Just purchased my first 4Runner
Discussion in 'New Member Introductions' started by Kevkess115, Sep 29, 2025.
  1. Sep 29, 2025 at 11:35 AM
    Kevkess115
    Kevkess115 [OP] New Member
    2025 TRD Sport Premium
    I am happy to become a member of the 4Runner Club! I had been contemplating for over a year about buying a new 4Runner and I am glad I waited! I love driving my new 2025 TRD Sport Pro and all the features with it! The 2.4L engine runs great and the 8 speed transmission is very smooth. I had talked to many different owners and all reported loving their 4Runners before making my decision. My next step was to talk to several mechanics and they all reported these were well built vehicles. Now it's time to do my homework and learn all the electronics.
    werlyb23, Mr.DRZ, rphillips66 and 5 others like this.
  2. Sep 29, 2025 at 11:41 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Looking good! Great color. And you probably already know that body colored fenders add another 5hp per wheel so good choice there.
    djwantke likes this.
  3. Sep 29, 2025 at 11:46 AM
  4. Sep 29, 2025 at 11:59 AM
    welcome
  5. Sep 29, 2025 at 12:25 PM
    This post brought to you by AI
    Please trade in your 5th gen for 6th gen
    The market is struggling and it's all your faults
    fiddy5000 and FourBelugas like this.
  6. Sep 29, 2025 at 1:42 PM
    DesertSurfer
    Congrats on your new rig and welcome to the forum.
  7. Sep 29, 2025 at 2:20 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Congrats! That's amazing you knew so many different individual long time 6th gen owners with such abundant amount of experience with their 6th gens, and have access to several mechanics who knew the 6th gen so well, as to give you such in depth feedback, especially considering the 2025 model year is essentially a completely different vehicle than the now obsolete 5th gen, the only thing they share being the brand and model names.
    2Toys, Danno83 and djwantke like this.
  8. Sep 29, 2025 at 2:34 PM
    FourBelugas
    23 white ORP
    now now, let's go easy on the guy. It's not often a first time 4runner buyer is this informed on their purchase. I have only seen one 2025 in my area so I don't have access that kind of data points.
  9. Sep 29, 2025 at 3:47 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    Welcome!
  10. Sep 29, 2025 at 4:31 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    :rimshot:
  11. Sep 30, 2025 at 3:28 AM
  12. Sep 30, 2025 at 3:29 AM
    Welcome from Wisconsin!
  13. Sep 30, 2025 at 6:45 AM
  14. Sep 30, 2025 at 7:02 AM
    Danno83
    Danno83 New Member
    Southern Louisiana
    2024 Silver TRD ORP
    TRD Pro grille, blackout badging, Toyota Orweillian tracking delete.
    How do several mechanics know that these are well built vehicles? Do they own them? Have they had several 6th gen 4runners come through their shop? This post seems very odd.
    FourBelugas and 2Toys like this.
  15. Sep 30, 2025 at 7:08 AM
    Probably speaking about 4Runner's in general, I know there's a lot of nitty-gritty technical details and Toyota decisions we can get into but I think it's best to keep it at being happy for OP as long as it didn't cost their first-born plus interest. :D
    Mr.DRZ and 2Toys like this.
  16. Sep 30, 2025 at 7:36 AM
    This isnt the first. If you are a daily subscriber you would notice quite a few like this. Most are hidden in other threads, this one has its own thread as the OP. I'm sure these are just excited new owners who just purchased a 6th gen and decided to let Chat GPT write their post for them...... Or its Toyota using bots to try to steer consensus and generate sales.
  17. Sep 30, 2025 at 8:22 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Time will tell if OP is a one and done.
  18. Sep 30, 2025 at 10:31 AM
    HuskerRunner
    O,NE
    2023 SR5P
    Congrats on getting a TRD Sport Pro. Extremely hard to find trim level in most areas
