Largest 2021 4WD tire size without level or lift
Discussion in '5th Gen 4Runners (2010-2024)' started by TRAVIDIOUS, Feb 21, 2024.
  1. Feb 21, 2024 at 6:20 AM
    TRAVIDIOUS
    TRAVIDIOUS [OP] New Member
    travidious
    Apache Juntion
    2017 limited 4x4 & 2016 POLARIS RZR XP1000 "Bankruptcy-Starter Kit"
    4RUNNR-3" Bilstein lift X 33" tires & RZR XP-NOT ENOUGH ROOM TO LIST ALL MODS
    Hello all "Yota folks!
    I'm a former Tundra TSS owner (2013) and should have never sold it.
    I'm Travis. Me and my wife just bought 2 4Runners and I'm excited to get going with them....
    Hers is a 2021 SR5 4WD (totally stock)
    Mine is a 2017 Limited 4WD (3" lift/ 32" tires)
    My FIRST QUESTION IS FOR HER'S...What is the biggest tire size I can put on hers without lifting or leveling?? This will get me into some better looking rims that we'll use later when I do lift/level it for larger tires.
  2. Feb 21, 2024 at 7:31 AM
  3. Feb 21, 2024 at 8:02 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    I'm here in AZ too. Apache Junction!
  4. Feb 21, 2024 at 8:23 AM
    steelevo
    Utah
    Welcome. A few others with experience will chime in.
  5. Feb 21, 2024 at 9:24 AM
    welcome
  6. Feb 21, 2024 at 9:39 AM
    Biggest tire size without rubbing is the stock 265/70-17 (32") on the stock +15mm offset wheel. If you find some 4th gen +30mm offset wheels, you should be able to clear 255/80-17 (33"), but the stance will be narrower.
  7. Feb 21, 2024 at 9:47 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    Thank you very much 3joh22a
  8. Feb 21, 2024 at 9:59 AM
    Welcome to the forum from Wisconsin!
    Lift alone doesn't clear tires. It only hides the rubbing. The possible exception is a body lift.
  9. Feb 21, 2024 at 10:08 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Lift will not help. Choosing the appropriate tire size and wheel offset will. 285/70R17 with +4 to 0 offset seems to be the sweet spot for minimal rubbing.
  10. Feb 21, 2024 at 10:15 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    Can you explain/help me understand the "+4 to 0 offset" and how do I shop for this in a search?
  11. Feb 21, 2024 at 10:21 AM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    Even when staying with stock size, just changing from the factory tire to an all terrain (which generally have a wider tread) will change the look considerably. I kept the same size yet when from a 31.6" to a 31.9" tall tire but the wider tread makes them look even bigger. Here's before and after pictures...
  12. Feb 21, 2024 at 10:25 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    Same 4R that my wife has essentially, that all I'm trying to do right now. I found some 265/75r16, on aftermarket rims and Just want the better look for now. Will use the same rims on bigger tires once a lift is installed.
    Thanks for the pics. very helpful to get a visual.
  13. Feb 21, 2024 at 10:25 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Lower positive and higher negative offset values represented in mm pushes the wheel further out, creating a larger sweep radius that can introduce interference/rubbing. Any wheels you are shopping for should indicate offset.
  14. Feb 21, 2024 at 10:26 AM
  15. Feb 21, 2024 at 10:27 AM
    +1, here’s my rig with stock size tires. I had a 3/2 lift with 285’s and it was no more capable than it is now with 265’s.
  16. Feb 21, 2024 at 10:56 AM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    16's won't fit unfortunately
  17. Feb 21, 2024 at 10:58 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
  18. Feb 21, 2024 at 11:06 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    Can you explain why 16" wont work??
  19. Feb 21, 2024 at 11:11 AM
    wax poetic
  20. Feb 21, 2024 at 11:15 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
  21. Feb 21, 2024 at 11:32 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    They won't fit over the brake calipers.
  22. Feb 21, 2024 at 11:37 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    WHAT A GREAT GROUP AND EXPERIENCE FOR FIRST TIME POSTER HERE. THANKS SO MUCH GUYS!!
    CalcityRenegade and Thatbassguy like this.
  23. Feb 21, 2024 at 11:38 AM
    TRAVIDIOUS
    travidious
    Apache Juntion
    SAVED ME SOME HEADACHES 4-SURE
  24. Feb 21, 2024 at 12:40 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
  25. Feb 21, 2024 at 12:51 PM
    Manhattan
    Manhattan New Member
    The factory 17s and 20s have a 15mm offset. So, if I'm understanding correctly, going to 285/70/17s (32.7"), on factory wheels, even with a 2-1 lift, the tires will rub the plastic fender liner. And the fix is to cut, drill two new holes, move in 1"... is this accurate?
  26. Feb 21, 2024 at 1:26 PM
    TRAVIDIOUS
    travidious
    Apache Juntion
    Because Im an old Marine, Im going to ask for this to be broke down shotgun style...Given the above video, what is the largest tire size on a 17" rim that will fit and not rub??
    Im guessing a 275/70/17 (32.16")? & if trying to go 285/70/17 it will become questionable??
  27. Feb 21, 2024 at 1:30 PM
    wax poetic
    I think even then it will depend on the rim width/offset and tire design but I'll let others chime in.
    TRAVIDIOUS[OP] and nova like this.
  28. Feb 21, 2024 at 1:43 PM
    DesertSurfer
    Welcome to the forum!
  29. Feb 21, 2024 at 2:28 PM
    TRAVIDIOUS
    travidious
    Apache Juntion
  30. Feb 21, 2024 at 2:30 PM
    nova
    nova New Member
    mike
    Consider the wheel you like. Best fitment comes from POSITIVE offset wheels. 33's will fit in the wheel well fine, it's the wheel poke that kills the deal.
    I forgot to mention welcome to the forum! I'm moving to AZ in a few months!
    Edit: With respect to the author, I'd question a lot of the article's advice - Caveat Emptor
