Leveling Options, after C4 Lo-Pro Front Bumper and Winch?
Discussion in '5th Gen 4Runners (2010-2024)' started by jtice, Dec 17, 2018.
  1. Dec 17, 2018 at 11:14 AM
    jtice
    jtice [OP] New Member
    West Virginia
    2016 SR5
    Eibach Pro Truck Lift, 255/75/R17 BFG K02s, TRD Pro Wheels, C4Fab Front Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, BajaRacks Rear Hatch Ladder, SSO Roof Rack, RCI Full AL Skids
    Getting a 5th Gen 4Runner SR5 soon, and I plan to run a C4 Lo-Pro front bumper and a synthetic roped Smittybilt winch.
    So that is in the ballpark of 90 to 100 lbs added to the front end. (accounting for how much weight you remove for install)
    I also plan to run Rocky Road Rock Super Sliders, which are about 90 lbs.
    Also plan to run 255/75/R17 KO2 Tires.
    What are some good options for leveling the front end, that will also handle the weight well?
    I know alot of people run the Bilstein 5100s up front, and with the added weight, probably set them to the 1.85" position?
    But, that would still be on stock coil springs, will they handle the added weight well?
    Or am I going to have to jump up to a much more expensive option, like the ? Hoping not.
    Keeping a sliiiiiight rake is ok, so it still sits level when loaded with camping gear,
    But far less rake than factory.
    Strandskov likes this.
  2. Dec 17, 2018 at 11:24 AM
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    I put on Blistein 6112 set at second circlip for an 1.4” lift with KDSS. I added a X20 Smittybilt with synthetic and a Greenlane aluminum bumper and sliders along with RCI full skid aluminum. I sit pretty much level.
    The Blistein have new coils and a larger bore strut.
    WallyT4R, jgcaps and Strandskov like this.
  3. Dec 17, 2018 at 11:34 AM
    jtice
    West Virginia
    2016 SR5
    I figure your aluminum bumper is about 30 lbs or so lighter than the C4 Fab bumper.
    You have the most rake I would want, slightly more than I want maybe.
    I saw the 6112s mentioned before in another thread, but didnt realize they were also a stiffer spring rate.
    Looks like they also have more adjustment grooves, so more options to get it dialed in, level wise.
    Least those are almost $300 cheaper than the ToyTec option.
    Im not looking to go cheap, but at the same time, well, you know, stuff adds up quick.
  4. Dec 17, 2018 at 11:44 AM
    Living the dream
    ABQ
    The Greenlane bumper comes in at 43lbs. If I had to do it all over I probably would go up one more notch to put it at 1.7”. Though I am not hating the 1.4”. I figured once we load it up with camping equipment and a couple hundred pounds of dogs it will sit level.
  5. Dec 17, 2018 at 2:09 PM
    WallyT4R
    WallyT4R New Member
    Just adding shocks that increase the preload to level out the vehicle does not help you carry more weight. Springs carry the weight. Shocks dampen the weight. To carry more weight you need to increase the spring rates. Have you looked into a standard OME setup?
    Deadpooly6 and (deleted member) like this.
  6. Dec 17, 2018 at 2:35 PM
    jtice
    West Virginia
    2016 SR5
    The only OME setups I saw were complete lifts, that looked to be 3"?
    That more lift than I am wanting or needing. Not sure I really need to lift the rear at all, just mainly the front,
    and like you say, the front coils will need to be replaced, which I figured was the case, just wasnt sure what options were out there.
    Plenty of options for more involved, expensive and taller lifts, but wasnt sure what people were doing for mainly leveling with additional weight.
  7. Dec 17, 2018 at 3:38 PM
    Living the dream
    ABQ
  8. Dec 17, 2018 at 5:16 PM
    jtice
    West Virginia
    2016 SR5
    Thanks I will look into the OME more. Ran them on TJs in the past and liked them.
    Shame it doesnt have adjustable height like the others though.
  9. Dec 17, 2018 at 5:43 PM
    WallyT4R
    WallyT4R New Member
    Could also call Dobinsons.
    Strandskov and eaglescout like this.
  10. Dec 18, 2018 at 11:04 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    I would look into the Eibach pro truck kit as well. We have installed numerous and everyone has been happy.
    scottalot and Strandskov like this.
  11. Dec 18, 2018 at 12:08 PM
    jtice
    West Virginia
    2016 SR5
    Unless I am missing something, the Eibach 4Runner springs say they are 2.75" lift?
    Way more lift than I need to run 255/75R17s. Plus I dont want to go over 2", so I dont run into alignment issues and need to swap out upper or lower A arms.
  12. Dec 18, 2018 at 12:29 PM
    You could get the Eibach shocks and set them at the 1.6" setting.
    Ask Eibach if they have any coils that are stock size that will handle the additional weight you've added. They might have something.
    I have these shocks with stock coils (no additional weight) and I'm very happy with the ride.
  13. Dec 18, 2018 at 1:56 PM
    Mike's Custom Toys
    This is the Pro truck kit installed on a new 4Runner with stock uppers it aligned just fine.
    scottalot, jgcaps, WallyT4R and 2 others like this.
  14. Dec 18, 2018 at 2:44 PM
    jtice
    West Virginia
    2016 SR5
    Has a nice stance to it, what size tires are those?
