Limited ventilated seats blowing hot air sometimes
Discussion in '5th Gen 4Runners (2010-2024)' started by h4yd3n, Aug 18, 2020.
  1. Aug 18, 2020 at 6:54 AM
    h4yd3n
    h4yd3n [OP] New Member
    Hayden
    2021 Limited
    Does anyone else have an issue with hot air being blown out of the limited ventilated seats when it’s really hot out? Mine is only a 2019 so wtf
  2. Aug 18, 2020 at 7:20 AM
    Agent_Outside
    Built 2011 T4R Limited
    The seat ventilation is not heated or cooled, it’s simply moving air that’s already in the vehicle.
    Is it actually blowing air out? Pretty much every manufacturer has gone away from the air hockey table design and they use a fan to pull air through the seat and out the bottom. It’s more effective and comfortable to pull air away and remove the heat than it is to blow on the heat.
  3. Aug 18, 2020 at 7:27 AM
    h4yd3n
    Hayden
    2021 Limited
    Well mine were/are-sometimes-still actively cooled. It was blowing cold air for sure.
    But for the past month there are times when the seats keep blowing hot air for the entirety of my drives even for 30 min or so until I just turn them off.
    I think I’ll need warranty service
  4. Aug 18, 2020 at 7:34 AM
    Agent_Outside
    Why even ask the question if you have no idea how it works, you're not going to listen, and you’re going to waste a trip to the dealer regardless?
    deanf likes this.
  5. Aug 18, 2020 at 7:40 AM
    h4yd3n
    Hayden
    2021 Limited
    Lol. Reading comprehension Test:
    1. mine blew very cold air even on very hot days this summer.
    2. Suddenly they sometimes blow only hot air even during medium hot or warm days.
    = there is an intermittent problem
    see? Reading comprehension
    deanf likes this.
  6. Aug 18, 2020 at 7:46 AM
    Agent_Outside
    Regardless of what you think happened, it never blew air colder than the interior temperature, that’s impossible, the system is literally just a fan that circulates air.
    ThePnsh3r likes this.
  7. Aug 18, 2020 at 12:28 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    If you want colder air seat ventilation, make sure to press the 2nd button which directs AC air thru the front and bottom vents. Also make sure AC is on.
    remember it’s just a fan circulating what ever air temp is under the seats up into the air pockets of the seat.
    Singleminded likes this.
  8. Aug 19, 2020 at 12:11 AM
    fixer5000
    fixer5000 the logical one
    steve
    Massachusetts
    2018 limited in nautical blue with redwood leather
    no plans
    this is how i do it and it works fine for me. smoke tested and they blow out not in...ymmv
  9. Aug 19, 2020 at 6:04 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    If my seats don’t blow colder or warmer air, why is there a control knob that has a cold or hot setting?
    I believe my limited blows cooler or warmer air through the seats, but I have never really investigated
  10. Aug 19, 2020 at 6:20 AM
    Agent_Outside
    The seats have a heating elements in them (hence heated seats), so you can ventilate it while heating the seat. The seat does not have a cooling system, it’s substantially harder to make something hot cold, than it is to make something cold hot. Also if you notice they refer to “heated seats” all over, but you will never find any reference of “cooled seats” anywhere, just ventilated.
  11. Aug 19, 2020 at 7:12 AM
    Spare Parts
    Southern Maine
    22 LR ORP
  12. Aug 19, 2020 at 7:33 AM
    Agent_Outside
  13. Aug 19, 2020 at 10:42 AM
    Daytonaviolet
    Bay Area, CA
    Ventilation fan for reference :) It only circulates the air temp around the fan, thus the word ventilation rather then cooling.
    Singleminded and Agent_Outside like this.
  14. Aug 20, 2020 at 4:35 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    It may not “heat” or “cool” the air it circulates, but I will say the air is cooler or warmer depending on which way I turn the temp setting knob.
    Daytonaviolet likes this.
  15. Jun 25, 2021 at 10:53 AM
    retired
    retired New Member
    Al
    2017 Magnetic Grey 4Runner Limted
    In our 2017 Limited, we experience intermittent seat cooling. Sometimes it works, I believe it may be a switch issue. For example if I turn the knob to the first position the fan will not come on, but if I then turn the knob to a higher position the fan will come on. When it works the seat becomes very cool to the point where it is too cold.
