Light panel options.
Discussion in '5th Gen 4Runners (2010-2024)' started by Nubie, May 1, 2024.
  1. May 1, 2024 at 8:06 AM
    Nubie
    Nubie [OP] New Member
    Finally starting to upgrade/add lighting to the rig. Lots of research about adding a panel and I’m stuck.
    I’m considering Switch-Pro or Auxbeam. The problem is that after lots of looking I can’t figure out why I shouldn’t go with Auxbeam. I don’t need to pay lots extra for the prestige of Switch-Pro unless there is a CLEAR advantage.
    Any help on the subject would be appreciated!
    Thanks.
  2. May 1, 2024 at 10:50 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    If you don't get the Switch-Pro, you'll get stuck in the first mud puddle you try to cross.
  3. May 1, 2024 at 11:19 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    I went through the same thought experiment several months back. I bought the mictuning version. I figured it would be easy to replace with a Switch Pro if/when it fails. The ~$100 price tag made the choice easy. If it were a race car or pre-runner, then I would argue the more durable version is required. I think for most overlanders, the cheaper versions should be just fine.
    https://www.amazon.com/MICTUNING-P1...6782206&mcid=809873e548823bd383fe8cce0ba14503
  4. May 1, 2024 at 11:39 AM
    2019 TRDP w/Kangs brah!
    Personally I feel like the Auxbeam is just the cheap copy. I will be going SP when I need it.
