Leaking From Charcoal Cannister
Discussion in '2nd Gen 4Runners (1990-1995)' started by GShubert, Feb 16, 2025.
  1. Feb 16, 2025 at 5:31 PM
    GShubert
    GShubert [OP] New Member
    Greg
    '91 4Runner with the 3.0.
    Gas is leaking from the charcoal filter down into the hose that empties into the frame. Can I cap off any of the lines going to or the one that drains into the frame to keep it from leaking?
    I put a new gas cap on it and it did not slow it down....Slowed it down when I leave the gas cap loose.
    Thanks in advance.
  2. Feb 18, 2025 at 8:42 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    GShubert[OP] likes this.
  3. Feb 19, 2025 at 9:01 AM
    GShubert
    Greg
    Thanks. I will replace the canister. Used to work on all my vehicles. 35 years of diabetes has stopped that.
  4. Apr 14, 2025 at 8:21 PM
    Why is there gas dripping from your charcoal canister? They only deal with vapors. I would look and see why you have a fuel leak. Otherwise, you'll just saturate a new canister.
  5. Apr 15, 2025 at 9:11 AM
    Justthemechanic
    Nevada desert
    You are correct, the canister is only getting fuel vapors from the tank. If the canister does not purge the fuel vapors, eventually the charcoal gets saturated. When that happens, the fuel will condense out of the charcoal and drip out of the bottom of the canister.
