Largest Tire That Will Fit in Spare Location?
Discussion in '5th Gen 4Runners (2010-2024)' started by Vito Corleone, Jul 4, 2020.
  1. Jul 4, 2020 at 9:45 PM
    Vito Corleone
    Vito Corleone [OP] New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I will be taking delivery of a 2020 4Runner ORP in a few weeks and plan on lifting it and installing larger tires as soon as I get it. I am curious as to if a larger tire/wheel will fit under the rear in the spare location. I currently have a Tacoma with a 3/2 lift, however, a full size tire/wheel (285/75/16) will not fit in the spare location so I have that size spare in the bed.
    Roland likes this.
  2. Jul 4, 2020 at 9:56 PM
    Agent_Outside
    Built 2011 T4R Limited
    33s fit fine
    Roland and Thatbassguy like this.
  3. Jul 4, 2020 at 10:34 PM
    Mtbpsych
    Mtbpsych New Member
    Skinny 33?
    Roland, Thatbassguy and SlvrSlug like this.
  4. Jul 5, 2020 at 4:46 AM
    850RedRunnerORP
    850RedRunnerORP New Member
    FL
    '18 Barcelona Red ORP
    Eibach Stage 1 kit 285 BFG K02s
    I recently put BFG K02s on mine, 285/70/r17, and the 5th one fit just fine in the spare area.
    808Yoda, Roland and Thatbassguy like this.
  5. Jul 5, 2020 at 6:57 AM
    jack bauer1
    jack bauer1 New Member
    285/70/17 RG fits fine too.
  6. Jul 5, 2020 at 10:14 AM
    Agent_Outside
    The 2 common 33” tire sizes 285/70/17 (32.7ish) and 255/80/17 (33.3ish) both fit fine.
    ready6delta and DRobs like this.
  7. Jul 5, 2020 at 10:51 AM
    Vito Corleone
    Georgia
    2022 4Runner ORP
    Nice! Thank you to everyone for the info.
  8. Jul 5, 2020 at 1:32 PM
    Antman
    Antman New Member
    Anthony
    I can verify I just put my 285/70/17 in spare location. No problems. Honestly didn’t think it’d fit though.
    Roland likes this.
  9. Jul 14, 2020 at 10:16 AM
    WapitiHunter
    WapitiHunter New Member
    Andrew
    2013 SR5 Burrito
    Ironman4X4 Pro Stage 3 Lift; Rhino Rack; 295R17s.
    I must be doing something wrong. I have 285/70/17s and it doesn't fit well. It hangs down at an angle due to the bracket on the frame. I thought about grinding it off and rewelding it higher up so the spare can sit flat.
  10. Jul 14, 2020 at 10:43 AM
    taco_runner
    taco_runner New Member
    Kev
    4Runner TRD OR Premium
    Additional question, does the 285 sit very close to the exhaust pipe?
  11. Jul 14, 2020 at 10:46 AM
    Antman
    Antman New Member
    Anthony
    Maybe the under carriage slightly varies between per year on my 2020 I have absolutely no problem fitting it in and it’s nowhere near the exhaust or any bracket I could probably fit a larger size tire in they’re easily
    Roland likes this.
  12. Jul 14, 2020 at 3:43 PM
    Agent_Outside
    I have a 2011 and I fit a 255/80/17 (bigger diameter than a “33 inch” 285) just fine. I wonder if your vehicle has been hit and the frame is tweaked?
  13. Jul 14, 2020 at 3:48 PM
    WapitiHunter
    Andrew
    2013 SR5 Burrito
    It's probably the hitch mount taking up space.
  14. Jul 22, 2020 at 4:45 PM
    2Trex
    2Trex New Member
    2019 4Runner | TRD Off Road Premium | Magnetic Gray
    2019 TRD Off Road Premium | Magnetic Gray Metallic | LT255/80R17 Falken Wildpeak A/T3W | Borla Cat Back Exhaust | TRD Cold Air Intake | Toytec Boss 3" Lift | SPC Upper Control Arms | RCI Rock Sliders | Warn Semi-Hidden Winch Mount | Smittybilt X2O 10,000 lb. Winch | Cargo Drawers
    I have a 2019 with the factory class III hitch. The last post questions if the hitch is an for a 33 inch spare. Do any of you that said 33” spare works, have the factory hitch?
