Keys
Discussion in '4th Gen 4Runners (2003-2009)' started by Ni4Ni, Dec 21, 2018.
  1. Dec 21, 2018 at 5:16 PM
    Ni4Ni
    Ni4Ni [OP] New Member
    2005 & 2003 4Runner Limited
    Hello Everyone! Merry Christmas! My first post so please forgive anything I do incorrectly and thank you in advance for any help you can provide. I bought my wife a 2005 4Runner Limited 4WD White. While test driving the car, I always entered it by using the fob to unlock the door. Days later (once the car was mine) I tried unlocking the door with the key. No go. I rolled down the back windows with the fob and tried to roll up the window with the key. No go. They won’t even turn at all. I’m assuming something probably went wrong with ignition on this 4Runner at some point and they swapped it out which I imagine was costly. The question is, what should I do, get a second key cut that will open the door and roll up the window? Think I can get someone to adjust those locks to match the working ignition key? I really don’t want two keys if I can avoid it. Suggestions? Thank you!
  2. Dec 22, 2018 at 9:13 AM
    Welcome to the forum.
  3. Dec 29, 2018 at 7:36 PM
    DDrunner
    DDrunner New Member
    Duke
    04 limited
    Stock for now
    Go back to where you bought the runner and explain the situation and have them correct it or have them give you the $ to go correct it yourself . It probably going to be close $500. Good luck.
  4. Dec 31, 2018 at 8:11 AM
    jgcaps
    jgcaps Lovin the Colorado Life.!
    CO
    2018 MGM TRD ORP KDSS 4Runner
    3" Icon Stage 2, 18x9 Fuel Beast wheels, 285/65/18 BFG KO2's, N-FAB Black Rock Rails w/removable steps.
    sounds like it might be a valet key..?
