Leaking water from the rear ceiling
Discussion in '5th Gen 4Runners (2010-2024)' started by imgotcheese, Mar 5, 2021.
  1. Mar 5, 2021 at 4:40 PM
    imgotcheese
    imgotcheese [OP] New Member
    2011 SR5
    Hi all. I live in a rainy climate and just noticed the other day I have water coming into the rear soaking through the ceiling and dripping from a plastic keeper. Hoping to find the solution and order parts before tearing it apart. I haven’t modified anything on the roof of the car and the weather stripping is in good condition and clean. Thoughts? Thanks!
  2. Mar 5, 2021 at 6:00 PM
    Mtbpsych
    Mtbpsych New Member
    Do you keep the window cracked open when it’s raining? It looks like water sneaks in through there rather than a leaking roof.
  3. Mar 5, 2021 at 7:29 PM
    imgotcheese
    2011 SR5
    I don’t. It’s soaking through the headliner
  4. Mar 5, 2021 at 8:14 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Sunroof? Those drains can clog.
    j cat likes this.
  5. Mar 5, 2021 at 8:48 PM
    imgotcheese
    2011 SR5
    I can’t imagine the water would drain all the way back to the rear, but Im not sure. The other photos may have not been clear enough so here’s another
  6. Mar 5, 2021 at 8:57 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Yea I saw it was rear hatch but unsure where the drains go. There's also drip rails that cover the channels for the roof rack mounts, it could have rusted through but with it being only 10 years old it seems unlikely.
    That location looks like the hatch gasket would be the culprint, but you mentioned it was good.
    Even if the spoiler were leaking some, I can't imagine it being able to get in there, as it's part of the hatch, and has drain holes for it a the bottom of the hatch. Even if it were to fill it up it would remain in the door, not the headliner, like you're seeing there.
    There's gotta be a leak in the roof rack.
  7. Mar 5, 2021 at 9:10 PM
    imgotcheese
    2011 SR5
    I’ve only lived in this rainy climate for 2 1/2 years, I was in Phoenix before. Maybe the roof rack channels are leading back there somehow. I’ve seen a lot of people having problems with their roof rack seals leaking
  8. Mar 5, 2021 at 9:11 PM
    imgotcheese
    2011 SR5
    It’s slopes up in the middle from the roof rack rails so I’m confused lol
  9. Mar 5, 2021 at 9:12 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Also if you don't have a lift on your vehicle (i.e Stock height) you have a forward leaning rake, so on level ground the water would run forward, not backward.
  10. Mar 5, 2021 at 9:13 PM
    imgotcheese
    2011 SR5
    I’m afraid I might have to take the whole headliner out to find this
  11. Mar 5, 2021 at 9:14 PM
    imgotcheese
    2011 SR5
    yep, no level or lift kit
  12. Mar 5, 2021 at 9:16 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Probably. It's a pretty big job, but if you don't find it you'll end up with mold and mildew in the vehicle if you can't find it externally.
    My guess is the bolts that hold the roof rack down have let some water through and are leaking. You could attempt to pull them out, add some RTV, and put them back in.
  13. Mar 5, 2021 at 9:30 PM
    imgotcheese
    2011 SR5
    Well that’s probably what I’m gonna do.
    I just paid it off this month! Sunuva
  14. Mar 5, 2021 at 9:31 PM
    imgotcheese
    2011 SR5
    Thanks for your suggestions. It’s my first post, I’m surprised somebody found it
  15. Mar 5, 2021 at 9:32 PM
    imgotcheese
    2011 SR5
    Any suggestions on what interior keepers I should get because I know I’m going to break at least 30% of them lol
  16. Mar 5, 2021 at 9:44 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
  17. Mar 5, 2021 at 11:12 PM
    imgotcheese
    2011 SR5
    Awesome, thanks for the help! Hopefully I can get this solved before mildew
  18. Mar 5, 2021 at 11:35 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Don't go destructo mode just yet. Check the drain plugs first like mentioned above. I know that it seems dumb that the drain line would be all the way back there but they kinda do. The drain lines at the back of the sunroof go toward the rear. Check them first and clean them out (fishing wire/ fish tape) works great. If it's that perfect, just use a carpet cleaner for the headliner and vualá
    I usually bust out my hoover portable upholstery vacuum for jobs like this
    imgotcheese[OP] and Thatbassguy like this.
  19. Mar 6, 2021 at 4:39 AM
    I would definitely check the moonroof drain tubes and roof rack mounting bolts before messing with the headliner. The rear roof rack mounting bolts seems like the most likely culprit. Good luck!
    Welcome to the forum!