  15. Dec 18, 2018 at 3:40 PM
    Mike's Custom Toys
    They are 265 70 17
  16. Dec 19, 2018 at 6:08 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    It looks a tad higher in front. Wondering what happens when you load it up in back.
  17. Dec 19, 2018 at 6:45 AM
    Mike's Custom Toys
    Its not higher up front. The driveway is slanted a bit
  18. Dec 23, 2018 at 3:07 PM
    browndirtcowboy
    browndirtcowboy New Member
    king 3" lift kit, fuel vectors, 285 toyo mt's, oem audio 500q, morimoto hid headlights, morimoto led fogs,
    After my bumper and winch my front sagged. I had to take my king coilovers and replace with 700lb King springs to get the rig back to level. Wheelers offraod carrys them.
  19. Jan 7, 2019 at 8:57 AM
    jtice
    West Virginia
    2016 SR5
    Do you remember what notch setting you set the front shocks to?
    Love the stance of this, but with the added weight of bumper and winch, Im betting I might need to set it one notch higher than you did.
    Have you installed this kit on any 4Runners with bumper and winch?
    And just to confirm, you are talking about this kit, correct?
    http://toyteclifts.3dcartstores.com...ck-Lift-System-Stage-1--104Runner_p_1952.html
  20. Jan 7, 2019 at 9:11 AM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    I have a 3” lift, but toyotech works amazing.
  21. Jan 7, 2019 at 9:23 AM
    jtice
    West Virginia
    2016 SR5
    I hear alot of good things about the Toyotechs, but thats more lift than I want, or need, dont want to get into replacing control arms, etc.
    I will just be running 255/75/R17 tires.
  22. Jan 7, 2019 at 9:28 AM
    JBTRD
    Jeremy
    Ohio
    It may be hard to find a 700lb coil with a level kit, i think dobinsons has something like that. I was at a 50-50 with toytech and dobinsons when i was looking for something for my bumper and winch
  23. Jan 7, 2019 at 9:49 AM
    jtice
    West Virginia
    2016 SR5
    Read in another thread the Eiback springs are 660 lb/in. front and 205 lb/in rear.
    WallyT4R likes this.
  24. Jan 7, 2019 at 11:01 AM
    Mike's Custom Toys
    Fronts are set at zero. I would put it up one notch. We have used these on tacomas with bumpers and a winch but not 4runners yet. Yes that is the kit. We sell it as well.
    jtice[QUOTED][OP] likes this.
  25. Jan 8, 2019 at 12:17 PM
    JBTRD
    Jeremy
    Ohio
    Right toytech offers a 650lb and 700lb as do most companies. 700 may hold the weight better than a 660lb. Also if you want to add more weight in the future 700lb is the way to go.
  26. Jan 9, 2019 at 6:09 AM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    This, put the whole kit on could not be happier. Summit bumper and Smittybuilt with rope. Front clip set on second ring.
    Got rid of the body roll and nose dive when braking, rides tons better and handles so good you can feel the rack and pinion steering!
    WallyT4R, nimby and scottalot like this.
  27. Jan 9, 2019 at 8:12 AM
    jtice
    West Virginia
    2016 SR5
    Thanks for the input, been wanting to hear from someone that has this kit AND some bumper/winch weight up front.
    Setting it to the second notch is what I have been thinking would work out well. My bumper will be a bit lighter, but still looks like it should work out well.
  28. Apr 10, 2019 at 6:35 AM
    jtice
    West Virginia
    2016 SR5
    Guess I should update my own thread.
    This all ended up working out great. Rides better than stock. "Stiffer" in ways, but still sucks up the bumps, nose dive is gone, and just has a more planted secure feel.
    Driveway is a bit off level so it may look odd, but the 4Runner is setting pretty much dead level.
    Eibach Pro Truck Lift (coils and springs) Front set to second notch.
    TRD wheels with 255/75/R17 KO2s
    C4Fab Bumper with Smittybilt 9.5 Winch
    Rocky Road Rock Rails
    DRobs, nimby, SlvrSlug and 1 other person like this.
  29. Apr 10, 2019 at 7:59 AM
    WallyT4R
    WallyT4R New Member
    Very nice! I just bought the same kit but since I will be carrying 300-500 lbs on a constant basis and towing a trailer often, I purchased a stiffer OME rear coil per recommendation from Wheelers. The OME rear coil is 265 lbs vs the stock Eibach at 205. I will have a rake but this better suits my application. Do you feel the need for upper control arms? I'm thinking about just going ahead and getting a set. Also do you have a diff drop or think it needs one?
    nimby likes this.
  30. Apr 10, 2019 at 8:20 AM
    jtice
    West Virginia
    2016 SR5
    I have alittle added weight, but not very much, and more to the front, so this seems to work out well for me.
    No idea what it will do with a trailer though. But, I dont do that often enough to matter.
    Mine aligned just fine with stock arms, and no drop.
    Eibach says you dont need any of that with this kit, and that seems to be true.
    Some have done UCAs to be able to have more adjustment and more caster, etc.
    But mine seems to drive fine the way it is.
    WallyT4R[QUOTED] and nimby like this.
