PSI for load range E tires
Discussion in 'Wheels & Tires' started by ToyotaRDie, Jan 14, 2022.
  1. Jan 14, 2022 at 8:09 AM
    ToyotaRDie
    ToyotaRDie [OP] New Member
    Does anyone have load range E tires on their 4R? These are 10 ply load E tires and the ride is definitely a rougher. I live in Colorado springs and hit the mountains pretty much every weekend. What psi are you running at in the street? Was thinking of lowering to 30 psi for a smoother ride on the street. On the trails I'll prob go down to 20psi. Thoughts?
  2. Jan 14, 2022 at 8:13 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I run the load range E BFG KO2 in 275/70-17. When I first got them, Discount set them to 36 psi, which I thought was crazy high, so I dropped them to 33 and got horrible results. Did some research (tire size.com maybe?) and turns out they actually need to be set closer to 41. I run them around 40/41 now and they’re great and straight on the road, if a bit stiff at times (but that’s an E-rated tire for you). Then I air down to about 18 off road.
  3. Jan 14, 2022 at 8:32 AM
    I think the experience would change from different tire brands. Some Load E tires have real strong side wall that gives much firm ride vs some Load E tires have little less strong side wall so its not too bad. For example from most common tires BFG KO2 got 3 ply side wall even though running at 32-33psi still it wasn't comfy on road. Vs tires like Falken Wildpeaks does not seem to have 3 ply side wall so it won't be firm as KO2.
    Me personally will not run Load E again as we use the 4R for our road trips as well. It is little too firm and not make my kiddo sleep comfortably.
    vBsdQ8AWKit8tSDJnYF9dqtfJjw7711yOtn6Al4u_2230f22290e6eae442d7d2ec1c8820f0bed47938.jpg
  4. Jan 14, 2022 at 8:44 AM
    ToyotaRDie
    I have Kenda Klever R/T load E tires 265/70/17. 10 ply with 3 polyester side ply. Uber tough tire but rough ride on the road. Was thinking of lowering to 25-30 psi for city driving and 18-20 for off road. Do you think 25-30psi for street use this would be unsafe on turns or destroy the already bad MPG on the 4R? Or would the hard sidewalls compensate for the lower PSI?
  5. Jan 14, 2022 at 8:53 AM
    Even though I lowered psi the side wall on my KO2 was not round as a SL tire. So why not try lower and check the temperature by hand from time to time. If the tire is not too hot I guess you would be ok.
    Your TPMS warning would be little annoying on the dash and you would never know if you get a puncture until its too late.
    One time I called BFG customer support to ask what is the correct tire pressure to run on 285/70R17 Load C and I got a ridiculous answer. "You should run at 50psi on that tire":facepalm:
    I wonder if we have any member here working as a tire tech to advice?
  6. Jan 14, 2022 at 9:37 AM
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    I also run the KOs load range E - sidewall specs say 80 psi cold (max). Load Range E tires always call for running at a higher PSI than your standard passenger car tires. I run mine at 45 psi - the ride is satisfactory to me but to each his own..
  7. Jan 14, 2022 at 9:51 AM
    Shadow_T4R
    Shadow_T4R New Member
    Josh
    2019 MGM TRD OR 4Runner
    Bilstein 6112 + 5160S | JBA UCA | Icon 2" Rear Springs | Cooper Evo MT 285/70/17 | Spider Trax Spacers | ToyTech Diff Drop | ARB Diff Breather | C4 Low Pro Bumper | X2Power AGM Group 31 Battery | Voltage Booster | Diode Dynamics SS3 Sports | ARB 50qt Fridge | Custom Built Gear Plate
    285/70/17 Cooper Evos, load range E here. Street use I run mine at 35 psi. Anything under 30 psi and I feel like I'm on a gumball and my already terrible mpg get worse. For off-road use it depends. Forest service roads right around 25 psi, really rocky stuff or the snow 10 psi or lower. I'm still running the stock TRD OR wheels.
    I would think anything under 30 psi on the street and your gonna start to get real uneven ware on your tires and your mpg is gonna suffer, not that its not already with E tires.
    BionicRandy likes this.
  8. Jan 14, 2022 at 10:01 AM
    We run Cooper AT3's, 275-70-17, load range E at 36psi- 38psi on street, 22psi off road. A little firmer on the street, but we like the rock protection of the 10 ply rating.
    POWERPLANTHOMER likes this.
  9. Jan 14, 2022 at 10:59 AM
    jester243
    Dan
    Spokane, WA
    ran load range E on my Tacoma and it kinda ruined the ride for me and cost me a few MPG's too. this time around with the 4runner I opted not to go with the E
    roc likes this.
  10. Jan 14, 2022 at 1:18 PM
    Will
    Will New Member
    2022 4 Runner TRD Sport
    I’m a tire salesman.
    the air pressure you run is the main cause of the rougher/softer ride.
    tread design can greatly reduce ride comfort through excess noise and if the more aggressive tread design starts to wear irregularly (which they are prone to do) that will start to manifest itself into vibrations throughout vehicle. This also makes ride feel rougher.
    10 ply tires are designed to have an optimum footprint on road with higher air pressures. This also can affect some of the ride but not as much as air pressure.
  11. Jan 14, 2022 at 1:22 PM
    Will
    Will New Member
    they gave you the max air pressure to handle the max load of the tire at highway speeds. They would not tell you anything else for CYA reasons.
