Lift kit vs leveling kit
Discussion in '5th Gen 4Runners (2010-2024)' started by Cfahnestock, Apr 19, 2025.
  1. Apr 19, 2025 at 12:02 PM
    Cfahnestock
    Cfahnestock [OP] New Member
    Chris
    2022 Toyota four runner TRD Sport
    20 in rims to 17 in rim, 24560r20 to a 26570r17
    On the fence on if I need to do a full on lift kit or is a leveling kit good enough. Any thoughts? I don’t off road, it’s cosmetic only.
  2. Apr 19, 2025 at 12:18 PM
  3. Apr 19, 2025 at 12:36 PM
    Do you ever park in underground parking?
  4. Apr 19, 2025 at 2:37 PM
    If it's for cosmetic purposes only, get a leveling kit or upgrade your tires. That's what I did. I got rid of the street tires and slapped on some Falken Wildpeaks. The "Stance" is much better now.
    Before:
    After:
  5. Apr 19, 2025 at 8:36 PM
    Cfahnestock
    Chris
    Ya. I went with the wild peaks as well!!!! Looking at Rough Country brand on the kits. Anyone have any other suggestions.
    Thacrow likes this.
  6. Apr 19, 2025 at 10:22 PM
    I heard stay away from rough country.
    I'd just level it (buy some hockey pucks lol) if you want that stance
    Cfahnestock[OP] likes this.
  7. Apr 19, 2025 at 10:38 PM
    Just put some good tires on it and you’re good.
  8. Apr 19, 2025 at 10:48 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Bilstein 5100s up front. Dial in 0 or .85 in or 1.75 in or 2.5 in whatever looks good to you. Leave the rear alone. $280-ish and you're done.
  9. Apr 19, 2025 at 11:17 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Choosing between a rough country lift and doing nothing, I would do nothing.
    To somewhat level keeping stock springs, Bilstein 5100s or Eiback Pro Truck shocks at the 1" perch up front is good bang for the buck IMO.
  10. Apr 20, 2025 at 3:59 AM
    broken-giver
    broken-giver BFD
    bilstein 5100s is I think absolute cheapest way to go, if you don’t want to do leveling kit. For me they were $800 or so installed, I think. The factory struts are too soft, upgrading that for me was worth it. I also wanted somewhat level stance so went with 0.85, some people go higher.
  11. Apr 20, 2025 at 4:30 AM
    Welcome from Wisconsin! As long as you don't off-road go for the leveling kit. Even after the leveling kit, if you decide to off-road... GO. We had a leveling kit at first from new to see how it sat, and went off-road with it, nothing too difficult. I liked the fact that the ride was smooth, like factory, but with some draw backs... body roll, front dive during moderate braking. Now with a Bilstein suspension upgrade.. none of that. Just thought I'd point out both sides, good luck on your choice.
  12. Apr 20, 2025 at 4:53 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Here are some pics I shot just last week of my 2022 SR5 Premium 4WD.
    I had our local off road 4WD shop install a front pair of Bilstein 5100 shocks set to raise the front 1.75”. I kept the factory front coil springs. I did nothing to the rear shocks or springs yet. They are still factory.
    I went to factory size 265/70 R17 SUMITOMO ENCOUNTER AT tires in the SL load rating. SUMITOMO Rubber Company owns Falken Tire. My tires were made in Thailand. (I figured just as long as they did not say made in China on them, lol.)
    When buying tires, be sure to know how to check the manufacturing date codes stamped on EVERY tire. You don’t want to get stuck with real old tires. My tires were only three months old when I bought them. Pretty good, I thought.
    I like the way the Bilstein 5100s feel and ride. The SUMITOMO tires ride really nice and look good to me. I am not currently using my T4R for off roading. If I ever do, I don’t foresee it being anything very radical at all. I do however “exercise” / activate the 4WD system on a monthly basis to help keep it in working order. I drive slow when in 4L, and do not turn sharply. Likewise, when exercising 4H, I do so on relatively straight roads, no sharp turns on dry pavement. All seems well.
    I run empty (no weighty payloads of any consequence in the rear cargo area) the majority of the time. Keep in mind that if you lift the front end such as with these Bilstein 5100s, if you place a lot of payload weight in the rear of your truck, the rear suspension will squat down some, (I believe it’s called “negative rake”), and that may then be an undesirable look for you.
    I may eventually have something done to the rear suspension to beef it up / raise it slightly.
    Also- After my shop replaced the front shocks, they recommended a front end alignment, which I agreed to. I’m very happy with the whole deal- appearance-wise, and driving-wise.
