PSI for load range E tires
Discussion in 'Wheels & Tires' started by ToyotaRDie, Jan 14, 2022.
  1. Sep 29, 2022 at 2:33 AM
    #91
    I guess I should have given a more descriptive explanation of our 10-ply use. We live on a gravel road, once upon a time a rock entered a tire tread.. seeing a piece of gravel stuck right in the tire tread made us switch to 10 ply tires, and since that change we have not had a 'rock' related flat. this is 25 yrs. or so ago. It's just what we do, run them at 37-38 psi. and life goes on! It works for us, but this may not work for everyone, and when we plan a trip, I air down a bit(2-3 psi) for aaahhh feeling in the ride.
    djwantke likes this.
  2. Dec 25, 2023 at 7:04 PM
    #92
    JWZ
    JWZ New Member
    2024 4Runner Off-road Premium KDSS
    I have a 2024 4Runner off-road premium with KDSS. Have driven over 2,000 miles on 40psi. The ride has been good, no added load, other than a 70lb roof rack and 70lb rock rails.
    Recently Contacted Wildpeak for my 265/70/17R E rated tires and they recommended 44PSI.
    Your New Size (LT265/70R17 E) has a Load Capacity of 2,219 lbs. @ 44 psi. per tire.
    44 psi cold would be the optimal air pressure for your new tires.
  3. Dec 25, 2023 at 7:54 PM
    #93
    backpacker
    backpacker New Member
    2023 TRD ORP
    Falken Wildpeak 265/70R/17 load E
    That's interesting. I've been running at 40. I can tell it's at the lower end of the sweet spot on colder days.
  4. Jan 2, 2024 at 2:14 PM
    #94
    Marchy
    Marchy New Member
    Sean
    Seattle
    2021 4 Runner Venture
    I run mine at about 40 psi for her pavement princess duties, and air down as required for whatever offroad adventures I get into. Ride quality is about the same as the stock P rated tires, and one could air down for a more pillowy experience at the expense of a mpg or two.
  5. Jan 3, 2024 at 10:41 AM
    #95
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    That checks out. https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf different tire size would change the pressure...and this chart applies for all brands of tires.
    The number of people in the automotive industry (including tire sales and installers) who do not know that an LT requires more pressure to handle the same weight as a P-rated tire (of the same size) is astounding.
    bigshmoop likes this.
  6. Jan 4, 2024 at 10:45 AM
    #96
    bigshmoop
    bigshmoop New Member
    Joe
    Schaumburg, IL
    '23 Lime Rush ORP
    LT255/80R17 ATW3's, Westcott Designs DOM/TIG sliders, low profile roof rack, ladder, preload collar lift, Baja Designs 40" S8 lightbar
    Amen to that.
    Toy4X4 and djwantke like this.
  7. Jan 4, 2024 at 12:00 PM
    #97
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Haven't seen this before
    Thanks yall
    I run 38psi, used to be 36.
    MT Baja ATZ LT285/70's load E
    Watching Thread
    Toy4X4 likes this.
