Large tires
Discussion in 'Wheels & Tires' started by dadley, Nov 3, 2025 at 6:33 PM.
  1. Nov 3, 2025 at 6:33 PM
    dadley
    dadley [OP] New Member
    I have a connection at a car dealership who can get me tires for cash, half the price of new tire. So I feel confident I can get a good price on tires large like 38-40 inches . How much of the fender do you need to carve out to fit like a 40 inch tire?
  2. Nov 3, 2025 at 10:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    which 4r
  3. Nov 4, 2025 at 3:18 AM
    dadley
    It's a silver sr5 the body is in awesome shape
  4. Nov 4, 2025 at 3:22 AM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    What year 4Runner?
  5. Nov 4, 2025 at 4:02 AM
    dadley
    It's a 2015 with 202,000 km
  6. Nov 4, 2025 at 6:06 AM
    You're going to have to butcher the shit out of it to fit 40's. 35's are even a struggle if you really want them to clear. Plus, you'll want to regear, and probably have issues with the steering rack with tires that big.
    I'd highly recommend against anything that big, unless it will be a dedicated wheeling right.
    Toy4X4, icebear and Borracho Loco like this.
  7. Nov 4, 2025 at 6:07 AM
    why have fenders at this point? LOL
  8. Nov 4, 2025 at 6:43 AM
    dadley
    I can see your point regarding the handling and steering however I have extensive experience and am confident I can overcome things like that quite easily just by relying on experience driving
  9. Nov 4, 2025 at 6:44 AM
    dgtulsaguy
    dgtulsaguy Rocklanding Jedi Master equivalent
    22 MGM ORP long travel
    What are you doing with your car? If you want to use all of the travel available for the shocks serious cutting, tubbing, hammering and relocating is required. Check out my build thread to see what it took for me to flex 38's
  10. Nov 4, 2025 at 6:49 AM
    and that's with 38s , OP wants 40s. Right on! Hell's revenge awaits my man!
  11. Nov 4, 2025 at 6:55 AM
    dadley
    Just daily driving with the family long distance road trips etv
  12. Nov 4, 2025 at 7:39 AM
    Experience isn't going to change the physics involved with running tires that large and heavy.
    For this use case, I wouldn't go any bigger than a 285/70/17 and stick to an SL load range. Why would you butcher your fenders just to fit tires you have no need for?
  13. Nov 4, 2025 at 8:19 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Because it would make me look cool, bruh.
    OP fails to mention his deleted thread where he talks about how awesome the body is, but he's poking holes through his rusted frame with a screwdriver.
    Priorities man. Fix the frame before you try to slap 40's on a rust bucket with a big, beautiful body.
    You definitely have confidence, I'll give you that, but the more I see you post the more I get the feeling that confidence is misplaced
  14. Nov 4, 2025 at 8:20 AM
    Pixeltim
    Pixeltim New Member
    Tim
    WTF is a km?
  15. Nov 4, 2025 at 8:21 AM
    LOL, i'm thinking this was sarcastic and will leave it alone. LOL
  16. Nov 4, 2025 at 8:22 AM
    Pixeltim
    Pixeltim New Member
    Tim
    LOL!
    I'm guessing this is a troll thread.
  17. Nov 4, 2025 at 8:26 AM
    Man, the troll game this guy has is pretty impressive. Ya’ll keep falling for it.
    Next he’ll ask about a 6 inch BODY lift and/or a super charger to add to the engine.
    TrailSpecial22 and djwantke like this.
  18. Nov 4, 2025 at 8:42 AM
    Pixeltim
    Pixeltim New Member
    Tim
    What's wrong with a supercharger?
    I like body lifts!
    Steely123 likes this.
  19. Nov 4, 2025 at 9:06 AM
    dgtulsaguy
    I'd also be shocked a car dealership regularly sees ANY tires in those sizes. Maybe a Jeep dealership but 37's is typically the max they deal with too.
  20. Nov 4, 2025 at 9:21 AM
    dadley
    Ya you would think that for sure but this guy buys tires in for me and all his buddies he orders them thru the dealer (the owner owns a bunch of dealerships) and we just pay the guy cash like half price off wholesale
    dgtulsaguy[QUOTED] likes this.
  21. Nov 4, 2025 at 9:22 AM
    dgtulsaguy
    That's a good deal. I thought you were talking takeoffs when you said half price.
  22. Nov 4, 2025 at 9:55 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Not if it is a tractor dealership, those are probably tractor tires.
  23. Nov 4, 2025 at 9:56 AM
    Miss my SR5 :muscleflexing:
    Before -
  24. Nov 4, 2025 at 10:01 AM
  25. Nov 4, 2025 at 10:02 AM
  26. Nov 4, 2025 at 10:19 AM
    dadley
    Ya there no paper trail I don't even think he keeps his invoices from the vendors there not to many people keeping an eye on things there but if I can get a $500 tire for $200 cash it works for him cash in his pocket and works for me to haha
  27. Nov 4, 2025 at 11:22 AM
    It’s a thousand M’s.
    Toy4X4, icebear and Thatbassguy like this.
  28. Nov 4, 2025 at 1:13 PM
    dgtulsaguy
    Sounds shady. If so, earn it instead bro! There were points in my life that I pulled the trigger on "fell-off-the-truck" deals. Totally regret that chapter and I have made amends where possible. I subscribe to the non-aggression principle now. My eternal soul is worth more than a few dollars, even if the mark is just some rich dude.
    Sin4R likes this.
  29. Nov 4, 2025 at 1:38 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Many years ago I worked with a redneck chick that had 44” mudders on a first generation Tacoma . Now that I think about it it was a pre Tacoma truck .
    Mid 80’s or so . Looked ridiculous.
  30. Nov 4, 2025 at 3:41 PM
    Yeah this entire thread reads as shady and trolly