  15. Jul 22, 2020 at 5:17 PM
    Agent_Outside
  16. Jul 23, 2020 at 12:30 PM
    satxguy
    satxguy New Member
    Marcos
    San Antonio, TX
    2020 off road
    OME lift Ditch lights Carhartt seat savers Husky floor liners Off grid engineering dual battery tray Battery isolator Victory 4x4 full roof rack RSG Rock Sliders Roam RTT
    I was able to fit a BFG KO2 285 spare on my Taco spare location. Not all 285’s measurements are the same. BFG KO2 285 fit in stock spare location under my 2020 4Runner. It may be the brand or tire type that’s the issue. BFG KO2 285 is not 33’ 32.8 for a 285/70/17 and 33.9 for a 285/75/17. Load ratings also effect the tire size same size tire different load ratings 116/113Q C BSW 32.8" 11.5" 7.5-9" 8.5" 15/32" C 2755/2535 lbs 50 psi 50.3 lbs 635 116/113Q C RWL 32.8" 11.5" 7.5-9" 8.5" 15/32" C 2755/2535 lbs 50 psi 51.4 lbs 635 121/118R E RWL 32.7" 11.5" 7.5-9" 8.5" 15/32" E 3195/2910 lbs 80 psi 57.9 lbs 635
  17. Jul 24, 2020 at 7:23 AM
    Barcelona Trail
    Barcelona Trail New Member
    Colorado in Winter - SoCal in Summer
    '16 TEP w/ KDSS
    Bilstein 6112 & 5100 - Built Right UCAs - AFE Intake, TBS, & Exhaust - Pedal Cmndr - Icon Rebound - 285 BFG KO2
    People are saying that 285/70/17s fit just fine... and they do fit. That being said, IF YOU HAVE KDSS (as I do) its a tight fit due to the location of the rear swaybar. While my KO2 does fit, there is less than a half inch of clearance between it and the previously mentioned swaybar. That swaybar moves/articulates as needed and could potentially rub the spare. In fact I've spoken to guys who also have KDSS and upon inspection they have noticed that the swaybar has rubbed on occasion. Anything bigger than the 285 KO2 could be a problem down the road
    DurangoMax and satxguy like this.
  18. Jul 24, 2020 at 8:28 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Frizzle77 and 7385 like this.
  19. Jul 24, 2020 at 8:53 AM
    Agent_Outside
    DRobs[QUOTED] likes this.
  20. Jul 24, 2020 at 8:02 PM
    2Trex
    2Trex New Member
    Thanks for all your replies. I was a little confused but now it looks like all I need to do is go buy five tires.
    captrussia253 and Thatbassguy like this.
  21. Feb 14, 2021 at 2:21 PM
    fantom.4r
    fantom.4r New Member
    I was looking for answers since I just bought a 2019 4Runner TRD Off Road. It came with two spares (the one of the bottom of the truck) and another one with the TRD rims (which they kept in the trunk).
    My question is, will the TRD rim with the 265/70/17 fit in the spare tire spot? Or do I need to use the steelie in order for it to fit there properly?
    Thank you in advance!
  22. Feb 14, 2021 at 5:58 PM
    Tuco S.
    Tuco S. New Member
    My 255/80R17 didn't want to go in at first (wouldn't clear the swaybar) until I tilted the tire downward towards the rear (hitch side) while turning the crank to hoist it up. It went in just fine after that.
  23. Feb 14, 2021 at 6:00 PM
    Tuco S.
    Tuco S. New Member
    Yes it will fit.
  24. Oct 19, 2021 at 4:30 PM
    Mtbpsych
    Mtbpsych New Member
    I was able to fit a 295/70/17. It hangs lower, closer to rear diff height. My question is, anybody see the chain not being able strong enough to hold it for some reason? All together it’s probably about 75ish-80ish pounds. For off road use, I would 100% pass on this solution. This is just for a road trip though, so nothing that requires clearance. Just worried about the chain being strong enough to hold the tire is my main concern.
  25. Oct 19, 2021 at 7:50 PM
    Roland
    Roland New Member
    That chain can hold 300 Lbs.
    Thatbassguy and Mtbpsych[QUOTED] like this.
  26. Oct 19, 2021 at 8:49 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    285/70r17 fits.
    Mtbpsych and Roland like this.
  27. Oct 19, 2021 at 9:36 PM
    Mtbpsych
    Mtbpsych New Member
    Cool, thanks for the reply! I’ll be more at peace without having to worry about the tire falling off:cool:
    Roland[QUOTED] likes this.
  28. Oct 20, 2021 at 1:51 AM
    TacoTheTaco
    TacoTheTaco New Member
    To clear it up, Tacoma’s come with a 265/65r17 from the factory. 4Runner’s have 265/70R17’s from the factory. While it’s not significant, it’s obvious why the 4Runner has a little more room.
    To answer the questions, I have a 285/70R17 and it’s not close to the KDSS. If you have KDSS and 285’s, you should have a lift and I’d recommend the KDSS spacers. Is it close to the exhaust? It was closer to the OEM exhaust, but not so close you’d have to worry about anything. I also switched to the Magnaflow Overland exhaust and it seems just slightly further away from the tire and I don’t have to smell the lovely 4.0 fumes if I open my back window. Lastly, I have the factory hitch and no problems at all there either. Been running my 285/70R17 spare in the factory spot for months now.
    icyhotahs and taco_runner like this.
  29. Jan 19, 2023 at 9:22 AM
    wapitispokes
    wapitispokes New Member
    JJR
    2005 4Runner Ltd V6
    I've been running Nitto Ridge Grappler 255/80/17 on a 2005 limited with rear hitch and in my case it does NOT fit "fine" but I can get it in adequately with some difficulty. Ultimately, I do get it tucked away enough so that it only hangs about 2 inches below my rear hitch. Just checked and it angles up towards the rear. I may not have tried the suggestion of angling the rear side of the spare (facing the hitch) downward before cranking it up.
    Since I have onboard air, sometimes I install the spare with lower pressure (around 18 lbs) and that helps.
    If there was 1/4 inch more clearance it would probably tuck in fine.
  30. Jan 19, 2023 at 3:42 PM
    Kezin
    Kezin New Member
    ‘21 and ‘17 Limiteds
    This is the 2010+ section. Might be enough difference between the two generations that makes it easier to fit a larger tire in the 5th gen spare location
