JB Weld
Discussion in '4th Gen 4Runners (2003-2009)' started by esamos, May 21, 2025 at 5:12 AM.
  1. May 21, 2025 at 5:12 AM
    esamos
    esamos [OP] New Member
    2006 Limited V8 4wd
    Any have experience with JB Weld for bonding plastic together? Best bond all-weather material for plastic on plastic?
  2. May 21, 2025 at 6:20 AM
    grumpy 02
    grumpy 02 New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    IMO JB weld is not the BEST but usually will work if you rough up the surfaces and clean them well. BEST would be the solvent for the specific plastic involved---ABS cement for ABS, PVC cement for PVC etc.
  3. May 21, 2025 at 6:36 AM
    esamos
    2006 Limited V8 4wd
    Thanks. I’m potentially trying to fabricate a 5th gen TRD grill onto my 4th gen. I might be able to reuse the brackets from the 4th gen grill but they will need to be fastened in some way, probably with a glue of some sort.
  4. May 21, 2025 at 6:36 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
  5. May 21, 2025 at 9:23 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Are you seeking a strong joint, or a near invisible joint.
    As mentioned, solvent welding gives a small joint.
    Another strong joint is heat soldering/welding. Use a soldering iron set to the correct temperature to melt but not burn the plastic. And plastic weld filler rods can be purchased. Very technique dependent so practice before doing real job.
  6. May 22, 2025 at 2:55 AM
    I've used Permatex black plastic welder with great results on a side by side tailgate. It comes with a 2-part epoxy type applicator, it's Permatex part number 84145.
