KO2 from Grand Cherokee fit stock 4Runner?
Discussion in 'Wheels & Tires' started by kyle50, Aug 17, 2020.
  1. Aug 17, 2020 at 10:38 AM
    kyle50
    kyle50 [OP] New Member
    Does anyone know if these KO2's that were previously on a Jeep Grand Cherokee will fit a stock 4Runner?
    BFGOODRICH
    ALL TERRAIN T/A KO2
    275/55/R20 115S D1
    31.9 diameter
    10.8" width
    Thanks!
  2. Aug 17, 2020 at 10:41 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Yea it should fit on a Toyota Wheel 20". If you're wanting to actually offroad, 20" wheels don't give a bunch of sidewall to work with FYI.
    Stock tires are 265, so there's a chance with the wrong offset you'll rub some, but likely ok.
  3. Aug 17, 2020 at 10:49 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    They're basically the same size as OEM, so they'll fit, assuming you have some 20" Toyota wheels to put them on.
  4. Aug 17, 2020 at 12:28 PM
    kyle50
    They're on these wheels. Does that work?
    BLACK RHINO
    MOZAMBIQUE
    20 X 8.5 5-127.00 30 SLGLMM
  5. Aug 17, 2020 at 12:32 PM
    BroRunner
    BroRunner New Member
    2015 4Runner Trail Edition
    It definitely won't fit with those wheels. The 4runner has a 6 bolt pattern (6-139.7mm) or if you're into imperial units that's a 6bolt 5.5".
  6. Aug 17, 2020 at 12:35 PM
    kyle50
    Thanks! I really appreciate it.
  7. Aug 17, 2020 at 12:43 PM
    BroRunner
    I just had an idea and found this online:
    https://wheeladaptersusa.com/collec...-lug-truck-2-thick-14x1-5?variant=36527018833
    So if you really wanted to get them to fit you probably could. I've never used anything like this before but it's just like a spacer. The load rating of the 5 bolt and 6 bolt wheel from BlackRhino appears to be the same, so that makes me think it shouldn't be a big deal in regard to strength of 5 vs 6 bolts.
