Lightest 10K winch to go in C4 Lo Pro?
Discussion in 'Armor' started by Jrunr, Nov 1, 2021.
  1. Nov 1, 2021 at 12:34 AM
    Jrunr
    Jrunr [OP] 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    I want to add the C4 Lo Pro bumper and a winch to my 2021 TRD Pro, but I am looking to do so without adding a ton of weight to the front end. What is the lightest, quality, 10K ish winch I can fit inside the bumper?
    Thanks!
  2. Nov 1, 2021 at 5:09 AM
    Most of the 10K winches will be about the same size. Going with a synthetic line will save you some weight.
    Even so, you're probably going to get some sag with that bumper and a winch. I think one of the suspension manufacturers might make upgraded Springs for the Pro. Otherwise, your only options are to deal with it or to upgrade the front suspension.
    MeefZah likes this.
  3. Nov 1, 2021 at 5:32 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Probably could toss a 1/4" spacer in there, too, if there's sag. That would likely put it back to factory height.
    Ditto on the synthetic line. If you aren't locked in to that particular bumper you could also get a hidden winch bumper to save weight; I want to say mine was a gain of maybe 70 lbs (including winch) after factoring in weight of the removed OEM components.
  4. Nov 1, 2021 at 6:06 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Opted for the aluminum version of Victories Blitz w/o tube work (35 pounds), plus a ZEON 12 S(synthetic/80 pounds). That combination did not budge the front springs, at all.
    https://www.victory4x4.com/product/V4R5FB.html
    https://www.roundforge.com/winch-database/warn-zeon-12-s-winch-95950/
  5. Nov 1, 2021 at 6:09 AM
    Jrunr
    Jason
    Awesome. Thank you for that. I am still planning out the build of my baby after i get home from this deployment...
  6. Aug 9, 2022 at 8:59 PM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    Jer-
    Been following your methodical build since you got your Moon Rock. Awesome build.
    I’m considering the same Aluminum Victory bumper and a Warn 10k# synthetic winch like yours on my ‘21 Pro but I’m concerned with possible front end sag if I stay with the stock Fox/Pro suspension that comes in the ‘21 models. When you reported no sag with your installations, is it with the factory Fox suspension?
  7. Aug 10, 2022 at 8:43 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Yes, and thanks!
  8. Aug 10, 2022 at 8:48 AM
    Kilo Papa
    TX & NM
    2021 TRD Pro
  9. Aug 10, 2022 at 8:51 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Personal choice. They'll both get the job done....most of the time.
    4runGirl88 likes this.
  10. Aug 10, 2022 at 8:53 AM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Thought so. Thought I’d ask. Thanks again.