  13. Apr 20, 2025 at 5:11 AM
    If I had the choice to choose between a Rough County Lift or a Rectal exam by Edward Scissorhands, I would choose the exam.
    Remember, they're called "Rough" for a reason. Just stick with swapping out tires.
  14. Apr 20, 2025 at 5:17 AM
    Rick G.
    BLKNBLU, Where, praytell, did you get such work done for “$280-ish”? My local 4WD shop charged me north of $800.00 for the front Bilstein 5100s installation, parts and labor, which included front end alignment.
    broken-giver likes this.
  15. Apr 20, 2025 at 5:47 AM
    That's just for parts, and ONLY for the fronts.
    https://www.suspensionlifts.com/sho...6xU_hOklHTDX77o3jJuBrh660ukqKKDAaAgEEEALw_wcB
    I think that's what BLKNBLU was referring to, and I think he installed his himself. If he got the install done for $280 then he probably traded sexual favors to get that price. If he did, hey...no judgement. We've all whored ourselves out.
    Imdav2u likes this.
  16. Apr 20, 2025 at 6:47 AM
    Rick G.
    OK, that could be. Thanks Borracho. If DIY is the case, I understand. I’m not equipped to handle such a job, plus my age. Lol. It also seems it could be a potentially dangerous DIY job. No way would I want to mess with those front springs trying to force shocks in to them at my old age.
  17. Apr 20, 2025 at 6:58 AM
    Yeah, this is one of those jobs I would happily pay someone else to do. I don't want to lose any fingers trying to attempt it.
  18. Apr 20, 2025 at 7:54 AM
    stay away. Go with a simple Bilstein 5100 kit and reuse stock springs.
  19. Apr 20, 2025 at 8:43 AM
    BLKNBLU
    BLKNBLU New Member
    Yes. Parts only and fronts only.
    And at my age sexual favors is no longer a viable currency.:rofl:
    Slopemaster likes this.
  20. Apr 28, 2025 at 6:57 PM
    Cfahnestock
    Chris
    Thanks all. New to four runners and this forum. Love em both!!!
  21. Apr 28, 2025 at 9:54 PM
    Hold on a minute! No mention has been made whether @Cfahnestock is ready to ditch the XREAS system on his 2022 Sport to throw Bilstein, Eibach, or any other shocks on there...
  22. Apr 29, 2025 at 4:23 AM
    Black23TRDPremium
    Black23TRDPremium New Member
    Hoza
    TRD Premium
    2023 Black 4Runner with a leveling kit
    Welcome.
    I had my 23 TRD ORP leveled with ToyTec spacers by the dealer in Tx at time of purchase. I did not like how it 'nose dived" when braking and it felt top heavy all the time. I researched suspensions for a few months and then used the valuable expertise these fine and upstanding members of this forum offered - and I ended up getting the Eibach Pro truck stage 2 kit from Eibach when they were running a 15% off spring sale last month, and I also re-installed the rear coil spring spacer onto the Eibach lift coils. I did the install myself. I installed a set of Nitto Terra Grappler G3's 285/70R17.
    Cfahnestock[OP], Tmel and hossler1788 like this.
  23. Apr 29, 2025 at 5:45 AM
    BLKNBLU
    BLKNBLU New Member
    I did not realize the sport package included xreas. You are correct that will be a major consideration for the OP.
    Black23TRDPremium likes this.
  24. Apr 29, 2025 at 6:16 AM
    In reading through this thread I didn't either, then it dawned on me that the Sport is that model that has XREAS and the body of a Limited, but no leather or full-time 4wd...
  25. May 8, 2025 at 7:03 AM
    Tmel
    Tmel New Member
    Travis
    2024 4Runner TRD Off Road Premium Metallic Blue
    Hello, I have a 24 TRD ORP and was thinking of going with the same lift. Do you mind telling me how high you have the front set and if you installed aftermarket UCA's? I'm trying to stay in the 2" of lift area due to parking garage limitations. Looks great by the way.
  26. May 16, 2025 at 2:49 PM
    Black23TRDPremium
    Hoza
    TRD Premium
    I have my front set at 2.50 inches and I installed a set of Freedom Offroad UCA's. I will add that the TRD roof rack barely clears the garage door. That had not crossed my mind until completion and after new taller tires.
  27. May 16, 2025 at 4:55 PM
    Purely for looks, Go with a spacer as it fits your exact needs.
  28. May 16, 2025 at 5:21 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    I am thinking of shock surplus bilstein 6112 prebuilt front shocks for a good while.