    You can run a load range c tire on a vehicle that requires only a “4 ply” rated tire and just run the air pressure at the pressure listed on your door jam or owners manual and be fine.
    however, if the tire has been designed to have an optimum footprint at closer to the max air pressure the wear pattern could suffer. I doubt going to 6 ply rated from 4 ply rated would change wear characteristics that much though.
    Burnt Taco and kmeeg[QUOTED] like this.
  12. Jan 14, 2022 at 1:41 PM
    @Will really appreciate sharing that..:) Its great to have you in the forum to ask tire problems.
    Would you mind if I ask you, if you forget the price tag / promotions / availability in your shop, what 17in tire brand,model, load rating would you install on your 4Runner (stock weight, no trailer, no RTT, just minot things like skids and sliders) that is used as a daily driver (dry, wet, snow conditions) and weekend/vacation offroader? :D:D
  13. Jan 14, 2022 at 2:01 PM
    I run E rated 285-70-17 Nitto Ridge Grapplers. They are great, soft ride. My off road trails are full of sharp lava rocks. I don’t bother airing down. Not even sure what pressure they are at, probably around 37 psi.
    Toy4X4 likes this.
  14. Jan 14, 2022 at 2:12 PM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    I’m also curious where folks stand. I’ve been leaning towards C load since most of my traveling is job commute and I don’t do extreme or gnarley off-roading.
    Singleminded likes this.
  15. Jan 14, 2022 at 2:19 PM
    My mud tires are 295/70/17's and load range E. They're actually surprisingly comfortable at 35 PSI, which is what's recommended on that size and load range on our 4runners.
    Toy4X4 and kmeeg like this.
  16. Jan 14, 2022 at 2:25 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Didn’t you have Toyo Open Country AT3s at some point?
  17. Jan 14, 2022 at 2:27 PM
    Yes, they're on right now. Those are 285/70/17, load range C. They have held up to off-roading fine as well.
    banjos-n-beer[QUOTED] likes this.
  18. Jan 14, 2022 at 2:28 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Nice. They seem to have a higher wet pavement rating than similar options. That’s worth it to me here on the coast.
  19. Jan 14, 2022 at 3:06 PM
    I've been happy with them as an all-around tire.
  20. Jan 14, 2022 at 4:15 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I run mine at 35-36.
  21. Jan 14, 2022 at 4:27 PM
    NB8George
    NB8George New Member
    2018 4Runner TRD Pro
    Im really confused. We run our E tires in our vans between 65-75 psi. I just bought KO2’s that are rated E and im wondering if its the same case. Can I run them at 80 psi for optimum fuel efficiency? Just wondering
  22. Jan 14, 2022 at 4:51 PM
    No, that would suck!
    It's based on GVWR and tire size + load range.
    Stock size LT tires should be run at 44 PSI to maintain the proper load, but a lot of people will run them lower for better ride quality or treadwear
    This is a good tool for converting tire pressure from stock size and load range tires to alternate sizes and load ranges:
    7385, Toy4X4, Will and 1 other person like this.
  23. Jan 14, 2022 at 4:54 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    Probably because your Toyota weighs somewhere around 4500 pounds and isn’t meant to weigh more than 5200 pounds fully loaded while the load capacity of those tires is up to 16,000 pounds.
  24. Jan 14, 2022 at 5:11 PM
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    I had Stock BFG E-Rated tires on my FJ Cruiser Team Trail, and it was recalled to put a sticker on the door saying 46 PSI minimum for E-Rated Tires. It road like a rock and only touched the road in the center. I had terrible problems getting the tires balanced and it had the famous 55mph steering wheel shimmy. Toyota fixed this by switch to a C-Rated tire and no more problems (38 psi).
  25. Jan 14, 2022 at 5:19 PM
    Henry J
    Sacramento Ca
    Well I’m an idiot running mine at 60 for our FJ and 4Runner on Dick Cepek trail country exp. Hell, litterly got them rotated on Wednesday and American tire set them at 60
  26. Jan 14, 2022 at 5:20 PM
    remoguy55
    remoguy55 New Member
    2020 SR5 Premium 4WD
    I have stock size General Grabber X3s, Load E. I run about a 38PSI. the tire calc said to run around 44psi but seemed too stiff and uneven tread.
  27. Jan 14, 2022 at 5:36 PM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    I think 25 psi in an E rated tire would be unsafe and 30 wouldn't be much better. Yes, your mpg would suffer. E rated tires actually need more psi than stock sl (p) rated tires to function property, because they are stiffer . the stiff sidewalls definitely don't compensate. I read a great article somewhere explaining it all, but unfortunately can't find it any more.
  28. Jan 14, 2022 at 5:48 PM
    The tire will have the max inflation psi on the sidewall. I’m betting that between 35-40 is the sweet spot for E load tires on our 4Runners.
    80+ psi sounds way high.
  29. Jan 14, 2022 at 6:05 PM
    I have Falken Wildpeak MTs 285/70/17 E load i run them at 45 psi. In the front, and 35 psi. In the rear. That calculator says E load should not be run under 35 psi. I have been running mine like this for over 2 yrs. With no problems.
  30. Jan 14, 2022 at 6:12 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    I have had 285/70R17 E rated tires on my two FJ cruisers and my fifth generation and I run all of them at around 35 to 36.
    I think you could probably go down to 32, but I think that’s a bit low.
