KO2 C1 vs E1
Discussion in 'Wheels & Tires' started by taco_runner, Sep 7, 2022.
  1. Sep 7, 2022 at 7:35 PM
    taco_runner
    taco_runner [OP] New Member
    Kev
    4Runner TRD OR Premium
    So I ordered a stock size 265/70/17 C1 BFGoodrich KO2, and got it installed today. I test drove on the highway for nearly an hour under my normal driving habit and I only got 16.5 mpg :) ... I normally get 20mpg.
    When I reached home, I inspected the tires and to my surprise, they installed the heavier and beefier E1 which weighs 6lbs more per tire.
    My question, will there be a significant difference in "mpg" when comparing the C1 against E1?
    Don't laugh at me, I am not yet going rock climbing, this vehicle is currently a mall crawler, and used for long drives. I just like the look of the KO2's.
    Edit:
    Picture below was taken when I reached home, trying to figure out how to solve this... Google map says from home to highway exit is 10.5miles/18 minutes, multiply that by 2 because I started from home, then back = 36 minutes city drive. My total drive was 52 minutes, so 16 minutes was spent on the highway. So combined highway/city of 15.8 mpg. I got to say though, the A/C was on full crank (look at the outside temp)... I am overthinking this, LMAO
  2. Sep 7, 2022 at 7:58 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Not enough to make a notable difference in your pocket.
  3. Sep 7, 2022 at 8:03 PM
    kmeeg LionRunner
    I don't think Load E will have such a big difference. Here's a non scientific test for 20miles of highway drive giving me stock mpg with 275 Load E KO2 + OME 2.5” lift + RSG sliders.
    Also note this is pre 2020 instrument cluster. My newer 2021 instrument cluster show me much lower mpg but when I calculate by hand the real mpg is much better. But just wanted to say 275/70R17 Load E did not give me bad mpg. Just my experience. Hope your alignment is good.
    https://youtu.be/Km9Lb1SKxn8
    taco_runner[OP] likes this.
  4. Sep 7, 2022 at 8:34 PM
    Significant? Maybe not. But, it will certainly make a difference.
    If fuel economy is a concern, I would have stuck to the SL version. C is a nice compromise. But, if you're not getting into situations where puncture resistance is a consideration, LT tires are probably overkill.
    karmatp and taco_runner[OP] like this.
  5. Sep 8, 2022 at 2:44 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    If you requested and paid for C's then the shop should fix the problem. Yes, 6 pounds per wheel assembly, especially at the tire, will make a difference in MPG, acceleration and braking performance. I swapped wheels last month and went from a 25 pound Motegi to a 21 pound Konig and my MPG increased from 17.8 average to 20.1 average using the same 255/75 KO's.
  6. Sep 8, 2022 at 5:23 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    E is way overkill for our light 4Runners. Ride quality will improve also with the C’s.
  7. Sep 8, 2022 at 10:37 AM
    taco_runner
    Kev
    So they changed the tires to C1, but my steering wheel is vibrating... now they are trying to check everything again... my luck !
    GJ4R likes this.
  8. Sep 8, 2022 at 10:40 AM
    kmeeg LionRunner
    Do they have roadforce balance machine to properly balance the wheels & tires?
    Is it a good tire shop that maintains and calibrate the roadforce balance machines?
    Edit -
    a sample pic-
  9. Sep 8, 2022 at 3:50 PM
    taco_runner
    Kev
    20220908_155724.jpg Yeah they did a road force balance and they put the tires on the rear. I drove it as is and it didn't vibrate but I rotated the tires and there is a little vibration, I am now at Discount tires, they will replace one tire... and hopefully that will solve the issue.
  10. Sep 15, 2022 at 4:51 PM
    I’ve never been a fan of white letters showing, but I’ve got to say they look great on the Nautical Blue!
  11. Sep 15, 2022 at 6:50 PM
    GJ4R
    GJ4R New Member
    Careful, don’t you dare blame the tires…sacred ground around here.
  12. Sep 15, 2022 at 6:52 PM
    GJ4R
    GJ4R New Member
    I’ve had my stock sized c rated k02’s rebalanced 3 times, had an alignment, and had Toyota look at it and claim it’s fine. Still have the wheel shimmy. Many, MANY others experiencing the same shit. I’m about to return the tires and get something else.
  13. Sep 15, 2022 at 7:46 PM
    taco_runner
    Kev
    If it makes you feel better, I had the shimmy when I first got the 4Runner brand new. i just ignored it. Now I'm just picky because of the KO2's. So far after road force balance, and Discount tires changing the really bad ones, no more shimmy...
    GJ4R[QUOTED] likes this.
  14. Sep 15, 2022 at 8:16 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    E tires are absolutely great, but a waste if you don't off-road at all.
    Like mentioned, if you paid for 'C' rated you should get what you paid for. They probably just had a set of 'E' rated sitting somewhere and slapped them on which would make me inspect the date code to ensure I didn't get a set of older tires.
    GJ4R and taco_runner[OP] like this.
