Limited 2020 rear liftgate arrow buttons do not work
Discussion in '5th Gen 4Runners (2010-2024)' started by olukas, Apr 16, 2024.
  1. Apr 16, 2024 at 8:41 PM
    olukas
    olukas [OP] New Member
    Hi, just purchased 2020 Limited with the smart key. Those up and down arrow buttons on the liftgate do not roll window up or down neither lock/unlock the car. The inside switch for rolling window down works properly as well as all locks. I tried to search everywhere, checked fuses and so on but could not find any solution. Anyone has an idea what to do?
    Thank you!
  2. Apr 16, 2024 at 8:48 PM
    Go Birds
    Go Birds New Member
    23 ORP
    Let's rule out the basics first:
    The key fob has a live battery and will lock/unlock doors when you push the buttons on it?
    Next, you do have the key fob, with live battery, on your person when pressing and holding the down arrow on the hatch to attempt the rolling down of the rear glass?
    icebear, MeefZah and Pentangler like this.
  3. Apr 16, 2024 at 10:08 PM
    olukas
    Hi, yes that is correct. Locks work, I can open the lift gate using the handle as well as both front locks with the key fob on me.
  4. Apr 17, 2024 at 6:50 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    There's a receiver for FOB signal under the center of carpet in the back, but I think it's simpler than that. Read your owners manual. Make sure hatch is shut completely.
  5. Apr 17, 2024 at 7:20 AM
    olukas
    I did read the manual, also tried to search the entire internet and tried all the tricks but still cannot make it work. Was thinking if the previous owner had it deactivated for some reason? I beliave it is to new to have the wires broken going to the rear gate or anything like that.
  6. Apr 17, 2024 at 7:29 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Yeah and you never know who has been inside what either. It's easy to remove the hatch panel yourself. Snap together and a 10mm bolt if you want to check the plug and test the wires. I didn't know about the manual. Most people don't read it anyway. I'm learning things about 5th gen as I go from experience. I have a tech on messenger and I can maybe ask him. If it's a problem usually you see it at the dealer multiple times.
  7. Apr 17, 2024 at 7:37 AM
    olukas
    That would be great thank you! Just wanted to ask before I start taking it to the parts:)
  8. Apr 17, 2024 at 7:41 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Don't throw parts at it. That's what you do driving a Dodge, but I love em. It's been my experience that is simpler than you think. All the technology is creating more problems, but they are still pretty simple.
