Liquid swishing sound behind dash only when accelerating
Discussion in '2nd Gen 4Runners (1990-1995)' started by Abdulnaser, Dec 17, 2018.
  1. Dec 17, 2018 at 8:57 AM
    Abdulnaser
    Abdulnaser [OP] New Member
    1990 Toyota Hilux Surf
    Okay I have 1990 Toyota Hilux Surf that was imported here. It has 126,000 kilometers which is like 77k miles. Every time I start it up and accelerate, I hear what seems to be water/liquid moving around behind the dash, I only notice it when I accelerate.
    Something to note:
    -The heat doesn’t work
    -I changed the coolant a week ago but the water sound was around before the coolant change
    -It’s a 2.0L regular gas engine code 3Y-E
    -there is no liquid entering the passenger compartment
    If anyone can please help, it will be greatly appreciated
  2. Dec 17, 2018 at 9:56 AM
    Bob
    Bob Member Staff Member
    Bob
    Interested to see what it turns out to be
  3. Dec 17, 2018 at 2:59 PM
    4runningMan
    4runningMan New Member
    New Mexico
    It "sounds like" liquid or it IS liquid? Are you able to confirm that much?
  4. Dec 17, 2018 at 4:15 PM
    Dillusion New Member
    KYle
    On my old 2002 Camry I had the same noise.
    It was the coolant circulating. It also had the dreaded head bolt issue causing coolant to leak into the cylinders. Would go away after bleeding the system but after driving it for a bit and loosing coolant I'm guessing the air in the system combined with the flow caused the noise.
  5. Dec 17, 2018 at 4:16 PM
    Abdulnaser
    It sounds like liquid. Maybe kinda bubbly liquid sound
  6. Oct 16, 2019 at 6:39 AM
    Yodaforce
    Yodaforce New Member
    Matt
    1997 4Runner SR5 5-Speed
    Hello, Abdulnaser. I have the exact same issue in my '97 4Runner.
    - Only during heat settings
    - Heat DOES work
    - No leakage inside or outside car
    - Only on acceleration
    - AC works fine - VERY cold
    - NO overheating issues
    Did you ever find out what was up?
    Matt
  7. Oct 16, 2019 at 6:47 AM
    The Blue Pearl
    The Blue Pearl New Member
    Bill
    16’ NBP 4x4 4Runner
    18’ Tundra SR- 4x4
    Oh boy don’t sound good !!
    was truck flooded- hope not- good luck with ur issue
  8. Oct 16, 2019 at 6:53 AM
    Yodaforce
    Matt
    Don't know about Abdulnaser, but I'm third owner on my truck, and can't imagine mine was flooded given the sweet operation of the other 99% of this car. Its a beast.
  9. Oct 16, 2019 at 7:15 AM
    Dark Knight
    Dark Knight Get off my lawn
    Pressure test your coolant system. This will reveal the location of the leak.
  10. Oct 20, 2019 at 1:35 PM
    Twisted Bow
    Twisted Bow New Member
    '95 3.0
    I have heard this as well I'm my 95 3.0, I'm still waiting on a knock sensor to arrive before diagnosing this sound though since I'll have the engine tore up to replace the sensor. I'll post anything I find but I'm already assuming it's because of a coolant leak I found when I got the truck. It only happens every couple weeks but I've learned to just refill my radiator when I hear it and it immediately goes away, normally it's only a couple cups of coolant that fits back in. No overheating, heat/ac fine, happens when the defrost is on on startup etc.
