KDSS spacers and skid plates
Discussion in '5th Gen 4Runners (2010-2024)' started by Jamesngotts, Nov 1, 2021.
  1. Nov 1, 2021 at 10:47 AM
    Jamesngotts
    Jamesngotts [OP] New Member
    2018 4runner TRD Offroad
    TRD PRO 17” Rim 265/70r17 Ko2 tires
    Hi community,
    2018 4Runner TRD Offroad Premium with KDSS.
    So here is the build we are doing:
    *ARB skids
    *Front Bilstein 6112’s set at 2.7” lift
    *Rear Bilstein 5100’s
    *Rear Bilstein 1” lift coils
    *ICON adjustable rear track bar
    *ICON Tubular rear upper and lower trailing arms
    *Bilstein UCAs
    *White Knuckle Rocksliders
    *Treat Oak front KDSS Spacers
    *285/70r17 GY Duratracs
    This will not be a mall crawler. This rig has been out on difficult trails with our first build. Has anyone had issues with the KDSS spacers causing the front sway bar to hit the skid plate? If so, any work arounds or skid plates designed to work withe KDSS spacers. Additionally, with the 2.7” front lift, should we lower the front diff?
    Thanks’s for any feedback.
    icyhotahs likes this.
  2. Nov 1, 2021 at 11:12 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    Why are you doing spacers in the first place? Leveling? I don't have anything against using spacers on difficult trails, but if you intentionally got KDSS, it might depreciate the on-road value of having it.
  3. Nov 1, 2021 at 11:26 AM
    The spacers lower the sway bar to keep it more level on a lifted vehicle. The spacers shouldn't affect handling. But, the primary benefit of KDSS is better articulation off-road.
  4. Nov 1, 2021 at 11:29 AM
    You need atleast KDSS spacers or after market track bar to avoid KDSS bracket hitting sway bay.
    Also this will help on the down travel so KDSS 4Runners will also have down travel as the non KDSS 4Runners after lift.
    Update (adding pic to show this problem) -
    332467d1555820491-new-sonoran-steel-prod_40a5e665c1cba4d0c50848a4dc073ebfd6790120.jpg[​IMG]
  5. Nov 1, 2021 at 11:30 AM
    icyhotahs
    Samuel
    Sacramento, CA
    Definitely on the same page there, I've checked out TOO's stuff as well. I'm just a little weary about altering geometry in general- OP mentioned only the Front Spacers.
  6. Nov 1, 2021 at 11:37 AM
    icyhotahs
    Samuel
    Sacramento, CA
    Odd, my kdss piston isn't anywhere near that close to my (stock) sway bar. Even at full compression. I remember checking that when I added my Eibach load level sytem. Hmmm
  7. Nov 1, 2021 at 11:38 AM
    I'm guessing that it's because he's only lifting the rear an inch. My understanding is that the spacers are only necessary if you are going with extended travel shocks.
    Mtbpsych likes this.
  8. Nov 1, 2021 at 11:39 AM
    icyhotahs
    Samuel
    Sacramento, CA
    Gotcha. Again, this community is great. Sometimes there's competing info.
  9. Nov 1, 2021 at 11:41 AM
    It is! And, I could be wrong. :D I'm just guessing most of the time.
    icyhotahs[QUOTED] likes this.
  10. Nov 1, 2021 at 11:46 AM
    Sorry I couldn't provide any useful information to the original question. My front skid was custom.
    I would imagine some of the aftermarket skids have left a little extra space in there. I just wouldn't chance it. I wonder if any of the skid manufacturers have thought about this.
    Maybe an Email to Treaty Oak would clear things up. They might have heard this question before.
  11. Nov 1, 2021 at 11:47 AM
    From what I see;
    1. Iif KDSS is not lifted more that 1in rear there will be no issues.
    2. But if this spacer or after market track bar is added KDSS can get down travel just like non KDSS when lifted.
  12. Nov 1, 2021 at 12:08 PM
    Jamesngotts
    Treaty Oak are the ones who warned me this maybe a problem but it’s skid to skid and depends.
  13. Nov 1, 2021 at 12:13 PM
    Aha. Hopefully someone here has experience with them.
  14. Nov 1, 2021 at 9:06 PM
    blksubykid
    blksubykid New Member
    Supposedly they clear RCI skids but I’ll let you know in a couple of weeks.
