Limited Front End
Discussion in '5th Gen 4Runners (2010-2024)' started by baz0157, May 13, 2020.
  1. May 13, 2020 at 6:42 AM
    baz0157
    baz0157 [OP] New Member
    P
    2019 Limited Nightshade
    Rough Country leveling kit, Stealth Custom Series Bronze SR8's and Gobi Rack, Victory 4X4 Rear Window Storage & Cargo Basket.
    Anyone else have this problem with their limiteds? Where the lower bumper meets the top under the head light housing keeps popping out.
    Push in one side and the other pops out. Had it in the dealership for its first service and pointed it out. They told me it was fixed. Drive it home and it is still popping out and won’t start fastened.
    skull and aedavis87 like this.
  2. May 13, 2020 at 6:56 AM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    Eibach Stage 2, JBA UCA’s, K02 - 265/70r17
    Yup, my 2019 does the same thing. I first noticed it around 800 miles and it is only on the driver side *knock on wood*. I forgot to mention at the first service but did at the second. I have almost 8k miles now and had my 4R for just over a year. The dealer worked out where I would drop by the body shop to have them take a look and the shop indicated that it's not uncommon. After talking with the body tech I was convinced I'd leave it alone, although Toyota agreed to cover the body shop costs.
    Basically the tech indicated he has seen it with 5th gen 4Rs and 3rd gen Tacomas and had even showed me a Tacoma they had there with it. As I understand it, there are an insufficient amount of attachment points (clips) for the bumper cover to hold it to the body securely. The tech said he is more than willing to "try" to fix it but there is no guarantee he could fix it or that the manipulation wouldn't cause the other side to pop out. I figured that although I don't care for it having that gap I understand his explanation and I'd rather not have anyone go in there manipulating things that may end up causing other issues and wasting more time.
    Toffees, aedavis87 and baz0157[OP] like this.
  3. May 13, 2020 at 7:34 AM
    baz0157
    P
    Well, I got note of explanation from you than I did my body shop! Thank you. I agree I don’t want any manipulation. I’ll live with as well, until I decide to make this Nighshade a TRD OffRoad... haha wonder if anyone has ever put the TRD front bumper on a Limited?
  4. May 13, 2020 at 8:56 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    like this ?
  5. May 13, 2020 at 9:21 AM
    baz0157
    P
    @Daytonaviolet absolutely! You do it yourself? Any info or suggestions you could offer?
  6. May 13, 2020 at 9:29 AM
    Daytonaviolet
    Bay Area, CA
  7. May 13, 2020 at 9:36 AM
    baz0157
    P
    Thank you, I'd appreciate that! My biggest problem so far has been finding the correct part for the new front bumper. Whether TRD OF or TRD Pro.. most of my searches come up short of finding anything that works. When I mentioned it to my local shop/dealer they just said, why did you buy a TRD... simple answer, I wanted the Nightshade..
  8. May 13, 2020 at 9:44 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I have the same issue on my drivers side as well. Pop it in, drive for a few miles, pops back out. Very annoying but learned to live with it.
    EDIT: I meant passenger side, not drivers side
    Daytonaviolet likes this.
  9. May 13, 2020 at 9:51 AM
    Daytonaviolet
    Bay Area, CA
    I think most of these bumper issues may be related to the bumper installation. The back of the bumper has the square guides which secure into the bracket under the headlights. Often times, you just need to reseat the bumper correctly into this bracket.
    aedavis87 likes this.
  10. May 13, 2020 at 10:33 AM
    Daytonaviolet
    Bay Area, CA
    Did you completely remove the bumper then reseated ?
  11. May 13, 2020 at 10:39 AM
    mcat707
    I’ve done it several times. Probably more than 10 times. I had to, when I needed to adjust the HID bulbs in my AlphaRex PRO headlights. These aftermarket headlights require to remove the bumper to get the headlight assemblies out just to replace or adjust the bulbs. Yes it sucks.
    Daytonaviolet[QUOTED] likes this.
  12. May 13, 2020 at 11:06 AM
    Daytonaviolet
    Bay Area, CA
    the first time I seated my TRD bumper, I noticed the gaps like the next day after driving around. I removed the bumper and reseated. But I did it at the exact time, meaning the left and right sided needed to be seated simultaneously in order for me to get a good guide pin seating under the head lights.
    If I did it one side at a time, I could not get the guide tabs seated correctly.
  13. May 13, 2020 at 11:15 AM
    mcat707
    I’ll have to try that next time I have to reinstall the bumper
  14. May 13, 2020 at 4:15 PM
    Jemplyr77
    Jemplyr77 New Member
    Brian
    Oklahoma
    2019 MGM Nightshade
    Tinted windows. USR tail lights.
    Had the issue on my 2016 LE and the dealership took it to the body shop they used and fixed it. Stated it was common and never had another issue. Don’t have the problem on my 2019 NS...yet anyway.
