Lift suggestion for daily driver?
Discussion in 'Suspension' started by gagnon18, Jun 2, 2021.
  1. Jun 2, 2021 at 7:19 AM
    gagnon18
    gagnon18 [OP] New Member
    2021 sr5 premium
    Hi
    I just got my first 4Runner. I’m not experienced with lifting or tires or anything like that. I have stock tires but would like to lift the truck a little. Any recommendations? I don’t do off roading so it’s just for looks. Also was wondering if anyone’s had a mechanic install their parts for them because I don’t know how but I know it’s cheaper to buy the parts yourself.
    TrailSpecial22 and Thatbassguy like this.
  2. Jun 2, 2021 at 7:31 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Buy a spacer kit take it to your favorite mech done...next
  3. Jun 2, 2021 at 7:57 AM
    Welcome to the forum, i agree with ruiz4251.
    Toy4X4 and ruiz4251 like this.
  4. Jun 2, 2021 at 8:11 AM
    gagnon18
    2021 sr5 premium
    Thank you, do you recommend any certain spacer kit?
  5. Jun 2, 2021 at 8:14 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Toytec 2.5" front, 1.5" rear. This is probably the most common and sets the truck in a nice level, more aggressive looking stance.
    You're going to want bigger tires though because the stock 265s will look wrong with a lift.
  6. Jun 2, 2021 at 8:25 AM
    gagnon18
    2021 sr5 premium
    Ok. What size wheels would you recommend with those spacers? Do I need to buy coils as well or just the spacers? I appreciate your help
  7. Jun 2, 2021 at 8:48 AM
    You don't need coils with a spacer lift. If you're happy with the stock ride quality, it's the most economical solution.
    For wheels, I prefer 17's. If you prefer a bigger wheel, I would stick to 18" or 20" tops. Don't go too wide, 8-9" wide is ideal. Stay close to 0 offset for the best chance at not rubbing.
    Toy4X4 likes this.
  8. Jun 2, 2021 at 8:56 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Tires, not wheels. Although even that is your preference, I just think the stock tires looks small with a lift. The most common tires-after-2.5" lift are 285s (33" tires).
    The spacer kit comes with what you need... essentially 4 spacers. One for each coil / coilover. You use all parts of your existing suspension and you don't "replace" anything, you just are adding spacers to the existing assembly.
    This is my former 2014 TE with the described Toytec kit and 285s:
    POWERPLANTHOMER and Thatbassguy like this.
  9. Jun 2, 2021 at 9:00 AM
    I didn't even consider the possibility that was what @gagnon18 meant. In that case, I would agree to go 285/70/17 or 275/70/17.
    Toy4X4 likes this.
  10. Jun 2, 2021 at 9:02 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Well he was quoting me and my post mentioned "tires" so I just figured he was lumping "tires" and "wheels" together
  11. Jun 2, 2021 at 9:40 AM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Everything everyone is saying!
    Like the way yall think
    Nothing wrong with just wanting a nice look
    1.25" wheel spacers with OE wheels
    275/70's will work fine imo
    Dont forget positive caster
  12. Jun 2, 2021 at 9:44 AM
    If you don't go off-road I think a spacer lift like ReadyLift which Toyota dealerships use would be a safe bet. I really like the ride comfort (I prefer soft suspension).
    I also like BIlstien 5100. They are slightly firm than ReadyLift kit that uses stock shocks.
    I have also like expensive & complicated suspension like ELKA 2.5 remote res adjustable suspension which are not needed for non-offroad.
  13. Jun 2, 2021 at 9:51 AM
    275/70r17 does not have much tire options right? I don't see any SL rated tires. The softest I see is Falken Wildpeak Load C. Rest seem to be Load E which will be worst in comfort.
  14. Jun 2, 2021 at 10:13 AM
    This is the downside of that size. It's too bad because it seems to be a great size at stock height or with a smaller lift. It almost makes more sense to go 285 in SL and clear any rubbing.
  15. Jun 2, 2021 at 10:31 AM
    If you ask me spacer lift is not good for a dd. Unless you like stiff suspension.
  16. Jun 2, 2021 at 12:00 PM
    I wish I have my SR5 with space lift to test back to back but on top of my head my SR5 with spacer lift was fraction softer than TRD Pro Fox suspension on road. But if I go over a speed bump little faster TRD Pro Fox absorb it better.
  17. Jun 2, 2021 at 12:16 PM
    thkbaron
    thkbaron New Member
    So I wanted to ask a question here and sorry if I'm hijacking this thread, but I've lifted a lot of vehicles and there's always talk about when you use a spacer lift (level kit) or whatever you want to call it, it increased the angle of your CV joints on the front. I don't seem to see a lot of talk about that. I know on my Silverado 2 inch was ok but anything higher than that you really put stress on those joints. Is there something I'm missing on the 4runner?
  18. Jun 2, 2021 at 12:20 PM
    CV angles are affected by a suspension lift as well. Above a certain height, some will add a front differential drop. I have a little less than 2.5" up front and my angles are good.
  19. Jun 2, 2021 at 12:24 PM
    thkbaron
    thkbaron New Member
    Good info then for the original poster.
  20. Jun 2, 2021 at 12:33 PM
    It's definitely something to take into consideration. Also another benefit to a modest lift.
  21. Jun 2, 2021 at 1:15 PM
    thkbaron
    thkbaron New Member
    Yeah I’ll just be doing a 1 inch front is all when we get ours.
  22. Jun 2, 2021 at 2:37 PM
    I've had both. Will never use a spacer lift ever again. Its not comfortable at all and if anyone tells you it is they are just fooling themselves.
    Now I'm not saying buy a $3k+ suspension. But don't just stick a hockey puck under there and call it a day.
  23. Jun 2, 2021 at 2:53 PM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    OP...this is my 4Runner with 2.5" lift in the front and 1" lift in the rear. These tires are 265/70/17 (stock size) on a more aggressive offset wheel than stock. Many say 265's look small with a lift...I disagree. A more aggressive tire on a more aggressive wheel makes a big difference in the appearance...
    GtownRunner, Han4Run, Kfish and 8 others like this.
  24. Jun 2, 2021 at 3:10 PM
    thkbaron
    thkbaron New Member
    Yes suspension is a pile better although a one ☝️ much spacer probably isn’t a huge deal.
  25. Jun 2, 2021 at 3:17 PM
    Mine got ReadyLift kit 3in front & 2in rear with 265/70/17 (stock size) KO2 Load C.
    265s doesn't look bad but 285s are best looking imo.
    ruiz4251 and Thatbassguy like this.
  26. Jun 2, 2021 at 3:17 PM
    It should ride exactly like stock. If someone is satisfied with the stock suspension, they should be fine with a spacer lift.
  27. Jun 2, 2021 at 5:00 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    I think your correct, because it IS still stock right :cheers:
  28. Jun 2, 2021 at 5:43 PM
    Don't lie to yourself sorry. Doesn't ride like stock.
    But whatever he wants to do.
  29. Jun 2, 2021 at 5:45 PM
    thirdyota
    Brian
    Cincinnati, OH
    IMO your lift is too high for 265's and I dislike the stock SR5 wheels no matter what tire you put on them.
    That's one of the nice things about 4Runners...lots of different options for modding them :cheers:
  30. Jun 2, 2021 at 5:56 PM
    Lie to myself? Why would I care?
    You're literally putting spacers on top of the struts and springs. How could it ride any different?