  15. Nov 2, 2021 at 6:10 AM
    Jamesngotts
    Ok thanks! From looking at the ARB ones they seem like there is a good amount of space in there now but I’m not sure how much the bar flexes down as it is now. Maybe some has that number?
    Doglover2003 likes this.
  16. Nov 2, 2021 at 11:03 AM
    Foster1
    Foster1 New Member
    I'm installing the front kdss spacer today but keeping the stock skid for now. Planning to just cut it to make it fit. Don't plan on getting new skids until the stock one is badly banged up.
    I could let you know how it goes and how much I cut, but not sure if you'd be interested in keeping the stock skid at all?
  17. Nov 2, 2021 at 12:47 PM
    Jamesngotts
    Please do let me know how it goes. We have the ARB KDSS skids on there now.
  18. Nov 2, 2021 at 12:51 PM
    TacoTheTaco
    TacoTheTaco New Member
    KDSS hit my stock skid after putting the spacers on. I just trimmed down the notches for the sway bar on the skid plate a bit. It still hits from time to time. I’d think spacing the skid plate would solve most or all of these problems, but haven’t installed my diff drop yet
  19. Nov 2, 2021 at 5:04 PM
    Foster1
    Foster1 New Member
    Finished. Didn't touch the shutter valves at all like some instructions say to do. The sway bar touches the very corner of the skid plate. Here is how much I cut (After and Before):
  20. Nov 2, 2021 at 6:03 PM
    Jamesngotts
    Thanks! I might just cut out that side lip down to the plate. I’ve not done a diff drop on a 4runner, do the kits include hardware lower the skid?
  21. Nov 3, 2021 at 1:23 AM
    Foster1
    Foster1 New Member
    I'm lifted the same amount you plan on doing. The cv angles are great, didn't need a diff drop. Personally, I would hold off on that until you get the lift done first. I'll snap a pic of the cv angle tomorrow and show you.
  22. Nov 3, 2021 at 4:35 AM
    Good thinking! There is really no reason to open it. I would bet some people have actually caused a lean by messing with it.
  23. Nov 3, 2021 at 2:51 PM
    Foster1
    Foster1 New Member
    Not bad at all in my opinion.
  24. Nov 3, 2021 at 3:36 PM
    Looks good!
  25. Dec 20, 2021 at 11:25 PM
    11TrailEd
    11TrailEd New Member
    Ryan
    2011 TE KDSS
    RCI full steel skids and sliders, (soon to have Dobinsons IMS w/C59-302 front & C59-325 rear springs, SPC UCAs)
    @blksubykid
    Did you have a chance to see if the RCI skids clear the KDSS sway bar with the Treaty Oak spacers? I have RCI skids (KDSS specific, steel) and am getting a 2 to 2.5" front lift (1.5 to 2" rear lift) in the next few weeks and want to see if the spacers will work w/ RCI skids. Thanks!
    Netloop and donnermel like this.
  26. Feb 17, 2022 at 12:54 PM
    homesteader
    homesteader New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    So when adding KDSS spacers the shutter valve doesn’t need to be backed out 2 turns? Does that just allow the hydraulic fluid to move freely while installing spacers, which should make installations easier.
    I have treaty oak and plan to do my lift this weekend.
    I was also told to back shutter valve out on my 2022 4Runner.
    I just don’t want to cause any issues.
  27. Feb 17, 2022 at 3:55 PM
    I don't see any benefit to opening it. If you take apart both sides at the same time, opening the valves won't help. Plus, you're less likely to cause a lean.
    This is just my opinion. Do whatever you're comfortable with.
  28. Feb 18, 2022 at 11:31 AM
    homesteader
    Foster
    You mentioned you didn’t touch the shudder valves. Was the piston still able to come down easily to match the fixed side with the spacer?
    Thanks
  29. Feb 18, 2022 at 11:37 AM
    homesteader
    The only concern I had is if the piston will come down freely without force to match the fixed side with the spacer.
    If the shutter valve are open does it matter if it’s on the ground or up on a lift.
    I’ll be using a lift. Exit off-road instructions say off ground on jack stands.
    Do you know what causes the lean after opening shutters?
    thanks
  30. Feb 18, 2022 at 12:03 PM
    If the tires are on level ground, the sway bar will be level. If not, the piston moves with the sway bar.
    I would recommend doing one sway bar at a time. The piston should sit at the same height as the stationary link as long as the other axle stays level.
