KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by lowflyer, Aug 12, 2023.
  1. Aug 12, 2023 at 9:51 AM
    lowflyer
    lowflyer [OP] New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I now have a TRD Off Road Premium that has KDSS, which I did not have on my Venture. I like the KDSS stability. If the system were to stop functioning I should know it by the ride. My question is whether there is also any display on the dash warning when the system stops functioning. I don't see much discussion of KDSS in the manual.
    Thank you.
  2. Aug 12, 2023 at 10:12 AM
    Yes there is a warning light.
    364894d1593905397-only-kdss-w-lift-need-_580a04bbe1d3e7ebe2619bf566d66e76c3a662ae.jpg
  3. Aug 12, 2023 at 1:24 PM
    It stops at like 110.
    djwantke and Thatbassguy like this.
  4. Aug 12, 2023 at 1:40 PM
    I hit about 110-115 in my '03. I don't go over 99 in my '19 because the tires are only rated for 99.
    Ripper238 and gomiami like this.
  5. Aug 12, 2023 at 1:45 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    When I had the stock HT's I got up over 100 but now with my C load I don't go much passed 90.
    Love my KDSS
  6. Aug 12, 2023 at 2:22 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I used to top out all my vehicles just to see where it stops. My '04 JGC had a fuel cutoff at 113. I'm not as wild as I was in my younger days so haven't hit the governor in the 4runner or the '14 JGC.
    Luckily I don't think I've seen a "how to disable the governor" thread on here so maybe others are being responsible.
    :burnrubber:
    RumHamRunner73 and Thatbassguy like this.
  7. Aug 13, 2023 at 12:42 PM
    lowflyer
    I drove my Venture with no KDSS for 2.5 years. This new Off Road with KDSS is a huge improvement in stability. I'm loving it.
    Ripper238[QUOTED] and 2Toys like this.
  8. Aug 13, 2023 at 12:53 PM
    Per dashcam gps while speedo show little closer to 120. (Stock tires). Doesn't go beyond that.
    whippersnapper02 likes this.
  9. Aug 13, 2023 at 1:58 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    whipper snapper is so clutch
  10. Aug 13, 2023 at 2:02 PM
    Lol good to know these speeds! Man I don't even know how fast I've pushed the Toyota? Last time I went over 200kms/125 mph was when I told my passenger I'm gunna break my Dodge SX 2.0 speed record - 10 sec later straight into a road block at the bottom of the hill.
  11. Aug 13, 2023 at 2:50 PM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    With the right tools you can increase the speed limiter on the T4R. 5th gens are set to 175 kph (~109 mph) from the factory.
    Just because you can change it, doesn’t mean you should.
    Some modifications like regears can actually confuse the vehicle computer and impose a lower speed limiter. For example, on 3rd Gen Tacomas a 5.29 regear will limit them to about 83 mph even though computer set to 113 mph.
    Fortuner likes this.
  12. Aug 13, 2023 at 3:47 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Authorities notified...
    whippersnapper02 and Thatbassguy like this.
  13. Aug 13, 2023 at 3:51 PM
    No where says it's my vehicle nor I'm driving. Don't know who. :p
  14. Aug 13, 2023 at 4:06 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    As always, posting for a friend... :anonymous:
    jamied2023, kmeeg[QUOTED] and 2Toys like this.
  15. Aug 13, 2023 at 4:28 PM
    08TXRunner
    '20 SR5P
    Hard to imagine that brick even got that kind of speed.
    kmeeg[QUOTED] likes this.
  16. Aug 15, 2023 at 2:47 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    I test drove a trans am at carmax a loooong time ago and was telling the salesman on the drive about how far off the speedo on my explorer was with the larger tires (i was lifted with 32x11.50 OG BFG KO's). I was registering 90 but blew past my girlfriend at the time on the interstate, who later told me she was doing 90. I told him I was probably doing 100-105 based on how quickly I passed her.
    He then proceeded to lecture me on how it was aerodynamically impossible for a brick shaped SUV like that to go over 100 mph. He said he even struggled to get his Ford focus RS hatchback over 100 mph. After arguing with him for a while I told him he's just an idiot that doesn't know what he's talking about... and that he doesn't know how to drive his car. :argue:
