LED replacement bulbs
Discussion in '4th Gen 4Runners (2003-2009)' started by MyBoyGuinness, Feb 2, 2024.
  1. Feb 2, 2024 at 7:16 AM
    MyBoyGuinness
    MyBoyGuinness [OP] New Member
    Chris
    06 4runner
    level kit
    06 4runner. Looking at replacing low beam bulbs with some of the direct replacement aftermarket LEDs. Saw some while looking for regular bulbs on Amazon.
    Anyone have experience or suggestions.
  2. Feb 2, 2024 at 7:20 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I've had good luck with Diode Dynamics bulb replacements. I think they have options for 4th Gen 4R's.
  3. Feb 2, 2024 at 7:22 AM
    With my experience I have found drop in LED bulbs that perform like stock LEDs in 5th gen 4Runner with projector low beams.
    If your 2006 have reflector low beam LED bulbs may not be a good choice. They are too bringt for a reflector housing imo. If you have projectors like 5th gen projectors I had really good beam pattern with Lasfit LA plus (they have high price options too), Hikari Titanova, GTR Ultra2, Nighlight, etc.
  4. Feb 2, 2024 at 5:23 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    https://www.amazon.com/dp/B08VNWR5FQ
    After reading mixes reviews about LED output, I went with no flicker HID. Couldn't be more happy.
  5. Feb 4, 2024 at 1:28 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Check out the Boslla B4 Bullet. Cool features (sounds weird, but true) and I’ve had them in my ‘07 for ~2 years.
  6. Feb 12, 2024 at 12:10 PM
    Seananamous
    Seananamous New Member
    Black 2006 4Runner V6 SR5 4WD w/ 101K miles
  7. Feb 14, 2024 at 3:58 AM
    rihabn
    rihabn New Member
    Blue Ridge
    2004 gold 4runner v6
    front leveling kit, kenwood sound upgrade
  8. Feb 14, 2024 at 9:58 AM
    Seananamous
    Its very straight forward. Just make sure you use the right bulbs. The previous owner had a different headlight and I got confused but found out there was an unneeded wire harness. Remove it and then I was able to clip it on.
