KDSS and the PRO Skid plate
Discussion in 'Armor' started by Jamesngotts, Oct 12, 2020.
  1. Oct 12, 2020 at 10:10 AM
    Jamesngotts
    Jamesngotts [OP] New Member
    2018 4runner TRD Offroad
    TRD PRO 17” Rim 265/70r17 Ko2 tires
    I want to share this with the community to prevent some headaches. Pictures attached. TLDR: PRO skid will damage your KDSS if actually used offroad.
    So we have a 2018 4Runner TRD Offroad with KDSS. The wife and I love the look of the PRO and wanted it’s front skid plate. I found an article that describes cutting the PRO skid plate to work with KDSS. So I bought a PRO skid and we followed the cutting directions.
    This will work fine if you are a street crawler. However, we take our rigs offroad in moderate to difficult trails. Last weekend we took the 4Runner through a decent trail and my wife heard a loud metal on metal bang while articulating through an obstacle. I looked back in my rear view and didn’t see any thing that would have hit her skid. I then looked at her front sway bar and saw the rubber bushings were ripped up with a metal fasteners hanging on the sway bar. A closer look at the inside of skid and I could see where the bar hit the edge. I saw a dent on the inside of the plate right below a large nut on the bottom of the sway bar.
    djwantke, siblue, DrewMan and 2 others like this.
  2. Oct 12, 2020 at 11:17 AM
    The skid plate I bought wasn't compatible either. I knew it right away but thought I could make it work.... Now I have a custom skid built by a local off-road shop.
    In the end, this was better because it attaches to the bumper instead of the radiator support.
  3. Oct 12, 2020 at 12:28 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Greenlane off road offers one in 1/4” aluminum for KDSS.
  4. Nov 22, 2020 at 11:29 AM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    Thanks for sharing your experience with us and saving me from going this route!
    So did it bust your seals on the KDSS?
  5. Nov 22, 2020 at 7:48 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Thank you. Good information. I stay with original skid plate which is a little deformed, but still working.
    DrewMan likes this.
  6. Dec 12, 2020 at 10:31 AM
    Jamesngotts
    Sorry for the delayed response. Yes, it did bust the rubber seals on the front KDSS from the impact on the skid. We have since put an ARB skid on which is designed to be clear of the sway bar when it “disconnects”. We have taken it through some pretty rough tracks and had no issues with the durability of the skid or the KDSS hitting it. For $500, I really recommend this 3 piece plate from ARB Pic below.
  7. Dec 12, 2020 at 10:50 AM
    DrewMan
    Middle Tennessee
    no problem and thanks for the update.
    Great price for the (3) plates!
  8. Dec 5, 2023 at 6:08 PM
    UtahSooner
    UtahSooner New Member
    Aaron
    2023 TRD ORP w/ KDSS + Sliding Cargo Deck
    OME BP-51 & UCAs, TRD Pro Facelift & Wheels, GY Duratrac RTs LT285/70R17, Rocky Road Super Sliders
    Thx for sharing this 3 yrs ago @Jamesngotts! I just upgraded to a 2023 ORP with KDSS (finally sold my 2010 TE w/ KDSS & OE skid) and was planning to add the TRD skid - it’s in the garage but not cut/installed yet... This saved me the same eventual trail damage!
    How far below the KDSS brackets does your ARB skid sit (ie how much clearance below the sway bar)? Looks like there are some spacers between it and the frame to drop it lower?
    Thinking that adding additional spacers for the TRD skid to get the same clearance below the sway bar as the stock (or ARB) skid would work. But also thinking that selling the TRD skid and getting the ARB skids might be called for!
  9. Dec 5, 2023 at 6:38 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Appreciate the info, nice. I got the same setup dude
    Rad photo!
    Been running ARB 4-piece set for two years
    (folks informed me it's 3/16" and could also protect T-CASE better, hence the competitive price. Still solid - 1/4" would be nice)
    ✓FRONT SKID PLATE
    ✓FRONT OF TRANSMISSION SKID PLATE
    ✓REAR OF TRANSMISSION SKID PLATE
    ✓HEAT SHIELD ATTACHMENT FOR FRONT DRIVESHAFT PROTECTION
    ✓TRANSFER CASE ATTACHMENT
    @UtahSooner
    UtahSooner likes this.
  10. Dec 5, 2023 at 6:57 PM
    I have my skid plates off for winter maintenance or I'd measure for you, and yes it comes with nice aluminum spacers.
    Fun fact, I didn't own a torque wrench, and lost some of FSR's, few bolts shook right on outta there lol
    UtahSooner[QUOTED] likes this.
  11. Dec 5, 2023 at 7:04 PM
    UtahSooner
    Aaron
    Oh man, no bueno! Hope you got some blue loctite as well when you bought the torque wrench! No rush on the measurements, have a few other project irons in the fire so gonna sit the skid mod to the side for a bit.
  12. Dec 5, 2023 at 8:54 PM
    LOL ya buddy I sure did
    I've bought red as well, proceeded to install my Spidertrax wheel spacers with it, then the trajectory rubbed so hardcore I went straight to a local guy for a BMC and fender mount chop n weld :hattip:
  13. Jan 23, 2024 at 8:54 AM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    Hi: I just installed the ARB plates but stopped short at the transfer case plate. Removing 4 case bolts to install makes me very nervous, as it could induce leaking. Comments? Thx
  14. Feb 5, 2024 at 11:17 AM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    This post makes me nervous! I just installed the Talons Garage full skid plate package on my '24 OR and there's not much space between the KDSS and the front skid. How much down stroke is typical when flexing? They say it's KDSS compatible but there's not much room. What do you guys think?
    Talon2006 likes this.
  15. Feb 5, 2024 at 12:14 PM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    If your LH front tire is also on a ramp, it appears there is no room for KDSS sway bar movement.
  16. Feb 5, 2024 at 12:22 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    Both front tires are on ramps at this point so it's sitting just as it would be if both tires were on the ground.
  17. Feb 5, 2024 at 4:06 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    Are you running a KDSS spacer on the other side? Your swaybar looks very low for two wheels on the ground.
  18. Feb 5, 2024 at 4:09 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    No, suspension is stock.
  19. Feb 14, 2024 at 7:02 AM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    In case anyone is still interested, I found that the ram has about 3.5" of total stroke in my testing, 1.75" up and 1.75" down. Therefor, as the 4R sits with all tires on level ground, you should have up to 2" of clearance between the bottom of the RAM and a skid plate.
    UtahSooner and ID_Yeti like this.
