Just noticed when pressing brake...
Discussion in '5th Gen 4Runners (2010-2024)' started by UG4runner, Nov 29, 2025.
  1. Nov 29, 2025 at 1:25 PM
    UG4runner
    UG4runner [OP] New Member
    2024 Toyota 4Runner Sr5 Premium Underground
    Just noticed when i press on the brake( both when running or not running) around halfway on press i hear a very slight tick noise...i never noticed it before...but i guess its so minor just never noticed it...Brakes are fine no issue....Is this normal?...Thanks in advance.
    Shredder likes this.
  2. Nov 29, 2025 at 1:29 PM
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    Mine doesn’t do that, could it be something on or near your brake pedal linkage? Or frozen brakes clunking?
  3. Nov 29, 2025 at 1:42 PM
    UG4runner
    definately very light tick...sounds like its very close to pedal and inside the car..
  4. Nov 29, 2025 at 2:20 PM
    Shredder
    Shredder New Member
    23 OR
    Tires, shocks
    Could it be the pedal itself? (a beer can under the pedal does that too, lol.)
    Edit, maybe brake linkage hitting something when you press the brake?
  5. Nov 29, 2025 at 2:57 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    It could be the plastic plunger on the brake switch activating.
    RumHamRunner73 and Saker like this.
  6. Nov 29, 2025 at 10:38 PM
    UG4runner
    I dont see any difference in brakes....Brake lights fine...Ill guess ill just monitor to see if it makes any changes
  7. Nov 30, 2025 at 4:50 AM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    About 6 months ago I was cleaning my truck and I found a small rubber dampener on my floor liner. Since then, when I put enough pressure on the brake, and even today it happens I get a click.
    there is a return spring in the brake pedal. If it doesn’t have the rubber peice on it , it will make a click
    08TXRunner likes this.
  8. Nov 30, 2025 at 8:32 AM
    UG4runner
    Maybe its that...im no mechanic...im not going to fret over it...if it gets worse ill bring it in...only year and half with 12k miles...under warranty...but i hate bringing my truck to toyota...they usually make things worse
    Taylor21554 likes this.
  9. Nov 30, 2025 at 10:06 AM
    UG4runner
    Brake-pedal stopper pad / rubber bumper There’s a little rubber stopper on the brake pedal arm that hits a plastic switch when you press the pedal (it tells the ECU the brakes are on so it can kill cruise control, shift out of park, turn off brake lights, etc.).
    On a bunch of 2023–2025 4Runners (and Tacomas, Land Cruisers, etc.) that rubber piece hardens or shrinks a hair and starts making a single faint “tick” or “click” every time the pedal is pressed or released — engine running or not, hot or cold.
    • Doesn’t affect braking at all
    • Doesn’t throw any codes
    • Just an annoying little tick you notice because the cabin is so quiet
    The 2-Minute Permanent Fix (Costs $3–$8)
    Toyota sells the updated stopper pad under part 47121-12020 (about $4 at the dealer or $3 on Amazon/RockAuto). Literally a 60-second job:
    1. Pop the driver-side lower dash panel off (two clips)
    2. Reach up behind the brake pedal, pry the old rubber stopper out with a flathead
    3. Push the new one in until it clicks
    4. Done — tick gone forever
    Could it be this???
    Grug556, Taylor21554 and alittleoff like this.
  10. Nov 30, 2025 at 11:33 AM
    Taylor21554
    Naples Florida
    24 SR5 4x4
    Yes it is that. At least for me. I have the dampener in my glove box. Maybe one day I’ll do it myself. But it doesn’t bother me, no braking issues, and I don’t want to bring my truck to the dealer.
    Sometimes it clicks, sometimes it doesn’t. It just suppressing the noise that the spring makes. I can see how it could be a little annoying
