Limited owners. Tire pressure question.
Discussion in '5th Gen 4Runners (2010-2024)' started by mtnslyr, Jun 2, 2022.
  1. Jun 2, 2022 at 9:42 PM
    mtnslyr
    mtnslyr [OP] New Member
    The dealer had the tire pressure at 35 psi and the tire looked round. The recommended tire pressure on the door jamb is 32 psi so I deflated them. Now it definitely doesn't look round. What is your tire pressure on 245/60-20? I've attached a picture, does it look flat?
  2. Jun 3, 2022 at 12:11 AM
    DUSTYDOGDAN
    DUSTYDOGDAN New Member
    2022 4Runner
    bone stock for now
    It doesn't look flat. A new modern tire has a contact patch. It is not completely "round" if I am understanding your question. I would go by the pressure the owners manual says... but 2 or 3 more PSI isn't bad if out driving on the highway at high speeds.
    mtnslyr[OP] likes this.
  3. Jun 3, 2022 at 4:57 AM
    Steve40th
    Steve40th New Member
    sTEVE
    I run 35psi. Tire manufacturer has a window for which the tire will be fine.
    As others have said, as you drive temp will go up. Always check cold though..
  4. Jun 3, 2022 at 5:42 AM
    Like the others mentioned, the tire is intended to have a small flat area on the bottom when properly inflated.
    All 4Runners are 32. It's based on GVWR and tire size and load range. The 4Runner uses bigger tires than some other vehicles its size.
    It would change if you switch to a different size or load range tire.
    4runGirl88 and mtnslyr[OP] like this.
  5. Jun 3, 2022 at 5:46 AM
    Steve40th
    sTEVE
    Also, buy a quality tire pressure gage too. Cant stress that enough. Its worth it..
    DUSTYDOGDAN and Thatbassguy like this.
  6. Jun 3, 2022 at 6:20 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    - Wonder if the thoughts/issues with switching to a more aggressive/winter tire like Toyo T3 Or Bridgestone Blizzark on same 245/60-20 (Limited/TRD Sport).
    Planning to stick with 245/60-20 ... not downsizing to 17s
  7. Jun 3, 2022 at 6:21 AM
    Steve40th
    sTEVE
    When you change tires, different plys, designed for etc, they may require different pressures.
  8. Jun 3, 2022 at 6:25 AM
    Yes. Anything other than the stock size and load range will require an adjustment.
    Here is a handy tool for finding the appropriate pressure for a tire of different size or load range from stock:
  9. Jun 3, 2022 at 1:30 PM
    mtnslyr
    I have one from Capri tools, bought it off Amazon for $30. Is that good enough?
  10. Jun 3, 2022 at 1:53 PM
    mtnslyr
    I’ve been thinking about buying set of winter wheels. Going down to 17 inch wheel gives more winter tire options but the tread width increases to 265 mm. And I’ve read that on winter tire smaller tread width is better for slicing. So I’m in a quandary.
  11. Jun 3, 2022 at 7:24 PM
    KENTUCKYRUNNER
    KENTUCKYRUNNER New Member
    2006 sport to a2016 SR5 PREMIUM TO A 22 LIMITED
    i run mine at 34, i think its normal just low profile tires
  12. Jun 3, 2022 at 9:28 PM
    Henry J
    Sacramento Ca
    Holy crap I’ve been way the hell off. I’m driving around at 60psi on load E. I’m only admitting this here because no one lives near me to smack me in the face.
  13. Jun 3, 2022 at 11:09 PM
    Do you still have all your fillings?
  14. Jun 4, 2022 at 3:47 AM
    I highly recommend Nokian Hakkapliittas if you choose to get snow tires.
    Ouch! That must be rough!
    LT tires do require higher pressure than their SL equivalent. In the case of a stock size 265/70/17 LT tire, it calculates out to 44 PSI. But, a lot of folks will run them a bit lower.
    7385 likes this.
  15. Jun 4, 2022 at 4:39 AM
    Henry J
    Sacramento Ca
    Going from 60 to 45 would be like going from a futon to a mattress. I’ll be getting that done today
  16. Jun 4, 2022 at 6:49 AM
    lidz
    lidz New Member
    17' wheels, Any pressure is ok.
    I used to run 38psi(cold) and 41psi(hot) on the highway for one summer. this is stock tire pressure for transport. no problem.
    in addition, the backup tire is 50psi for long time storage. it was also used with no problem.
    In winter it falls to 30psi(cold) and 33(hot) also ok. lower than 29psi will trigger a warning. offroad can be as low as 25psi.
    so any 32-35psi(cold) is ok.
    If you get a nail in the tire, the monitor will show pressure lower unusually than others.
  17. Jun 4, 2022 at 7:02 AM
    "Any" pressure is not okay.
    At 38 psi, I would expect your tread to wear unevenly.
    Off-road can be as low as necessary for the situation. Obviously, at some point you risk having the tire come off the bead. I run 15 to 25 depending on the situation. I might try even lower in some rocks this year.
    7385 likes this.
  18. Jun 5, 2022 at 4:36 PM
    mtnslyr
    Do u have one? Which Hakkapliittas specifically and what size if u have one.
  19. Jun 5, 2022 at 4:45 PM
    I have a set Hakkapliittas on a Scion tC. I actually feel safer in that in the snow than I do in my 4Runner with three peak all-terrains. I don't recall the exact size that are on the tc. I know that they offer a version specifically for trucks and SUVs though.
    mtnslyr[QUOTED][OP] likes this.
  20. Jul 15, 2022 at 6:21 AM
    Steve40th
    sTEVE
    I have been using this one for years. I used to autocross a lot and drag race my Corvette. Its what was recommended by many..
    There are many out there that are fine..
    Racing communitys tend to be OCD for precision and consistency.
    https://www.joesracing.com/product/joes-pro-tire-gauges/
  21. Jul 20, 2022 at 12:13 PM
    CBC060786
    CBC060786 New Member
    Brian
    2015 4Runner
    I went from 20's to 17's as well. Handles much better for me.
  22. Oct 18, 2023 at 8:23 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Did you end up getting winter tires for your 20" wheels?
  23. Oct 18, 2023 at 10:06 AM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Did you notice the tire pressure at 35 psi while you were driving home from the dealer - or did you measure 35 psi after the vehicle was parked for some time. The 32 psi recommended tire pressure is cold pressure (after the vehicle has been parked for some time). If you saw on the multi-info display that the tires were showing 35 psi as you were driving home - and then immediately deflated to 32psi - the tires could be down to 29-30 psi easy when cold.
  24. Oct 21, 2023 at 11:50 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I run 38 in mine or it starts eating cornering edges off. Might be my driving. I get good even wear and don't have to adjust for extra load often or temperature differences. I was pricing another set of Bridgesone Dueler HL and it said 80k mile tire. Mine will have lasted about 30k on curvy mountain roads with Xreas. Hmmmm...I wonder what the problem is?
    pastoreater likes this.
  25. Oct 25, 2023 at 2:36 PM
    steelevo
    Utah
    When I had my Limited, I would run 32-35 PSI for around town street driving and 35-38 PSI for long trip highway driving.
