24. Aug 8, 2024 at 8:02 PM
    lockedup
    2 super exciting updates....
    New gas cap and purge solenoid.
    I know.
    I'm excited too... :bananadance:
    Had a P0442 code and it was just the gas cap, but I had already ordered the solenoid so on it goes.
    Fun stuff coming tomorrow.
  25. Aug 9, 2024 at 2:38 PM
    lockedup
    Got most of the front end redone....
    8/9/2024
    216,253
    LCA Kit - SuperPro
    I opted for the 3.5" setting and extra 100lbs because I have a winch & bumper planned ... but it is sitting too high.
    I get some nice vibrations under acceleration and when turning.
    So, I think I will try to lower the front this weekend about 1".
    After the winch/bumper I will adjust it back up if need be.
    Before the Dobinsons my front measurements were ~22" hub center to fender and rear was ~23".
    Now they are all around 24".
  26. Aug 9, 2024 at 5:46 PM
    gkomo
    gkomo New Member
    San Diego, CA
    Very nice! I’m super pleased with my Dobinsons IMS.
  27. Feb 16, 2025 at 11:44 AM
    lockedup
    Have not been driving this much and forgot to update!
    12-12-24
    216,565 miles
    I added shorter rear springs (Dobinsons C59-325 Rear Coils ) and lowered the front quite a bit.
    No more vibrations and rides great.
    Based on my measurements the front is at around 3.5" and the rear around 2.5".
    I do a have a slight driver side lean like everyone else.
    So I may grab a shim for the rear to help with that.
    Up next, I am looking at doing a manual T-case swap. Been doing a lot of research on what all will need to happen, but long term I thin it is a better solution than replacing an actuator. In order to help with shifter routing I am looking at a 1/2" body lift as well. I know it's not "necessary" but I think the extra room will help keep the cut out size down a bit. I also ordered a full set of replacement OEM body mounts & a new OEM transmission mount. Not because it "needs them", but because "while we are in there". [​IMG]
    LOSTR4 likes this.
  28. Feb 16, 2025 at 11:45 AM
    lockedup
    Next step is ....
    LOSTR4 and BassAckwards like this.
  29. Feb 21, 2025 at 6:26 PM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5 2wd
    Your stock case is full time 4wd right? Do you have any interest in selling your old case after the swap? Ive been wanting to 4wd/AWD swap my v6 and i think the v8 case would do the job. Im also in TX
    LOSTR4 and lockedup[QUOTED][OP] like this.
  30. Feb 22, 2025 at 7:19 AM
    lockedup
    It is full time. Sure. I can sell you anything else we pull off if you want also. Probably driveshafts (depends on if we retube & rebuild or buy new) , the 4wd selector & radio surround. I'm in Cedar Park near Austin. Where are you?
    LOSTR4 and BassAckwards[QUOTED] like this.
