Lift Tire Size
Discussion in 'Wheels & Tires' started by AmazerTazer06, Dec 6, 2021.
  1. Dec 6, 2021 at 10:38 AM
    AmazerTazer06
    AmazerTazer06 [OP] New Member
    Taylor
    2017 White SR5
    I recently upgraded my tires to KO2's stock size (265/70R17), but now I would like to add a 2 inch lift. Will my tires look too small with the lift addition? Should I get sell the new tires and upgrade to a larger size?
    2Toys likes this.
  2. Dec 6, 2021 at 11:01 AM
    I would run the KO2's and focus on other mods, ie armor, recovery gear, or whatever else you're planning. Then upgrade the tires when the KO2's wear out.
    Just my .02.
  3. Dec 6, 2021 at 11:05 AM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    Probably, I am in a similar situation. I am planning on a 2" lift in the spring of '22 and I am concerned that my 275's will look out of proportion.
    AmazerTazer06[OP] likes this.
  4. Dec 6, 2021 at 11:42 AM
    Jason73
    Jason73 New Member
    Jason
    2021 4Runner TRD
    265 will not look too small. Especially when using a good AT tire.
  5. Dec 6, 2021 at 11:48 AM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    lots of people run stock size or 275's with a small lift.... it looks just fine, especially if the tires are on the more aggressive side. that being said, I'm going up to 285's immediately when my suspension finally gets delivered even though I only have 7000km's on my stock size general grabber ATX's. if you search around I believe there is a thread with pictures of stock size tires with a lift to give you an idea.... some look good, and some bad (usually when they are on the factory tires. those things suck).
  6. Dec 6, 2021 at 1:56 PM
    @AmazerTazer06 here is mine right after the lift on stock size KO2's. 2.4" front, 1.5" rear.
  7. Dec 6, 2021 at 3:44 PM
    I think it looks fine.
    2Toys and Thatbassguy[QUOTED] like this.
  8. Dec 6, 2021 at 3:50 PM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    Do/did those rims push the tires out a bit more?
  9. Dec 6, 2021 at 5:25 PM
    Yes. They're -6 offset, which pushed them out a little under an inch from stock.
    banjos-n-beer[QUOTED] likes this.
  10. Dec 6, 2021 at 7:53 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    a few goodies
    I run 275s with a bit less than 2" lift and they look great.
  11. Dec 6, 2021 at 10:27 PM
    Here’s mine, stock size KO2s. The lift ended up being almost a 3in/2in lift.
    To be fair, it’s sitting lower (above) since it’s loaded down.
    Here it is with no cargo.
    Eventually Ill get 285s
  12. Mar 13, 2022 at 1:52 PM
    SkippyRunner
    SkippyRunner New Member
    2020 4Runner TRD
    Hey @2Toys - so the 275's look good...I'm about ready to pull the trigger on a 2" lift and larger tires. Do the 275's perform well with no rubbing?
    Can anyone else weigh in on tire size for a 2020 TRD Premium with a 2" lift?
  13. Mar 13, 2022 at 3:42 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    a few goodies
    When I first put them on, there was a little rub at full steering lock while backing up in reverse. A little trim of the forward side at the bottom of the wheel well took care of some of it. I should have left it alone at this point. A few months ago, I decided to replace the upper control arms with SPC UCAs from Toytec lifts to try to get rid of the small rub. The alignment shop was in a big hurry (end of day) and did not adjust the caster on the left front like they did on the right. Now I have a good rub on the rear fender well at the splash guard / mud flap. I have not put very much mileage on the truck over the winter, but I plan to have this resolved this week.
  14. Mar 13, 2022 at 4:12 PM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    Not at all. While I'll put larger tires on next time around, just like @McSpazatron, I don't think it looks out of place at all. 2.5/1.5 lift here.
    Thatbassguy and McSpazatron like this.
  15. Mar 13, 2022 at 5:53 PM
    SkippyRunner
    2020 4Runner TRD
  16. Mar 15, 2022 at 5:24 PM
    RaverJack17
    RaverJack17 New Member
    Joe
    2022 4Runner Trail Edition Army Green
    3" Lift and Tires
    What's the largest diameter tire can I go with after a 3" front and 2" rear lift? I was thinking the yokohama geolanders
  17. Mar 15, 2022 at 9:00 PM
    RaverJack17
    Joe
    3" Lift and Tires
    Mt's
  18. Mar 15, 2022 at 9:17 PM
    They're awesome! These are 295/70/17. I have a body mount chop, modified fender liners, and front mudflaps removed. Lift is 2.3/1.5"
    4runner2017ltd and nimby like this.
