lets talk pedal commanders and tunes
Discussion in '4th Gen 4Runners (2003-2009)' started by FoRunna414, Feb 11, 2025.
  1. Feb 11, 2025 at 8:44 AM
    FoRunna414
    FoRunna414 [OP] New Member
    Andrew
    06 Sr5
    full rebuilt bottom end, Kelford 256 cams, port and polish heads with NA Supra springs and retainers, exhaust cam gear, JBA headers, custom 2.5 stainless steel exhaust, AFE 76mm throttle body, AFEMagnum stage 2 intake, drilled and slotted rotors...and more to come.
    Have a 06 v6 with performance mods and looking for info on pedal commanders or a good tune.... Pros and cons. which are reliable and wont put my truck into limp mode or mess anything up. Banks, Hypertech, Bullydog etc. what's everybody using. TIA
  2. Feb 11, 2025 at 8:50 AM
    andrewtheadventurer
    Pedal commander has iffy reviews. I have a 5g and put the banks performance pedal monster on it to help with acceleration lag when towing. I liked the safety features of it vs other pedal modules. To my surprise, the pedal response is very noticeable. No more lag. Works great from a stop and rolling (example - getting up to speed for an interstate). Overall, i am happy with it. I am running it at Sport 50% with a 3500# trailer. Without the trailer, its peppy so i have to be soft on the pedal so i could reduce the levels but it doesn’t bother me. Set and forget is better for my situation
    FoRunna414[OP] likes this.
  3. Feb 11, 2025 at 8:51 AM
    FoRunna414
    Andrew
    06 Sr5
    heard and read the same thing about pedal commander
  4. Feb 11, 2025 at 8:54 AM
    Pedal Pretenders - Move your foot faster for the same effect
    Tunes - Better if available and you will actually pick up power unlike a pedal pretender.
    /End talk
    RUNNER4DAN and FoRunna414[OP] like this.
  5. Feb 11, 2025 at 8:55 AM
    andrewtheadventurer
    False.. lag is still there when you “move your foot faster” and stomp on the pedal. Source - my vehicle and my experience
  6. Feb 11, 2025 at 8:57 AM
    Had a PC on my 19 for 3 years. I turned it off and simply moved my foot faster and it's like you have it on. The lag is built into the vehicle's software so you aren't removing it with a pedal pretender.
  7. Feb 11, 2025 at 8:59 AM
    andrewtheadventurer
    Okay, we have both shared our experiences. Im not going to argue. OP can make his own choice
    Two4Runner, michow87 and Jynarik like this.
  8. Feb 11, 2025 at 8:59 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    PC electronically changes the input from the pedal. I loved mine and would recommend if you don’t want to spend the money on a tune.
    Gman2530 likes this.
  9. Feb 11, 2025 at 9:00 AM
    Up, down and all around!
    Tunes get you past lag and also fixes 'gear hunting', the PC can't do the latter at all.
  10. Feb 11, 2025 at 9:00 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2023 4Runner TRD Off Road Premium
    ADD W1 Oil Catch Can. AFE Magnum FLOW Pro DRY S Air Filter. ARK Splash Guards. Baxter Performance TK-501-BK Oil Filter Adapter. Canvasback Back Hatch. Differential Breather Relocation. Diode Dynamics SS3 SAE Yellow Pro Fog Lights. Dongar Industries Adapter. DRL Mod Harness. Garmin Mini 2 Dashcam. Garmin Overlander. Bulletpoint RubiGrid Dash Mount. Overland Torque Tune. RokBlokz Mud Flaps. SAIS FIlter Mod. Stahlbus Oil Drain Plug. Yokohama Geolandar A/T4 G018 LT265/70R-17. Yota Xpedetion Pro Grille. Yota Xpedetion Valances.
    I have the OTT on two of my vehicles. My 09 Tacoma and 23 4Runner. My Tacoma has a few performance mods on it, the tune was able to capitalize on those making everything I have done to "gel". My 4Runner being stock was still able to take advantage of the transmission tuning. I can't speak on pedal modifiers since i dont have one, but I can say tuning has more benefits. That's why I went that route.
    Knarf and FoRunna414[OP] like this.
  11. Feb 11, 2025 at 9:02 AM
    Yeah you input 5 and it spits out 7. You can dial in 7 with your foot though.
  12. Feb 11, 2025 at 9:07 AM
    FoRunna414
    Andrew
    06 Sr5
    I'm leaning more towards a tune but don't know where to look. Or if anyone could recommend one.
