Lean
Discussion in '5th Gen 4Runners (2010-2024)' started by JMC, Sep 14, 2024.
  1. Sep 14, 2024 at 9:05 AM
    JMC
    JMC [OP] New Member
    4runner
    I have dobinsons IMS and it’s fantastic. I do have 3/4” lean on the drivers side. I’m wondering if the bolts are long enough to add a 5mm spacer to adjust the lean. I really don’t want to disassemble the shock/spring to add longer bolts. I’ll post a pic below. Thanks in advance
  2. Sep 14, 2024 at 10:26 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Yes
    3/8" spacer should level you out just fine.
  3. Sep 14, 2024 at 1:32 PM
    Looks like you have more than 5mm of threads remaining on those studs, so a top plate spacer would fit. 5mm won't take out the lean though. You'll need about 3/8" (10mm).
  4. Sep 15, 2024 at 12:01 PM
    Dobs sells a spacer for this type of situation. IMG_5434.jpg I bought one but decided to just dissasemble the coilover and reset the seat height.
    djwantke and JMC[OP] like this.
  5. Sep 17, 2024 at 6:23 AM
    JMC
    JMC [OP] New Member
    4runner
    Is there any room for a 3/8”? Might be cutting it close.
  6. Oct 11, 2024 at 4:11 PM
    JMC
    JMC [OP] New Member
    4runner
    Do you have to use the dobinsons spacer or will any 1/4” spacer work. Thanks!
