LED Light Bar vs TSS
Discussion in 'Lighting' started by maui.built.hawaiian, Jul 22, 2021.
  1. Jul 22, 2021 at 10:12 PM
    maui.built.hawaiian
    maui.built.hawaiian [OP] New Member
    Kona
    2021 4Runner Trail SE
    Lifted
    Aloha!
    Quick question, as I’m new to the Toyota scene. My vehicle is a 2021 4Runner Trail.
    I’d like to install an LED light bar behind the grill. However, I was told, and I’ve read unless I purchase a “higher-end” bar, there may be issues with the bar emitting some sort of wave which could throw off the TSS. However, I can’t get an answer about the technology (or lack thereof) which could cause this. I’ve contacted a couple of manufacturers and they say they haven’t heard of this issue or had this problem.
    Anyway, any input is greatly appreciated!
  2. Jul 23, 2021 at 12:24 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    TSS components use radar, and some light bars on the market do create enough interference to cause AM/FM radio issues, so theoretically I suppose those same light bars could cause issues with the TSS radar.
    As far as which light bars cause this issue I couldn't tell you.
    I think a better question however is how often do you plan on using adaptive cruise control with your light bar energized?
    Overland WT and Toy4X4 like this.
  3. Jul 23, 2021 at 2:01 AM
    Welcome from Wisconsin! Anything is possible with electronic stuff. Like PVT Pablo said; how often would you run both at the same time?
  4. Jul 23, 2021 at 2:49 AM
    maui.built.hawaiian
    Kona
    Lifted
    Agreed. I’ve thought about that but I prefer everything work without the potential of components fighting.
    :bowdown:
  5. Jul 23, 2021 at 3:23 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    BBAB6FCF-0612-46C3-A9B3-A0A438684824.jpg When I had my 2020 Pro I had no issues with my Bajadesigns light bar.
  6. May 31, 2022 at 6:40 AM
    ImiotLeen
    ImiotLeen New Member
    2013 Black 4Runner
    noone
    Probably, everything is possible with electronics, and some lights of unknown origin might affect the work of TSS. When I installed a light bar in my car, I did not even think about possible interference. Also, for instance, why would the Vont LED color changing light bulb that I installed in my break room suddenly affect a phone? Such issues might likely happen if the manufacturer is violating some assembly standards. Other than that, I think you shouldn't worry.
  7. May 31, 2022 at 6:42 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    If you run them behind the blank plate below the sensor, you will not be interfering with the TSS. You can even dremel out that blank plate if you really want to get the most light from your bar.
  8. Jun 22, 2022 at 9:50 AM
    SnakeDoc
    SnakeDoc New Member
    Eric
    Upper portion of the grill without any issues. Plus there's no reason to ever use the light bar and TSS at the same time. TSS freeway and light bar off road. 20220417_144806.jpg