  13. Feb 11, 2025 at 9:08 AM
    I went with the OTT tune.
  14. Feb 11, 2025 at 9:10 AM
    FoRunna414
    Andrew
    06 Sr5
    I was thinking OTT as well. Cause I'm running cams and heads with bolt on's.
  15. Feb 11, 2025 at 9:11 AM
    You would need a custom tune for that.
  16. Feb 11, 2025 at 9:12 AM
    FoRunna414
    Andrew
    06 Sr5
    yea that's what I'm thinking too.
  17. Feb 11, 2025 at 9:14 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I don’t know why you’re trying to die on this hill lol. A PC does not make anymore power, and yes, push down further on your pedal and you get more response. But it’s not about having a heavier foot. A PC completely changes the feel and driving experience.
  18. Feb 11, 2025 at 9:15 AM
    I never said more power. I know it has a ramp to it but again you can do the same with your foot. Jabbing the pedal and tapering off does the same thing. Literally had one and ditched it for that reason and because it was touchy in low speed situations. I gave it to someone one here no charge.
    nimby likes this.
  19. Feb 11, 2025 at 9:24 AM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5 2wd
    A lot of tunes include throttle mapping which is all a pedal commander does. Id go with OTT, they have good reviews and dyno results on Tacomaworld for the single vvti 1GR.
  20. Feb 11, 2025 at 9:30 AM
    BassAckwards
    Nobody else has brought it up, but the URD Ucon is another option if you want a piggyback that can be easily removed. It requires exhaust cam gears to be installed, but it has built in o2 sims for folks running long tube headers, and it also has engine protection in case actual AFR deviates too much from the target. It also has adaptives so once you get your base tune, if you change your exhaust or intake, you can reset the battery and it will relearn based on the air flow demands. It’s a pretty robust ECU, im running one on my supercharged ‘13 tacoma
  21. Feb 11, 2025 at 10:42 AM
    FoRunna414
    Andrew
    06 Sr5
    yea im running heads and cams with intake manifold spacer 78mm TB and intake JBA headers and full exhaust already.
    BassAckwards[QUOTED] likes this.
  22. Feb 11, 2025 at 11:20 AM
    FoRunna414
    Andrew
    06 Sr5
    URD Ucon OR OTT might be the way togo to.
  23. Feb 11, 2025 at 11:46 AM
  24. Feb 11, 2025 at 12:10 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Yotawerx has very good reviews and are available through authorized shops in many places.
    I’m very interested in reviews from people with tunes on the 4th Gen 1GR-FE V6. I’ve seen them for 5th Gens but that’s a different iteration of the engine.
  25. Feb 11, 2025 at 2:13 PM
    CC-2224
    CC-2224 New Member
    2021 4runner Limited
    So my pedal commander cost me over 2 grand. I live in Massachusetts, but I was in New Hampshire when my dash light up like a Christmas tree. I had engine failure and multiple codes were tripped. I thought it was a battery or an alternator issue due to the fact that my engine would not turn over. I had it towed to a Toyota dealership in NH and had to wait two weeks for a new ECU. The pedal commander is a complete scam. I had it on my rig for about 10-15k miles. IMG_0374.jpg
    4onto, FoRunna414[OP] and kmeeg like this.
  26. Feb 11, 2025 at 2:22 PM
    What heads are you currently running and what are your cam specs on your setup, Currently?
  27. Feb 11, 2025 at 2:39 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Just contact OTT and setup a dyno session.
    For a simple tune with factory engine parts a flash tune is good to go imo. But since you have done a lot of work with engine components you'll need a proper tuning session.
  28. Feb 11, 2025 at 2:48 PM
    andrewtheadventurer
    I have heard this story a couple times on the interwebs. Sorry you went on that ride.. sucks when a product that is supposed to make your stuff better actually makes it worse and cost you even more money.
  29. Feb 12, 2025 at 6:59 AM
    FoRunna414
    Andrew
    06 Sr5
    Heads were the stock ones with a port and polish with Kelfords cams 256/256 cams with Supra NA springs and retainers with oversized valves. also did the exhaust cam gears.
    1SilverRunner and BassAckwards like this.
  30. Feb 12, 2025 at 7:01 AM
    FoRunna414
    Andrew
    06 Sr5
    yea i'm definitely staying away from a pedal commander
    CC-2224 likes this.
