It’s TOYOTA Tuesday
Discussion in 'General 4Runner Talk' started by djwantke, Sep 30, 2025.
  1. Jan 30, 2026 at 11:31 AM
    #121
    Borracho Loco New Member
    Sorry, all we can focus on are those chrome lugs ya' got:
  2. Jan 30, 2026 at 5:39 PM
    #122
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    lol
  3. Jan 30, 2026 at 5:43 PM
    #123
    lol
    ice cold shiny chrome :p:p
    Borracho Loco[QUOTED] likes this.
  4. Jan 30, 2026 at 7:29 PM
    #124
    Beachguy
    2024 TRP ORP
    Everyone knows you have no focus. Except on raptor lights.
  5. Jan 30, 2026 at 9:11 PM
    #125
    Borracho Loco and Rocket-67 like this.
  6. Jan 31, 2026 at 5:19 AM
    #126
    That was a good burn. Well done, sir.
    Also me when I see raptor lights on a 4Runner:
    Rocket-67 likes this.
  7. Jan 31, 2026 at 8:08 AM
    #127
    brownersd
    Sean
    Humble / Kingwood, Texas
    All about the doggies...
    NB4x4, Captain Spalding and Rocket-67 like this.
  8. Jan 31, 2026 at 7:51 PM
    #128
  9. Feb 2, 2026 at 8:04 PM
    #129
    Check out this Dixxon shirt. “The Overlander”
  10. Feb 3, 2026 at 1:02 AM
    #130
    it’s Toyota Tuesday.
    share favorite pic(s), of Toyota’s you’ve owned.
    and don’t use thread as your dumping ground til next Tuesday :p
    brownersd and BS67 like this.
  11. Feb 3, 2026 at 3:58 AM
    #131
    Beachguy
    2024 TRP ORP
    my ‘21 SR5P on the beach at Port Aransas.
    T4runner11, brownersd and Rocket-67 like this.
  12. Feb 3, 2026 at 5:01 AM
    #132
    Solution? Colorlugs.
    (Linkythingy)
  13. Feb 3, 2026 at 8:16 AM
    #133
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I dump when I want to... :crapstorm:
    brownersd likes this.
  14. Feb 3, 2026 at 9:18 AM
    #134
    T'sToy13
    T'sToy13 New Member
    Tony
    2019 Midnight Black 4Runner
    Circa 1995.....1978 Toyota Celica GT Coupe.........slightly modified :oldglory:
    Rocket-67 and 2Toys like this.
  15. Feb 4, 2026 at 4:29 PM
    #135
    whoa!! what is this folks
  16. Feb 10, 2026 at 4:26 PM
    #136
    workin in the garage last night
  17. Feb 10, 2026 at 5:42 PM
    #137
    T4runner11
    T4runner11 Member
    NYC
    11 SR5P MGM
    TRD Pro Bilstein Suspension TRD Pro skid plate TRD air filter TRD Pro Wheels (21) w Nitto Terra Kicker speakers with kicker amp
    Throwback to my 04 Sr5 Tacoma that I miss very much and current
    Rocket-67, djwantke[OP] and Lc200 like this.
  18. Feb 10, 2026 at 7:57 PM
    #138
    sick!
    T4runner11[QUOTED] likes this.
  19. Feb 10, 2026 at 9:09 PM
    #139
    brownersd
    Sean
  20. Feb 10, 2026 at 9:09 PM
    #140
    a late 70s or early 80s straight axle pickup with a lift and a camper bed.
    An overlanders dream
  21. Feb 11, 2026 at 2:07 PM
    #141
    It’s Wet Wednesday
    T4runner11, 2Toys and Rocket-67 like this.
  22. Feb 12, 2026 at 6:58 AM
    #142
    Throwback Thursday
    spotted this old welding pickup at work
    Rocket-67 and NB4x4 like this.
  23. Feb 15, 2026 at 1:45 PM
    #143
    Saw this in town today. If I wait until Tuesday to post it I’ll forget.
  24. Feb 15, 2026 at 4:25 PM
    #144
    oh wow
    :headbang:
    and it’s got the things. steel bumpers, winch, left hand drive. diesel?
  25. Feb 17, 2026 at 8:11 PM
    #145
    almost missed Toyota Tuesday.
  26. Feb 18, 2026 at 8:37 AM
    #146
  27. Feb 24, 2026 at 9:45 AM
    #147
    it’s Toyota Tuesday
    2Toys, ToyotaDude99 and NB4x4 like this.
  28. Feb 24, 2026 at 11:46 AM
    #148
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    26 I picked up a couple weeks ago. MGM to match the 4Runner
    ToyotaDude99 likes this.
  29. Feb 24, 2026 at 12:52 PM
    #149
    dang!
    :spending:
    ToyotaDude99, 2Toys and Trees91 like this.
  30. Feb 24, 2026 at 5:32 PM
    #150
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    Had my last pickup for 10 years. 09 f150 with a 5.4. Was a great pickup, that 5.4 just kept ticking along ha. Just got a lot of miles and got rusty.
    Hoping for 10 years out of this one...fingers crossed.