  15. May 14, 2020 at 7:55 AM
    baz0157
    P
    Stopped at my local dealer today to check on the TRD front end.. not a lot of luck. First off, they couldn't find a part number for a front bumper. My question was, how does someone with a TRD OF buy a new bumper when they have an accident?? (hard to believe a toyota dealer couldn't find a part number)
    Next, I called a dealership in the neighboring state. They seemed to find what I need, quoted me $1626.03 for all the required parts needed to change the front bumper.
    Does that seem about right?? Would you be able to provide part numbers for the front bumper build?? I'd greatly appreciate it!
  16. May 14, 2020 at 11:30 AM
    Daytonaviolet
    Bay Area, CA
    $1600 sounds okay, but what does it include ? I did the bumper swap as well as the liner swap. Here’s a pic of how my truck looks today :)
    take a look at this spreadsheet and let me know if you have any questions.
    https://docs.google.com/file/d/1PqD...65xIk3/edit?usp=docslist_api&filetype=msexcel
  17. May 14, 2020 at 11:33 AM
    skull
    skull New Member
    Karl
    NC
    2019 Trd ORP
    Doing in on my 2019 TRD ORP...passenger side
  18. May 14, 2020 at 11:36 AM
    baz0157
    P
    @Daytonaviolet Thanks for that spreadsheet! I assume it included everything needed.. the parts guy rambled off all the pricing.. I'd much rather do this all myself and not pay the dealership for the install. Who would have thought a Toyota dealer would have troubles ordering a bumper? :notsure:
  19. May 14, 2020 at 12:28 PM
    Daytonaviolet
    Bay Area, CA
    It’s because they are not accustomed to selling bumpers.. lol.. they are clueless when it comes to retrofitting.
    I purchased my new items locally but I ordered online and did local pickup. Items cost more if you walk in and request parts on the counter vs ordering online and doing local pickup.
    I tried ordering online out of state, prices were cheaper and with not taxes. But shipping ate away of the cost savings.
    After a while, the Toyota parts guy knew me personally and eventually offered me one line pricing at the counter. They will thrilled with the transformation :)
  20. Nov 14, 2020 at 2:45 PM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    UPDATE!!! Just received a call from the local dealer. They remembered my complaint from back in April and called to let me know that there is a service bulletin for replacing the clips with an updated p/n, fixing the gap issue. I'm scheduled to get mine done on Dec 1. Found the TSB online at NHTSA: https://static.nhtsa.gov/odi/tsbs/2020/MC-10176697-9999.pdf
  21. Nov 14, 2020 at 4:06 PM
    Daytonaviolet
    Bay Area, CA
    Awesome
  22. Nov 14, 2020 at 10:15 PM
    tundradan
    tundradan New Member
    2013 Silver 4Runner Limited
    Stock....for now
    Just my luck. I have a 2013....not covered. Had the same thing happen on our 2003 Honda Odyssey as well. Transmission went out and the class action suit covered all years from 2004 on. I'm always a day late and a dollar short! :(
    peter2772000 likes this.
  23. Nov 15, 2020 at 6:13 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    All the fix is, is Velcro tape. Pretty sure you could do that yourself.
    tundradan[QUOTED] likes this.
  24. Nov 18, 2020 at 3:13 AM
    fixer5000
    fixer5000 the logical one
    steve
    Massachusetts
    2018 limited in nautical blue with redwood leather
    no plans
    actually the duelock stuff is all plastic and holds a lot better than velcro would. its like 100s of little fingers that interlock together
  25. Dec 4, 2020 at 10:26 PM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    Just wanted to report back. Just had the work done and I am extremely pleased. As the bulletin indicates, both sides were done although I only had issue on one side (drivers side). Before and after pics included for comparison.
    Drivers side before:
    Drivers side after:
    Passenger side before:
    Passenger side after:
  26. Dec 4, 2020 at 10:40 PM
    The gap on the PS fender looks bigger in the 'after' pic...what's with that?
  27. Dec 5, 2020 at 7:27 AM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    It's the picture. After I posted I was thinking it would have been best to send after pics with better lighting but that's all I had and wanted to share the results.
  28. Dec 5, 2020 at 7:28 AM
    Thought so, but wanted to ask anyway...thanks
  29. Jan 28, 2021 at 6:34 PM
    RonnieD45
    RonnieD45 New Member
    Ron
    2016 Black 4Runner Limited
    LED light swap Blacked out emblems
    Dumb question...Is the labor cost covered under this bulletin? I just bought a 2016 and it’s bothering the hell out of me!
  30. Jan 28, 2021 at 6:41 PM
    204runnerunlimited16
    204runnerunlimited16 New Member
    Bought a shrockworks front bumper to fix the issue. :dancingbroccoli:
    DRobs likes this.