  20. Mar 6, 2021 at 8:21 AM
    Matt83
    Matt83 New Member
    Northeast
    Pull the rack and check the mounting bolts/gaskets.
  21. Mar 6, 2021 at 9:06 AM
    Abanero
    Abanero New Member
    2015 Inferno Orange 4Runner TRD Pro
    While I don't disagree w/ the culprit being the drain tubs, due to the extent of the visible damage, I still think it would be worth pulling the headliner for a full clean. By the looks of it, there's already enough water/moisture that mold/mildew could be a concern.
  22. Mar 6, 2021 at 11:48 AM
    imgotcheese
    2011 SR5
    Thanks for all the suggestions. I’ll probably pull the back of the headliner off and try and bend it down a little to get a peek in there to see if there’s mold and try and dry it out. I’m also gonna reseal the roof rack bolts, what about the long seam that’s on both sides of the roof under the rack. Is that something that I should consider replacing while I have the rack off. The car was in the AZ sun for 8 years so I wonder if it needs replacing. It looks fine from the top and isn’t cracked though
  23. Mar 6, 2021 at 12:54 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    Definitely a curiosity
    Let us know what you find homie
    I'll be good to keep in mine in case this happens to others
  24. Mar 6, 2021 at 6:03 PM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    Also check the satellite radio antenna (Shark fin) since you are checking for leaks. I'm pretty sure there is a gasket and a single bolt. If you drop the rear of the headliner you should be able to see it. If it was in AZ sun as long as you say, the gasket may have dried out and become brittle. Worth checking along with the roof rack bolts.
    Thatbassguy, ruiz4251 and j cat like this.
  25. Mar 6, 2021 at 6:28 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    shark fin creates the leak.. I wash my vehicles on my property and I am very careful not to hit the shark fin,,many have had leaks in the rear..I never go to the car wash .also the sun roof leaks in the driver area because of the drain holes get tree crap .
    the sun roof tubes run to the rear then drains on the rear tire area ..
    I had to remove my roof rack sliders because it is a PITA to remove the snow on my roof..
    I removed the plastic covers to remove the rack sliders and there was a lot of tree crap under it.. I sprayed soap on those plastic covers then I used the plastic tools to pop off those covers comes off easy ..
  26. Mar 6, 2021 at 11:36 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    My vote is also the roof rack mounts or shark fin (did they have the shark fin antennas on the early 5th gens?). The roof seam covers you're referring to are not seals. They're just trim pieces meant to make the welded seam prettier.
    Whatever you find, please do not use generic silicone or hardening RTV to seal. Use a proper automotive sealant that is meant to stay tacky and dynamic, like butyl rubber. Silicone and other gasket makers that cure and harden will lead to the same leaky problems in the future.
  27. Mar 7, 2021 at 7:02 PM
    solidcatch22
    solidcatch22 New Member
    2014 4runner SR5
    3'' leveling kit, 33'' BF Goodrich All Terrains, Black on black, Front Bull Bar with off road LED lights, custom steel roof rack
    I went to the car wash today and had water seeping through my seat belts! I did some investigation, pulled off my roof rack, took off the screws and there it was: rust buildup around the gaskets that hold the feet to my roof rack. Ive had my 4runner for 6 years (2014) so looks like I need to remove the headliner, dry out any moisture internally, spray rust remover, then use silicone to seal up both the interior and exterior gaskets of the screw holes. I also noticed tiny separation of the mounted gasket that the feet screw into which had rust on it as well. The rust wasn't bad at all but make sure and take the whole headliner off just to be sure no mold or mildew have built up.
    ruiz4251 and Thatbassguy like this.
  28. Mar 7, 2021 at 7:55 PM
    AgentKooper
    AgentKooper New Member
    2021 4Runner TRD Pro
    Factory rack?
  29. Mar 7, 2021 at 10:15 PM
    nimby likes this.
  30. Mar 8, 2021 at 6:45 AM
    j cat
    j cat New Member
    massachusetts
    I use a rust remover rustoleum that has phosphoric acid. this product dissolves the rust in an hour or so then wipe it off .. then I put a primer on it then a few hours top coat it .
    I used this on my 2000 GM truck and on my steel hand rail on the steps of my house. works good .did it last year .
    do not put silicone sealer on bare metal..
    I pulled off those covers that are the roof rack bars .. Toyota created this to hold up debris in that lock down ..
    when you put the bolts into the body frame use a thread sealer to protect the threads/metal from corrosion and water leaks.
    when I do my 96 Impala water pump bolts I use this to stop any antifreeze leaks. on other engines GM the upper intake manifold bolts do leak old engines and I fixed it .. permatex thread sealer..
