Lifting OffRoad Premium with KDSs
Discussion in '5th Gen 4Runners (2010-2024)' started by Jpcannavo, Mar 31, 2018.
  1. Mar 31, 2018 at 5:23 PM
    Jpcannavo
    Jpcannavo [OP] New Member
    Joe
    Hi all newbie with a lot to learn. I live in Colorado, serious mountain biker but new to off roading. I was ready to pull the trigger on a new TRD Pro, but test drove it against a new OffRoad Premium (ORP) with KDSS (stock suspension and tires). The ride on the highway was smoother on the ORP. So I am pulling the trigger on it, and plan to make after market mods. I will upgrade wheels and tires (Falken Wildpeak M/T?). But where I get confused is with the shocks and lift. Apologies if this has been covered elsewhere, but I am still trying to get it all straight. What I can’t seem to get clear on in reading through various threads is if the Bilstein suspension/lift setup on the TRD Pro would be compatible with KDSS as an aftermarket mod, or even desirable. And, if not how best to proceed ?
    Joe
  2. Mar 31, 2018 at 6:37 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Yes you can lift a KDSS Runner. Not much different than lifting one that does not have KDSS. About the max lift you want to go with either is 3". Pretty much the same kits work for both. How much do you want to spend? What are you going to use it for?
    POWERPLANTHOMER likes this.
  3. Mar 31, 2018 at 7:24 PM
    4X4Runner
    The left coast
    Example of a 4Runner TRD OR Premium with KDSS that’s got a suspension upgrade. Sitting at about 3.25” over stock height with 285/70-17 BfG AT KO2’s under it.
    1337DB72-D647-406C-A5EC-E72DB85A52E4.jpg 4C80CDC3-7237-4B0C-9EBD-EC09D7CB8DB2.jpg
  4. Mar 31, 2018 at 7:42 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    That looks great!!!!!
  5. Apr 1, 2018 at 6:16 AM
    billnourse
    billnourse New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    I have a Toytec Ultimate on my ORP with KDSS. Works just fine.
  6. Apr 1, 2018 at 8:01 PM
    4X4Runner
    The left coast
    As she sits today.
  7. Apr 1, 2018 at 11:38 PM
    Jpcannavo
    Joe
    Look is awesome! Appreciate responses. As for my plans/uses, mostly green Laning and perhaps some rock crawling as my skills develop. Becoming more inteteted in the BFG AT KO2’s. 4x4 runner, what load capacity are those and how do they feel on pavement? Also,wondering how much lift the 285s require. On interesting thing.
  8. Apr 2, 2018 at 5:22 AM
    4X4Runner
    The left coast
    I went with load range E on the tires and I used the medium duty OME coils. Considering I have the roof rack, tent, fridge and drawers it’ll support the weight. I’m looking into a dual batter setup and installing a twin compressor under the hood.
    My OME kit netted me 3.5” initially and I think it’s settled down to 3.25” before adding weight
  9. Apr 6, 2018 at 8:49 PM
    browndirtcowboy
    browndirtcowboy New Member
    king 3" lift kit, fuel vectors, 285 toyo mt's, oem audio 500q, morimoto hid headlights, morimoto led fogs,
    I just got the king lift kit especially for the 4runner with kdss. It rides amazing. Ive had Fox dsc coilovers , toytec boss, icon stage 3. But none ride remotely close to the king setup with Total chaos UCA's Running 285/70 17 Toyo MT's. Ive ran every tire worth mentioning on my 2011 taco, 2013 rubicon, 2016 taco and nothing is as tough as toyo and as quiet on road as a toyo Mud tire. DO you pay a lot for it? YES it is worth it YES. SHarp rocks , broken bottles running through branches and anything you can throw at it. I could never even manage to get a slow leak. My 2 cents.20180331_162826.jpg
    DrewMan likes this.
  10. Apr 27, 2018 at 9:26 AM
    knowonecares
    knowonecares New Member
    LB
    2018 4Runner TRD OR Prime
    TRD Pro Grill, N-Fab Nerf's
    I'm looking into a lift for my '18 T4R TRD OR Premium. Any links to your King kit? And how much would it cost to have someone install it (im in no position to do that myself), and if it would void any warranties. Thanks for the info, looks friggin sweet.
  11. Apr 27, 2018 at 7:57 PM
    browndirtcowboy
    I got my lift here...
    https://pure4runner.com/king-shocks...8.html?zenid=5a237f7085c16528b183632bfef67d7d
    It shouldnt void any warranty. Your rig will ride better than stock. I have kdss and thought the ride would be too stiff, its not at all. comfortable and solid.
    The Labor will run around 800 to 1k.
  12. Feb 15, 2021 at 3:42 PM
    Wickdog
    Wickdog New Member
    16 4Runner Trail Premium (Mag Gray Metalic)
    None
    I installed the Bilstein 6112/5160 lift (2 1/2-1.0) and love it. I might replace the rear coils to compensate for the RIGd UltraSwing tire carrier, but that decision has been made yet.
  13. Feb 15, 2021 at 4:07 PM
    Talk to a shop like Toytec or RSG Offroad they knows how to lift KDSS without KDSS lean or any other issues. Discuss about the size of tires you want to run, weight you want to carry, the budget you are looking at. I have installed $400 (parts only) spacer lift to $4200+ (parts only) ELKA lift for non KDSS 4Runners. These shops will have lot of options. At least Toytec explains me why one option is better than the other, etc..
    If you don't have winter tires or work from home during snowy days I don't think M/Ts are a good option for Colorado. All terrain tires with 3 peak mountain snow flake ratings would be good for driving on i70 in Winter. But still they are no match for a "All Weather" tire or "Winter" tire, you just have to drive carefully with plenty on gap.
  14. Feb 15, 2021 at 4:15 PM
    Those OME are insane. I was so confident on abusing them on trails and also amazing on curvy mountain roads. The only reason I changed them is because I wanted little more on road comfort.
