Light Bar on TRD Pro Rack
Discussion in '5th Gen 4Runners (2010-2024)' started by 24Gen5, May 22, 2024.
  1. May 22, 2024 at 10:12 AM
    24Gen5
    24Gen5 [OP] New Member
    I have a 5th gen 4Runner with a TRD pro roof rack and I’m interested to put a Prinsu light bar. Saw this set up and loved it. Anyone know what kind or mount, bar or additional set up it has besides the Prinsu light bar. Or are there any other suggestions?
  2. May 22, 2024 at 10:27 AM
    Doesn't a light over the head reduce visibility? all dust and other elements shine in front of you?
    In addition wind noise, poor aerodynamics acting like air brakes?
    I bet wiring also pain in the a** running along the weather strip on the roof and side of the windshield.
  3. May 22, 2024 at 10:52 AM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    I feel like at that far back it's pretty much only for looks. Maybe I'm wrong but I can't imagine getting a ton of useful positioned light out of that.
    djwantke and 1SilverRunner like this.
  4. May 22, 2024 at 12:34 PM
    ShakyDog
    ShakyDog New Member
    Steve
    2021 4R TRD ORP Nautical Blue
    Had a couple of Polaris RZRs and I removed the light bar on the roof on the second one as I learned that the lower the better. Running an 11" LED on the front grill was better than the 30" on the roof.
    Steve
    djwantke and 24Gen5[OP] like this.
  5. May 22, 2024 at 12:37 PM
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    No offense dude - that looks like shit. Function is probably even worse than the looks. Big oof.
  6. May 22, 2024 at 4:02 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP,
    So ya think the roof rack might be the Toyota PRO rack, with a Prinsu wind fairing bolted on. Then a light bar that folks say is LASFIT.
    my first thought before reading was that the PRO rack is way too far back for a light bar. That photo, and the way it’s mounted low, confirmed my suspicion.
    I have 3/4 length cargo basket. Even that is too far back for a lightbar (halfway over sunroof).
    They did a good job racking that wind fairing and light bar though, I didn’t know that was possible.
    But I’m a stickler for my off-road lights being as functional as possible.
    13” wide angle light bar lower grille (6000LM)
    2x 6” bars in upper grille (1,250LM ea)
  7. May 22, 2024 at 4:13 PM
    kmeeg[QUOTED] likes this.
  8. Nov 11, 2024 at 5:49 AM
    JT4RN
    JT4RN New Member
    NY
    Eibach Stage 2 lift. Pro front grill. Sound deaden doors, cargo area, and rear tailgate. Diode Dynamics fog lights. Anytime front camera connected to Kenwood head unit. Kicker sub and amp. GX rear bump stop and Energy Suspension front bump stop. FJ cruiser shift knob, rear molle panels, black paint climate control knobs. Sherpa crestone roof rack.
    I have a pro rack with an aluminum faring but no light bar. I am curious of real world light output. I may drop one in the future.
    Grandpawmoses likes this.
  9. Nov 11, 2024 at 7:22 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    What fairing and mount did you use? I'd like to put one on my Pro rack. Thanks in advance.
